Post reply
Something happened, review it here:
  • Warning: this topic has not been posted in for at least 120 days.
Warning! This topic is currently/will be locked
Only admins and moderators can reply.
shortcuts: alt+s submit/post or alt+p preview
Attachments and other options
Add files by dragging & dropping or selecting them Add files
Attach:
(Clear attachment)
(more attachments)
Allowed file types: doc, gif, jpg, mpg, pdf, png, txt, zip
Restrictions: 15 per post, maximum total size 8,192 KB, maximum individual size 2,048 KB
Note that any files attached will not be displayed until approved by a moderator.
Topic Summary
Posted by mrworf - June 07, 2017, 12:37:37 am
I otvoren
Posted by mrworf - June 07, 2017, 12:37:06 am
Evo i par slikica "skalamerije".
Posted by mrworf - June 07, 2017, 12:32:35 am
Oke, kada napravim pet postova, onda ću staviti u oglas što tražim! :)
Posted by robi1kenobi - June 04, 2017, 07:14:05 pm
Imas u oglasniku stanica po bagatela cijenama, sve su bolje od 9X. Oko dometa se nemoj sekirat
Posted by mrworf - June 04, 2017, 04:49:54 pm
Bilo bi sjajno kada bi netko tu prodavao Turnigy 9x
Posted by mrworf - June 03, 2017, 07:32:40 pm
Hvala na odgovoru! Koliki je domet tih stanica?
Posted by varadero - June 03, 2017, 08:57:21 am
Pozdrav,
Prvo pročitaj tu:
http://www.flyfreak.net/pocetnici/modelarstvo-kako-poceti/
A onda, najbolje ti je neka stanica od barem 8 kanala za to sve, ako si možeš priuštiti Taranisa,super. Ako ne, Turnigy 9x je jeftinija varijanta.
Posted by mrworf - June 02, 2017, 10:07:03 pm
Pozdrav svima! Novi sam na forumu i interesiraju me sve vrste letjelica ali za sada ću se baviti samo dronovima dok financije ne dozvole više. Na 3D printeru sam isprintaio Mavic klona i za sada naručio samo motore. Ostalo će malo pričekati dok se sa vama ne konzultiram.
Trebat će mi stanica a pošto se baš i ne kužim u sve to skupa, volio bi da mi predložite neku. Znaći osim što može voziti drona da može i pomicati gimbal i eventualno ugasiti svjetla na dronu.
3D print i instrukcije; http://www.instructables.com/id/Printable-Foldable-Quadcopter-DJI-Mavic-Clone-Fram/
Gimbal: https://www.aliexpress.com/item/Gopro3-Lightweight-2-AXIS-Brushless-Gimbal-Board-with-Sensor-Free-Debug-RC-FPV/32783551909.html?spm=2114.01010208.3.134.ZO2fCq&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10068_5010015_10136_10137_10060_10138_10155_10062_437_10154_10056_10055_10054_10059_303_100031_10099_10103_10102_10096_10052_10053_10142_10107_10050_10051_5030015_10084_10083_10080_10082_10081_10110_519_10111_10112_10113_10114_10179_10182_10185_10078_10079_10073_10123_10189_142,searchweb201603_16,ppcSwitch_7&btsid=607fc8d1-b211-4b5b-af92-bcfe34034301&algo_expid=fc8aafc6-94aa-4f4c-96ae-aab49bd4a244-18&algo_pvid=fc8aafc6-94aa-4f4c-96ae-aab49bd4a244
Eto, to je manje više to! Pozz svima! :)
