FlyFreak
RC Modeli => Samogradnja => Paraglideri => Topic started by: tonik on February 22, 2013, 12:20:05 am
Title: FPV Paraglider
Post by: tonik on February 22, 2013, 12:20:05 am
Pozdrav  ;)
Nakon EasyStara i multija idem provat složit i jedan paraglider za FPV .
Čak mislim da će sa njime FPV biti još i najopušteniji .
Imam namjeru složit ovako nešto;
http://www.opale-paramodels.com/index.php/en/shop-opaleparamodels/24/24/rc-paramotor-frames/trike-m2/trike-m2-set-1-detail (http://www.opale-paramodels.com/index.php/en/shop-opaleparamodels/24/24/rc-paramotor-frames/trike-m2/trike-m2-set-1-detail)
ili ovako nešto ali lakši malo
http://www.opale-paramodels.com/index.php/en/shop-opaleparamodels/26/25/rc-paramotor-frames/trike-l/trike-l-set-1-detail (http://www.opale-paramodels.com/index.php/en/shop-opaleparamodels/26/25/rc-paramotor-frames/trike-l/trike-l-set-1-detail)
Malo sam pronjuškao po ladicama i našao skoro sve potrebno za njega. Motor i regler ostao višak od multija, servoi su bili namjenjeni za buggya koji će još malo čekat, baterije imam od trikija i hexe, krila imam dva jedno je ono "zgužvano"           od H.K.  a drugo je cca 25-30% veće koje je davno kupljeno klincu da se igra na vjetru.
Idemo redom, popis djelova;
-motor (4215 / 650 kv) (ovi noviji su sada crne boje )
http://www.rctimer.com/index.php?gOo=goods_details.dwt&goodsid=709&productname= (http://www.rctimer.com/index.php?gOo=goods_details.dwt&goodsid=709&productname=)
-regler je 30 A http://www.rctimer.com/index.php?gOo=goods_details.dwt&goodsid=146&productname= (http://www.rctimer.com/index.php?gOo=goods_details.dwt&goodsid=146&productname=)
-servoi 15 kg. MG http://www.rctimer.com/index.php?gOo=goods_details.dwt&goodsid=461&productname= (http://www.rctimer.com/index.php?gOo=goods_details.dwt&goodsid=461&productname=)
-baterije 4S   2200  ili  4900 mAh http://www.hobbyking.com/hobbyking/store/__9943__ZIPPY_Flightmax_2200mAh_4S1P_40C.html (http://www.hobbyking.com/hobbyking/store/__9943__ZIPPY_Flightmax_2200mAh_4S1P_40C.html)
http://www.hobbyking.com/hobbyking/store/__9260__Rhino_4900mAh_4S1P_25C_Lipoly_Pack.html (http://www.hobbyking.com/hobbyking/store/__9260__Rhino_4900mAh_4S1P_25C_Lipoly_Pack.html)
ide još i jedna mala baterija 3S 460-750 mAh za napajanje video TX na modelu
-krilo http://www.hobbyking.com/hobbyking/store/__14284__HobbyKing_Paraglider_Parafoil_2_15m.html (http://www.hobbyking.com/hobbyking/store/__14284__HobbyKing_Paraglider_Parafoil_2_15m.html)
 ali nešto mi govori da će gore ipak  ovaj malo veći
http://www.lmstoys.com/usr/product.aspx?id=403&grpid=114&grpingid=3 (http://www.lmstoys.com/usr/product.aspx?id=403&grpid=114&grpingid=3)
-alu profili su kupljeni u Bauhaus-u od 1 met. ; šuplje cijevčice promjera 6,8 i 12 mm
(napravio sam i alat za savijat šuplje cijevi od malih kolotura za pojedini promjer),
 jedna lajsna širine 15x2 mm. a i jednu staru tv.antenu sam demolirao i uzeo one prve štangice  promjera 4 mm dužine 45 cm. Kućište za servo-e  koje je ujedno i nosač motora planiram napravit od alu. ploče debljine 2-3 mm.
