Hobbyking X900 Tricopter Glass Fiber Multi-Rotor Frame
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=28496&aff=448825 (http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=28496&aff=448825)
Da zapocnem novu temu, dugo sam planirao jednog tricoptera ali nije bio veliki izbor frejmova i repni mehanizam nije bas jednostavan.
Talon mi se svidjao ali je bio mali i dosta skup, nedavno je HK izbacio jedan prihvatljive cijene i odlucio sam i to isprobati.
HK info
Designed from the ground-up by our own engineering team, the X900 Tricopter is a culmination of months of design, testing and material sourcing to provide you with the perfect mix of quality, performance and value. The X900 Tricopter frame is a Hobbyking exclusive meaning you won't find it anywhere else!
The X900 features a very nicely finished glass fiber main frame, shock-absorbing landing legs and folding aluminum arms. The shock-absorbing landing legs are a great feature to handle those rough landings that we all have from time to time.
The integrated tail servo mount is constructed of glass fiber as well, allowing you to mount your favorite micro/mini tail servo for yaw control. The rear motor mount pivots on a dual ball bearing supported shaft providing super smooth and precise movement. As a result, the yaw control is locked-in and very precise while flying.
We offer a full line of multi-rotor electronics such as multi-rotor control board, ESC, motors and more, so it has never been easier or more affordable to get your multi-rotor frame in the air!
All necessary hardware is included. Simply add your own electronics.
Specs:
Front Arm Lengths: 420mm (boom base to motor shaft center)
Rear Arm Length: 450mm (boom base to motor shaft center)
Motor Bolt Holes: 16/19/25mm
Frame Weight: 385g (w/out electronics)
Required:
28-XX or 35-XX brushless outrunner motor x 3
25~40A brushless ESC x 3
High speed micro/mini servo for the tail (digital servo recommended)
10~12 inch propeller (2 standard/1 reverse rotation)
Multi-rotor control board
2650~3300mAh 11.1V lipoly
4CH Transmitter & Receiver
X666 je bio zrtvovan za dijelove
Kabl za struju za tricopter mi je napravio 4tm i ovim putem mu se posebno zahvaljujem.
Servo za rep
TGY-306G Ultra Fast/High Torque MG Digital Alloy Cased Servo 3kg / .06sec / 21g
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=22687&aff=448825 (http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=22687&aff=448825)
TGY-306G Ultra Fast/High Torque MG Digital Alloy Cased Servo 3kg / .06sec / 21g - Excellent 450 Heli & 3D servo.
Model: TGY-306G
Operating Voltage: 4.8V / 6.0V
Operating Speed: 0.07sec.60º/ 0.06sec.60º
Stall Torque: 2.4kg.cm /3.0kg.cm
Weight: 21g
Motor: 12mm Coreless
Potentiometer: indirect Drive
Ball bearing: Top Ball Bearing
Gear: Metal
Case: Aluminum
Connector wire: 220mm
Plug: JR/Universal
Sta se dobije u kutiji
Naravno gore ide KK2
Slikice sastavljanja
spajanje prijemnika
spoj na plocicu iz bliza
spajanje i testiranje repa
njezni thread lock
TL-680 Thread Locker & Sealant Low Strength
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=19067&aff=448825 (http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=19067&aff=448825)
Sastavljen
vaganje
825 g
plus 1 2200 3s 1005g
na kraju ce ici jos jedna baterija i mozda ponekad gopro
Trakice za ucvrsitit bateriju
Scorpion Lipoly Lock Strap 205mm (Small) x 3
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=17410&aff=448825 (http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=17410&aff=448825)
vece koristim na HEXi i koristio sam na X666 i do sada nisam nasao kvalitetnije
Pilot
kasnije idu gore loptice i led
Probno paljenje na podu
http://www.youtube.com/watch?v=ple1zGIhULM (http://www.youtube.com/watch?v=ple1zGIhULM)
Maiden
vani je ispod nule i vjetar
http://www.youtube.com/watch?v=EkRfiHtFjW4 (http://www.youtube.com/watch?v=EkRfiHtFjW4)
2 baterija
nakon toga su mi se prsti vec smrzli i nisam dalje stelovao
http://www.youtube.com/watch?v=EEwkqhn1708 (http://www.youtube.com/watch?v=EEwkqhn1708)
Lijepo 8)
ajd sada preseli motore s hexe pa probaj u Y6 formaciji.
ne treba ti ni servo mehanizam, ukrutiš ga da bude fiksiran u 'nuli'
pa javi kako leti.
tj. koliko kraće nego hexa s istim setupom.
