Autor Tema: P: Autić 1/18 Brushless 4WD Stadium Truck i stanicu  (Posjeta: 2103 puta)
0 Članova i 1 Gost pregledava ovu temu.
Offline hrvojehrvoje
  • Pravi letač
  • Postova: 116
« u: Travanj 19, 2016, 12:22:27 poslijepodne »
Prodajem komplet autić 1/18 https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=29978
1/18 Brushless 4WD Stadium Truck w/ 18Amp System (EU Warehouse)
Turnigy 1300mAh 2S 20C Lipo Pack (Suit 1/18th Truck) (EU Warehouse)   2kom
Quanum 2.4Ghz 3ch Pistol Grip Tx & Rx System (EU Warehouse)
i ponešto dijelova
Mini 4-Way Hex Wrench Tool (7mm, 5.5mm, 4.5mm, 4mm)
Front Susp.arm - L/R 2 pcs - 118B, A2006, A2023T and A2035    2kom
Rear Susp.arm-L/R 2 pcs - 118B, A2006, A2023T and A2035
Front upright - L/R 2 pcs - 118B, A2006, A2023T and A2035
Dogbone 2 pcs - 118B, A2006, A2023T and A2035
Front Steering arm-L/R (2 pcs) - 118B, A2006, A2023T and A2035
Rear Hub Carrier-L/R (2 pcs) - 118B, A2006, A2023T and A2035
Front /Rear Axle 2 pcs - 118B, A2006, A2023T and A2035
Front Camber Link set 2 pcs - 118B, A2006, A2023T and A2035
Steering Tie Rod Set 2pcs - 118B, A2006, A2023T and A2035
Spur Gear-60T - 118B, A2006, A2023T, A2028 and A2035
Chassics Bracket 1 set - 118B, A2006, A2023T and A2035
Steering Drag Link 1pc - 118B, A2006, A2023T and A2035
Autić je burazov, vozio ga je cca 10-15 puta, prošao ga gušt i sad skuplja prašinu, meni su draži avioni, a dan ima samo 24 sata. Ja sam ga isprobao, fora je, čak mogu reći da je i solidno brz.
Umjesto metalnih piksi stavljeni su ležajevi na kotače. Pikse isto dobijete.
Autić je stigao sa hladno zalemljenim žicama na motoru, popravljeno, radi bez greške .. motor računam sa cca 0Kn, ako nekad rikne, zamjenski je cca 10-12USD na HK, a ima i jeftinijih na BG i slično.
Prednji ovjes puknuo prvi dan nakon par običnih prevrtanja na zemlji/travi, ovako pokrpan je pretpostavljam nekoliko puta čvršći od originala. Novom vlasniku preporučam da nabavi http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14229&aff=4031 jer je jedan pin odletio i sad je umjesto njega DIY zamjenski (exploded view http://www.hobbyking.com/hobbyking/store/uploads/995173986X4031X56.pdf)
Autić, stanica, baterije, rezervni dijelovi, križni ključ za kotače, cijena 800Kn
dodatno može i alat sa slike po nabavnoj cijeni https://www.lindinger.at/de/mehr/werkzeuge/handwerkzeuge/planet-hobby-werkzeugsatz-27-tlg.
« Zadnja izmjena: Travanj 20, 2016, 08:27:25 prijepodne od hrvojehrvoje »
  • Pravi letač
  • Postova: 116
Odg: P: Autić 1/18 Brushless 4WD Stadium Truck i stanicu
« Odgovori #1 u: Svibanj 10, 2016, 09:14:55 poslijepodne »
bump
Offline Milan Prša
  • Pravi letač
  • Postova: 114
« Odgovori #2 u: Siječanj 29, 2017, 03:25:27 poslijepodne »
imate poruku u inbox-u
usuditi se to je cijena napretka
Offline kbelcar
  • Glavna faca
  • Postova: 756
« Odgovori #3 u: Ožujak 25, 2017, 11:25:23 prijepodne »
Pozz
Je'l autic prodan?
LP,  Chris
... gravity always wins ....
  • Pravi letač
  • Postova: 116
« Odgovori #4 u: Ožujak 25, 2017, 01:25:21 poslijepodne »
 sorry, kako se mjesecima nitko nije javio na oglas, na autic sam se nekak naviknuo
.. ako se predomislim javim
Powered by SMF © 2014 | Style by FlyFreak
