Autor Tema: P:FPV vtx i rx,Voltage regulatore, FC SHARK X6,NAZA M,TURNIGY i10,MOTORI,REGLERI  (Posjeta: 738 puta)
0 Članova i 1 Gost pregledava ovu temu.
Offline MARKO 31
  • Pravi letač
  • Postova: 153
  • Sve što možeš sutra,,nemoj danas!!!!
Prodajem:* Boscam Tx i Rx RC/TS832 5.8G 600MW 48ch NOVO NE KORIŠTENO.300kn
        *DC-DC step-down power module *Input Voltage Range: DC 3.2V to 40V (input voltage must be more than 1.5V higher than the output voltage, Cannot boost) *Output Voltage Range: DC 1.25V to 35V (Voltage continuously adjustable, high efficiency, maximum output current of 3A) *Uses solid capacitor, 36U thickening circuit board, high Q value high power inductance *With output LED indicator *If the working time is long, it is recommended to use the current within 2.5A, more than 2A need to add heat sink (more than 10W output) *In order to ensure the output stability, please keep the minimum 1.5V pressure difference *IN+ for input positive pole, IN- for input negative pole *OUT+ for output positive pole, OUT- for output negative pole Specifications: *Input Voltage: 3.2V~40V *Output Voltage: 1.25V~35V *Output Current: 3A (max). Odličan za izradu Bec-ova,drži voltažu u decimalu. Dostupno više komada. 40kn/kom        *FC SHARK X6,NOV NE KORIŠTEN,odličan FC jako puno modova,jednostavan.Shark X6 the multicopter control and autopilot system is specially designed for all multi-rotor enthusiasts. It packed in a full metal casing, with highly integrated and compact design, which provides durability and good flight performance. Shark X6 autopilot system make your multicopter highly maneuverable and stable in the sky. SharkX6 equipped with 3-axis gyroscope,3-axis accelerometer, barometer and others. With additional of the GPS module that use advance attitude stabilization algorithm, It could provide better stability. The system provides complete failsafe protection for your multicopter which include return to home, low voltage protection and auto landing. 450kn*****UZ OVO SVE NADODAJEM I SLIJEDEĆE: DJI NAZA M dignuta na V2....250KN      TURNIGY tgy i10 sa prijemnikom 10ch......700kn                                                             T-MOTORI 2216 900Kv     5kom         400kn      KOPTERWORX REGLERI 30A   6kom      350kn                                                             GIMBAL Mini 3d  400KN                                                             BATERIJE TATTU 4S 6750mAh    2kom    obje 400kn                  ZA VIŠE DETALJA,SLIKA I OSTALOG MOŽE KONTAKT NA 0916224319(WHATSUP,VIBER,SMS.....)
« Zadnja izmjena: Veljača 21, 2019, 06:54:23 poslijepodne od MARKO 31 »
Titus 600 y6,Turnigy tgy i10,S550,DJI PH3 PRO
Offline MARKO 31
  • Pravi letač
  • Postova: 153
Odg: P:FPV vtx i rx,Voltage regulatore, FC SHARK X6
« Odgovori #1 u: Siječanj 23, 2019, 05:12:45 poslijepodne »
Regulatore voltaže sam osobno koristio za Ubec 12V, i za grijač svijećice nitro motora, voltažu sam sa LiPo 3s spustio na 1,39v. Radi savršeno.
Offline MARKO 31
  • Pravi letač
  • Postova: 153
Odg: P:FPV vtx i rx,Voltage regulatore, FC SHARK X6,NAZA M,TURNIGY i10,MOTORI,REGLERI
« Odgovori #2 u: Veljača 21, 2019, 06:49:17 poslijepodne »
UPPPPPPP
Offline MARKO 31
  • Pravi letač
  • Postova: 153
« Odgovori #3 u: Ožujak 03, 2019, 07:59:23 prijepodne »
BUMP
Offline MARKO 31
  • Pravi letač
  • Postova: 153
« Odgovori #4 u: Ožujak 10, 2019, 09:27:14 poslijepodne »
Naza Prodana
Powered by SMF © 2014 | Style by FlyFreak
