Autor Tema: Prodano: EDF turbine  (Posjeta: 948 puta)
0 Članova i 1 Gost pregledava ovu temu.
Offline Raven
  • Pravi letač
  • Postova: 248
  • Njub
« u: Lipanj 27, 2018, 07:50:01 poslijepodne »
Na prodaju dvije EDF turbine.
64 mm EDF turbina za 3S 6 listova  -  100 kn
Turbina je za 3S bateriju, ima 6 listova.
Daje cca. 650-700 g potiska, na struju oko 35A.
Ne znam točne podatke jer je došla sa Alpha jet avionom. Taj avion je dosta brz, iz čega se vidi da je turbina ok stroj.
Dr. MadThrust 64mm Alloy EDF 4000kv 850w 4S EDF turbina -  PRODANO
Turbina korištena kroz cca. desetak letova. Odlična kvaliteta i odličan potisak.
Tvornički izbalansirana. Metalno kučište sto doprinosi kvaliteti i zvuku.
Vuče otprilike 45A i daje potisak kojih 1.1kg.
Sluzbeni opis i specifikacije:
The Hobbyking Alloy EDF series are pre-assembled and dynamically balanced making them simple and easy to fit, no unit assembly is required. As well as high power, these fans have excellent cooling and run so smoothly, the sound is amazing, there is also no housing distortion unlike plastic fans. This nice quality, powerful fan is a great way to upgrade your foamy 64mm jet to a missile in around an hour!
Features:
Pre-assembled
Factory dynamically balanced
High power with superior cooling
High quality construction
Fully servicable
Fast to fit
No housing distortion
Specs:
Rotor Diameter: 64mm 5 Blade
Outer Diameter: 66mm
Weight: 145g with 3.5mm Connectors
Motor: 2836L Brushless outrunner 4000kv
Max RPM: 60,000
Continous Power: 650w
Max Power: 850w
Max Amps: 43A
Max Thrust: 1.06kg
Timing: High
« Zadnja izmjena: Listopad 10, 2018, 01:01:25 poslijepodne od Raven »
Offline Raven
  • Pravi letač
  • Postova: 248
  • Njub
Odg: P: EDF turbine
« Odgovori #1 u: Srpanj 30, 2018, 07:52:51 poslijepodne »
Veća prodana, manja još uvijek na lageru.
Offline Raven
  • Pravi letač
  • Postova: 248
  • Njub
Odg: P: EDF turbine
« Odgovori #2 u: Kolovoz 24, 2018, 03:45:33 poslijepodne »
Bump, turbina jos u prodaji...
Offline Raven
  • Pravi letač
  • Postova: 248
  • Njub
Odg: P: EDF turbine
« Odgovori #3 u: Listopad 10, 2018, 01:00:50 poslijepodne »
Prodano...
Powered by SMF © 2014 | Style by FlyFreak