 Aluminij ću spajat Durafix štangicama (provao sam i mogu vam reć da sam oduševljen, postoji par caka ali više o tome ima na linku ispod)
http://www.durafix.hr/index.php (http://www.durafix.hr/index.php)
-kamera ide gopro i  sony ccd 520p http://www.hobbyking.com/hobbyking/store/__16461__1_3_inch_SONY_CCD_Video_Camera_PAL_.html (http://www.hobbyking.com/hobbyking/store/__16461__1_3_inch_SONY_CCD_Video_Camera_PAL_.html)
-video link je Lawmate 1.2 ghz
http://www.dronesvision.com/lawmate-1-2ghz-wireless-av-receiver-vrx-for-fpv-wireless-cctv-cameras/ (http://www.dronesvision.com/lawmate-1-2ghz-wireless-av-receiver-vrx-for-fpv-wireless-cctv-cameras/)
http://www.dronesvision.com/racewood-1-3ghz-500mw-wireless-av-transmitter-blue-label/ (http://www.dronesvision.com/racewood-1-3ghz-500mw-wireless-av-transmitter-blue-label/)
antene idu od IBCrazy-a (hvala Dr.Tom-u koji mi je dao par savjeta)
http://www.readymaderc.com/store/index.php?main_page=product_info&cPath=108&products_id=810 (http://www.readymaderc.com/store/index.php?main_page=product_info&cPath=108&products_id=810)
http://www.readymaderc.com/store/index.php?main_page=product_info&cPath=108&products_id=838 (http://www.readymaderc.com/store/index.php?main_page=product_info&cPath=108&products_id=838)
http://www.readymaderc.com/store/index.php?main_page=product_info&cPath=108&products_id=823 (http://www.readymaderc.com/store/index.php?main_page=product_info&cPath=108&products_id=823)
-točkovi (3 komada) promjera 7cm. http://www.hobbyking.com/hobbyking/store/__5613__Light_Foam_Wheel_Diam_70_Width_20mm_.html (http://www.hobbyking.com/hobbyking/store/__5613__Light_Foam_Wheel_Diam_70_Width_20mm_.html)
-nakoliko šarafa i matica m2 i m3, malo žice , vitroplast za podnicu i servo ruke, boja crvena i crna u spreju i nekoliko večeri za to poslagat.
evo i par slika;
(http://fodi.frubar.net/files/0532BD6A-B1A9-604E-878A-5E3E6DC6DB10_thumb.jpg) (http://fodi.frubar.net/files/0532BD6A-B1A9-604E-878A-5E3E6DC6DB10.jpg)
(http://fodi.frubar.net/files/5A19BB96-D194-5745-B369-784EBC687D98_thumb.jpg) (http://fodi.frubar.net/files/5A19BB96-D194-5745-B369-784EBC687D98.jpg)
(http://fodi.frubar.net/files/70E63054-3266-2645-A512-7CD3A8BFA205_thumb.jpg) (http://fodi.frubar.net/files/70E63054-3266-2645-A512-7CD3A8BFA205.jpg)
(http://fodi.frubar.net/files/4A814C98-1A62-F841-B37E-C3A5C60AFCD9_thumb.jpg) (http://fodi.frubar.net/files/4A814C98-1A62-F841-B37E-C3A5C60AFCD9.jpg)
(http://fodi.frubar.net/files/65EAB190-665C-194F-83AB-66FD1E350B9D_thumb.jpg) (http://fodi.frubar.net/files/65EAB190-665C-194F-83AB-66FD1E350B9D.jpg)
(http://fodi.frubar.net/files/568391C1-D76C-9A43-8981-47F96C50F7E3_thumb.jpg) (http://fodi.frubar.net/files/568391C1-D76C-9A43-8981-47F96C50F7E3.jpg)