Lijepo 8)
pa javi kako leti.
Pratim ja raspravu o ekonomicnosti/neekonomicnosti Y6 setupa,
ali i sam znas da omjer tezine/potiska/potrosnje jako ovisi od kombinacije motor elisa i moguce je dobiti svakakve rezultate.
Na papiru 3 je ekonomicniji u praksi ovisi.
Jedna baterija na 3 mi se mucila, na quadu ne bi ni letjela, s dvije ima struje na bacanje,
quad moze poletljei s 5 baterija pa letjeti duze.
Jos ako se poigramo s 3s 4s ...
Evo i dyno od mojih motora,
rezultate s 10x4.5 sam stavio ma x666 thredu i do odredjene amperaze stedljiv nakon granice ima snagu ali trosi daleko vise.
Imam jedan od 750kv motor i tek na 4s ima pravu snagu i stedljiv je, ispao pre slab za quada a na papiru bolje 750 nego 1200.
Moji modeli vrlo brzo postaju pre teski pa me izvaci malo vise snage.
čestitke na uspješnom maidenu
Hvala, da nije uspjelo dijelovi bi se vratili na provjereni X666,
ovako mogu dalje testirati, jos malo da ga umirim i da vrijeme se poravi i ide testiranje kakav je za snimanje.
Čestitke Srepfler...hvataš mu karakter ::)...ja sam laik za ovu kategoriju,ali držim da se treba pomučiti,,kao i za sve što vrijedi ;)
Lp
Odlično izgleda,i lijepo je sve poslikano :)
Lp
Aktivni rep mi je novost pa sam pazio da to radi kako treba, treba ga ustelati kao i quad plus stelovanje repa,
mixer editor mi je prije bio visak a sada je gotovo obavezan.
Ti si jedini koji je javno pokazao interes. :)
Moze...
Jel to ovaj triki novi projekt?
put okvira i naravno zapeo na carini
ITEM n° CP271947190CN new search
Local Date and Time Country Location Event Type Extra Information
2/27/2013 3:48:00 PM CHINA 518029 Receive item from customer
3/6/2013 6:46:00 AM SWITZERLAND ZURICH 59 Insert item into bag
3/7/2013 10:45:00 AM CROATIA ZAGREB 10003 PI Receive item at office of exchange (Inb)
3/7/2013 1:18:00 PM CROATIA ZAGREB 10003 PI Send items to domestic location_1
3/8/2013 7:06:00 AM CROATIA 31004 Osijek CAR Record item customs information
Retention reason : Awaiting presentation to customs commissioner
3/8/2013 7:06:00 AM CROATIA 31004 Osijek CAR Send items to customs1
3/12/2013 8:48:00 AM CROATIA 31004 Osijek CAR Return items from customs 1
3/12/2013 12:21:00 PM CROATIA 31004 Osijek CAR Return items from customs 1
3/12/2013 7:59:00 PM CROATIA 31200 Osijek KRT Receive item at location
3/13/2013 12:59:00 AM CROATIA 31200 Osijek KRT Send item to domestic location
3/13/2013 6:51:00 AM CROATIA 31550 Valpovo Receive item at delivery office
3/13/2013 4:20:00 PM CROATIA 31550 Valpovo Deliver item SIGNED BY : MARKO SREPFLER
servo i par sitnica
ITEM n° RQ158165394SG new search
3/9/2013 3:07:00 PM SINGAPORE SINGAPORE SO5 Receive item at office of exchange (Otb)
3/9/2013 3:07:00 PM SINGAPORE SINGAPORE SO5 Insert item into bag
3/19/2013 2:47:00 PM CROATIA ZAGREB 10003 Receive item at office of exchange (Inb)
3/19/2013 6:02:00 PM CROATIA ZAGREB 10003 Send item to domestic location
3/20/2013 9:09:00 AM CROATIA 31004 Osijek CAR Return items from customs 1
3/20/2013 8:26:00 PM CROATIA 31200 Osijek KRT Receive item at location
3/21/2013 2:07:00 AM CROATIA 31200 Osijek KRT Send item to domestic location
3/21/2013 3:21:00 AM CROATIA 31200 Osijek KRT Send item to domestic location
3/21/2013 7:41:00 AM CROATIA 31550 Valpovo Receive item at delivery office
3/21/2013 1:57:00 PM CROATIA 31550 Valpovo Unsuccessful item delivery attempt
Reason : Addressee not available at time of delivery
Measure : Item being held, addressee being notified
3/21/2013 4:33:00 PM CROATIA 31550 Valpovo Deliver item SIGNED BY : MARKO SREPFLER
baterija nije bilo? ??? ???
