Autor Tema: P: Turnigy Graphene 1300mAh 4S 65C Lipo Pack XT60 Removable Balance Plug  (Posjeta: 668 puta)
0 Članova i 1 Gost pregledava ovu temu.
Offline mlilasic
  • Pravi letač
  • Postova: 131
  • Triky-Zagi-ZMR250-QAV210-RealaccX210-XBEE_X200-Mix
« u: Ožujak 15, 2018, 12:06:01 prijepodne »
PRODANO
Specs:
  • Capacity: 1300mAh
  • Voltage: 4S1P / 4 Cell / 14.8V
  • Discharge: 65C Constant / 130C Burst
  • Weight: 166g (including wire, plug & case)
  • Dimensions: 78x35x33mmBalance
  • Plug: JST-XH
  • Discharge Plug: XT-60
Note: Graphene LiPo Batteries only require a standard Lipo battery charger.
Advantages over traditional Lipo batteries:
• Power density: 0.15-0.17kw/kg (5Ah-16Ah)
• Power density: 0.13-0.15kw/kg (1Ah-4.9Ah).
• Stable High pack voltage through the duration of use.
• High discharge rate, giving more power under load.
• Internal impedance can reach as low as 1.2mO compared to that of 3mO of a standard Lipoly.
• Greater thermal control, packs stay much cooler under extreme conditions
• Higher capacity during heavy discharge.
• Maintains higher pack capacity even after hundreds of cycles
• Fast charge capable, up to 15C on some batteries.
• Longer Cycle Life 600+
« Zadnja izmjena: Veljača 14, 2019, 09:43:15 poslijepodne od mlilasic »
Powered by SMF © 2014 | Style by FlyFreak