(http://fodi.frubar.net/files/2E4DAAA1-0846-6B43-BA3D-1B7A719AD9C6_thumb.jpg) (http://fodi.frubar.net/files/2E4DAAA1-0846-6B43-BA3D-1B7A719AD9C6.jpg)
(http://fodi.frubar.net/files/DCDCB326-419A-4846-A952-02C8F02365EF_thumb.jpg) (http://fodi.frubar.net/files/DCDCB326-419A-4846-A952-02C8F02365EF.jpg)
(http://fodi.frubar.net/files/DC9FD140-98A5-324E-926B-B92568D0E4B5_thumb.jpg) (http://fodi.frubar.net/files/DC9FD140-98A5-324E-926B-B92568D0E4B5.jpg)
(http://fodi.frubar.net/files/A099FEC3-9E44-F848-B274-7CABBE14E93A_thumb.jpg) (http://fodi.frubar.net/files/A099FEC3-9E44-F848-B274-7CABBE14E93A.jpg)
(http://fodi.frubar.net/files/B1D118CB-EB38-0A44-B87C-53C333526D3D_thumb.jpg) (http://fodi.frubar.net/files/B1D118CB-EB38-0A44-B87C-53C333526D3D.jpg)
(http://fodi.frubar.net/files/1288D624-29C4-2C4D-B2E3-3FEBB4BB0820_thumb.jpg) (http://fodi.frubar.net/files/1288D624-29C4-2C4D-B2E3-3FEBB4BB0820.jpg)
(http://fodi.frubar.net/files/E3D4AAB4-11CF-F24D-9088-BA192F1C89D2_thumb.jpg) (http://fodi.frubar.net/files/E3D4AAB4-11CF-F24D-9088-BA192F1C89D2.jpg)
(http://fodi.frubar.net/files/52034810-9E61-1345-A14D-3579715FB63B_thumb.jpg) (http://fodi.frubar.net/files/52034810-9E61-1345-A14D-3579715FB63B.jpg)
(Powered by frubar.net)
Title: Odg: FPV Paraglider
Post by: Giga on February 22, 2013, 10:14:23 am
Pozdravljam projekt. S nestrpljenjem se ceka nastavak...  ;)
Post by: tonik on February 23, 2013, 06:45:06 pm
Cijevčice raspiljene, savinute i spremne za spajanje.
Neki nacrt sa mjerama nemam, radim onako od oka i otprilike.
Biti će dug i širok oko 50 cm, a visok oko 40 cm, za težinu još neznam točno ali negdje oko 1.5 - 1.7 kg.  RTF.
Počeo sa spajanjem i već pomalo poprima "look".
(http://fodi.frubar.net/files/D9E2F113-F170-4D45-97B1-159BC27970E0_thumb.jpg) (http://fodi.frubar.net/files/D9E2F113-F170-4D45-97B1-159BC27970E0.jpg)
(http://fodi.frubar.net/files/E0FF8F4B-018F-B141-A04A-305DD551B2B0_thumb.jpg) (http://fodi.frubar.net/files/E0FF8F4B-018F-B141-A04A-305DD551B2B0.jpg)
(http://fodi.frubar.net/files/5CD6F899-255B-0244-8CA8-1B0744CFA1AA_thumb.jpg) (http://fodi.frubar.net/files/5CD6F899-255B-0244-8CA8-1B0744CFA1AA.jpg)
(http://fodi.frubar.net/files/9E961523-5982-724F-BBA0-A4AC8925AE08_thumb.jpg) (http://fodi.frubar.net/files/9E961523-5982-724F-BBA0-A4AC8925AE08.jpg)
(http://fodi.frubar.net/files/D4BE75BA-FA44-7546-97CF-675A2B9CACB7_thumb.jpg) (http://fodi.frubar.net/files/D4BE75BA-FA44-7546-97CF-675A2B9CACB7.jpg)
(http://fodi.frubar.net/files/71251B20-D249-C346-98A2-B5ABCBFE33BE_thumb.jpg) (http://fodi.frubar.net/files/71251B20-D249-C346-98A2-B5ABCBFE33BE.jpg)
(http://fodi.frubar.net/files/6A285CE1-FC23-0F44-A285-F89DC10B9F47_thumb.jpg) (http://fodi.frubar.net/files/6A285CE1-FC23-0F44-A285-F89DC10B9F47.jpg)
