Post reply
Something happened, review it here:
  • Warning: this topic has not been posted in for at least 120 days.
Warning! This topic is currently/will be locked
Only admins and moderators can reply.
shortcuts: alt+s submit/post or alt+p preview
Attachments and other options
Add files by dragging & dropping or selecting them Add files
Attach:
(Clear attachment)
(more attachments)
Allowed file types: doc, gif, jpg, mpg, pdf, png, txt, zip
Restrictions: 15 per post, maximum total size 8,192 KB, maximum individual size 2,048 KB
Note that any files attached will not be displayed until approved by a moderator.
Topic Summary
Posted by MarioMT - August 11, 2017, 04:35:29 pm
Probaj žice sa motora na ESC promjenit,možda si signal žicu krivo ušteko.Samo nagađam.Imaš kakve upute od ESC ?Ako imaš onda je riješen slučaj.Potraži na netu od ArtTecha u PDF-u upute za ESC to bi puno pomoglo.
Posted by varadero - August 09, 2017, 07:35:06 am
Standardna procedura:
1. Upališ stanicu, gas do daske
2. spojiš bateriju na model
3. sačekaš da nešto otpišti i odmah spustiš gas na minimum na stanici
4. sačekaš eventualno da još nešto otpišti
5. isprobaj da li sad radi
Ovo se zove učenje ESCa na tvoj raspon gasa na stanici.
I da, provjeri na koji kanal si ubo ESC na prijemniku, kod Turnigy-a je to 3. kanal, kod mene je 1. Pogledaj i na Monitor screenu na stanici koji ti kanal radi kada dodaješ gas...i da li uopće radi.
Posted by Maverick Top Gun :) - August 08, 2017, 10:27:13 pm
i to pokušao...i dalje ništa
Posted by Ikarus - August 08, 2017, 09:30:37 pm
probaj smanjit throttle trim ili reversat throttle kanal. Ako je throttle povišen, onda esc nece da odsvira početnu melodiju iz sigurnosnih razloga. To napravi bez propelera 8)
Posted by Maverick Top Gun :) - August 08, 2017, 08:59:14 pm
Pozdrav, danas mi je stigao alpha jet od art techa
kada spojim bateriju na esc (40A) motor odmah počne konstantno pištati, ali se ne okreće...čak ni neda ono "uvodno pištanje" nego odmah bip, bip bip u razmaku od jedne sekunde....pokušao sam kalibraciju, bindanje ali on i dalje pišti....stanica turnigy 9x
pa eto, molim pomoć  :-[