(http://fodi.frubar.net/files/B715A313-D271-EC40-8B48-FC624E0A5318_thumb.jpg) (http://fodi.frubar.net/files/B715A313-D271-EC40-8B48-FC624E0A5318.jpg)
(http://fodi.frubar.net/files/DF4FF776-43D6-9C43-B38E-96186545DC68_thumb.jpg) (http://fodi.frubar.net/files/DF4FF776-43D6-9C43-B38E-96186545DC68.jpg)
(http://fodi.frubar.net/files/2D4F54C0-E917-184C-B1BA-7E411FEAD55A_thumb.jpg) (http://fodi.frubar.net/files/2D4F54C0-E917-184C-B1BA-7E411FEAD55A.jpg)
(http://fodi.frubar.net/files/8C66ED21-A92F-EB45-A0FC-40B97CFF2359_thumb.jpg) (http://fodi.frubar.net/files/8C66ED21-A92F-EB45-A0FC-40B97CFF2359.jpg)
(http://fodi.frubar.net/files/8A40400B-5DB4-0740-B215-7771B2ACAB90_thumb.jpg) (http://fodi.frubar.net/files/8A40400B-5DB4-0740-B215-7771B2ACAB90.jpg)
(http://fodi.frubar.net/files/750D3E64-52F8-BB4B-8B6C-22CA4E31E06F_thumb.jpg) (http://fodi.frubar.net/files/750D3E64-52F8-BB4B-8B6C-22CA4E31E06F.jpg)
(http://fodi.frubar.net/files/73E0A1AD-7121-5D46-A818-52CBEC3F16DD_thumb.jpg) (http://fodi.frubar.net/files/73E0A1AD-7121-5D46-A818-52CBEC3F16DD.jpg)
Post by: Jarun75 on February 23, 2013, 07:09:48 pm
S kojim matrijalom si hardloto ovako aluminij?
Da li s aluminijem ili nekim drugim materijalom jer vidim da dobro se spaja makar je eloxirani.
Post by: tonik on February 23, 2013, 10:46:55 pm
Sa "Durafix" štangicama.
Stavio sam link gore di se može nabavit  ali evo još jedanput
Imaš i na ebay-u jeftinije.
Prije nego počneš spajat prođeš aluminij sa čelič. četkom,  kad se počne topit štangica dobro je proć još koji put.
Aluminij kojeg spajaš mora biti dovoljno zagrijan da kad makneš brener sam otopi
štangicu (to je ispravan i najači spoj ).
Inače sami spoj je jači i tvrđi nego aluminij kojeg sam spajao ( provao savijat ali spoj ne mrda).
Post by: kbelcar on February 24, 2013, 02:54:34 am
Bravo :)
....using tapatalk....
Post by: tonik on February 24, 2013, 09:55:54 am
Pošto je krilo bilo namjenjeno za "4 lines power kite" morao sam sve špagice promjenit i drugačije zavezat (tako da nije skroz ravan u zraku već da bude malo zaobljen kao pravi paraglider),
i da na livadi mogu natrimat  sami kut krila.
To je jedino što me muči sada (nebi volio da je prebrz u zraku i da moram cijelo vrijeme vozit skoro pun gas).
Maloprije sam ga provao na vjetru i mogu reć da solidno stoji u zenitu i dosta vuče gore.
(http://fodi.frubar.net/files/50AB8F47-BFC2-DF4D-BEFF-C855DC2DDF7D_thumb.jpg) (http://fodi.frubar.net/files/50AB8F47-BFC2-DF4D-BEFF-C855DC2DDF7D.jpg)
(http://fodi.frubar.net/files/05555C88-E9A6-B041-BBC7-173AC827D63C_thumb.jpg) (http://fodi.frubar.net/files/05555C88-E9A6-B041-BBC7-173AC827D63C.jpg)
Svaka sugestija je dobrodošla  :)
Post by: miso227 on February 24, 2013, 10:28:26 am
svaka cast na na radu kolega.
Post by: tonik on March 04, 2013, 09:05:44 pm
Malo se radilo ovih dana i skoro bi mogao biti "maiden flight"  :)
Još je ostalo malo za napravit ali nikako uhvatit vremena.
Evo kako sada izgleda:
(http://fodi.frubar.net/files/4C9698B8-4A0D-BB49-8AB6-EAF2BA842220_thumb.jpg) (http://fodi.frubar.net/files/4C9698B8-4A0D-BB49-8AB6-EAF2BA842220.jpg)
(http://fodi.frubar.net/files/6AC4E49B-DA33-084E-9991-9E77D908CE93_thumb.jpg) (http://fodi.frubar.net/files/6AC4E49B-DA33-084E-9991-9E77D908CE93.jpg)
(http://fodi.frubar.net/files/5FCE02B0-6453-DD45-BC44-9E856486BDEE_thumb.jpg) (http://fodi.frubar.net/files/5FCE02B0-6453-DD45-BC44-9E856486BDEE.jpg)
(http://fodi.frubar.net/files/E241483F-A50F-9749-8618-DE13C20E4B51_thumb.jpg) (http://fodi.frubar.net/files/E241483F-A50F-9749-8618-DE13C20E4B51.jpg)
(http://fodi.frubar.net/files/081E5E1A-4436-F64D-B8E5-3628ACDDEE7B_thumb.jpg) (http://fodi.frubar.net/files/081E5E1A-4436-F64D-B8E5-3628ACDDEE7B.jpg)
(http://fodi.frubar.net/files/9F0F19A3-4185-A246-BA9F-63A5379AFD91_thumb.jpg) (http://fodi.frubar.net/files/9F0F19A3-4185-A246-BA9F-63A5379AFD91.jpg)
(http://fodi.frubar.net/files/B3F68296-9045-A643-B395-82047A2C929B_thumb.jpg) (http://fodi.frubar.net/files/B3F68296-9045-A643-B395-82047A2C929B.jpg)
(http://fodi.frubar.net/files/40697CC6-0CEE-8D46-9D93-2E139A2AA958_thumb.jpg) (http://fodi.frubar.net/files/40697CC6-0CEE-8D46-9D93-2E139A2AA958.jpg)
(http://fodi.frubar.net/files/A1AC9C8E-C946-3A40-AE21-6E58F0AD0BD9_thumb.jpg) (http://fodi.frubar.net/files/A1AC9C8E-C946-3A40-AE21-6E58F0AD0BD9.jpg)
(http://fodi.frubar.net/files/30BD8287-5B85-C84C-96CD-B6BC06551109_thumb.jpg) (http://fodi.frubar.net/files/30BD8287-5B85-C84C-96CD-B6BC06551109.jpg)
Post by: Toki on November 12, 2013, 10:11:18 pm
Što je s ovim, jel poletilo to?
Post by: tonik on November 13, 2013, 09:39:57 am
Poletio je ali nije dugu trajao let  :'(
Motor je malo slab, za letuckanje bi prošao ali kod jednog preleta zakačio sam sa gondolom vrh stabla (dao sam gas na full ali jednostavno motor nije imao više snage) i u trenu dobio "gnjezdo" na stablu  :(
Da bi stvar bila još i gora više od pola špagica je isječeno nešto od motora a nešto od mene da bi ga skinuo sa stabla.
Jači motor sam nabavio još prije ljeta, međutim počela je sezona i nije se više imalo
vremena  :(.
Sad je druga priča , čim završim par projekta koje sam započeo vraćam se na ovo.
Na gondoli ću napravit isto neke preinake jer je malo prevelika.
Post by: Toki on November 13, 2013, 11:56:37 am
Hvala na informacijama, sretno.