Moze...
Posto sam nov u ovom hobby-u dosta toga me zanima,i lijepo je sve to vidjeti na jednom mjestu...
Konkretno me zanimalo na trikiju taj rep,kako radi mehanizam...Vi ste to super poslikali sa svih strana i odlicno se vidi.
Istina je da slika govori vise od tisucu rijeci :)
prvi paket samo okvir 998g paket
u drugom mala od 650 2s
Part 1/3
http://www.youtube.com/watch?v=Vs5q4_iJdEA (http://www.youtube.com/watch?v=Vs5q4_iJdEA)
Super je :)
Dosta je velik.
Super je :)
Dosta je velik.
Da se fino sklopiti za prijenos.
No u biti mozes staviti i krace i duze sipke, to su cetvrtaste cijevi s 2 rupe za motor mount i dvije za spoj na okvir.
Steta sto ne prodaju odvojeno od sipki jer zbog tih sipki paket je dugacak i ide visoka postarina, skoro kao i sam okvir.
Your order details are:
1x #9171000157/28496 Hobbyking X900 Tricopter Glass Fiber Multi-Rotor Frame = $26.99
Paypal or Credit Card (Amex / Visa / Mastercard) $0.00
ChinaPost Air Parcel No Lipo $25.02
Part 2/3
http://www.youtube.com/watch?v=m_KxCvEzVic (http://www.youtube.com/watch?v=m_KxCvEzVic)
Lijepo to leti, kao i svi tvoji multiji , svaka ti slanina.
Evo jedan jos bolji
2x 2200 za mene prava mjera
http://www.youtube.com/watch?v=nSI7_4ueZoY (http://www.youtube.com/watch?v=nSI7_4ueZoY)
no Servo je pre slab i odradio je svoje, morat cu nabaviti veci i jaci,
mozda da je tri laksi ali moj je 1.2-1.3 kg s dvije baterije.
Pa sada imam rastavljen X666 djelovi isli na tri
rastavljen tri zbog serva
hexa odspojena ( testiram nesto)
nema mi druge nego malo avione furat, sbach je prvi na listi
riknut servo
tri je citav
KK2 leti i s najjeftinijim servom,
koliko dugo to je vec druga prica.
Cross post ( 4tm hexa)
http://www.flyfreak.net/multirotor/six-glass-fiber-hexcopter-frame-600mm-moja-prva-hexa/msg112915/#msg112915 (http://www.flyfreak.net/multirotor/six-glass-fiber-hexcopter-frame-600mm-moja-prva-hexa/msg112915/#msg112915)
http://www.youtube.com/watch?v=Ah3U_iv9UIQ (http://www.youtube.com/watch?v=Ah3U_iv9UIQ)
Haj Marko,plesao si kao Nurejev u najboljim danima...naprijed Valpovo... ;) :)
Trebalo mi je da skuzim post. :) ;)
A što ja znam...držim da je tricopter muškog roda,pa sam ga krstio kao najvećeg baletana svih vremena i prebjega iz SSSR-a ,u ono vrijeme,......za taj poduhvat trebalo je imati ''muda''.....pozdrav...mislim da bi D pomogla...Oboje primite pozdrav...Ciao ;)
flight time s 2x 2200 3s
baterije su vec odsluzile svoje ( puno punjenja)
http://www.youtube.com/watch?v=4PVRxapFbYU (http://www.youtube.com/watch?v=4PVRxapFbYU)
E Markec,ovo je bilo nježno,i da ostanem u tonu,kao Maja Plisickaja u najboljim godinama :)...Pozdrav obitelji ;)
Hvala, kao jednom od rijetkih koji se aktivno javlja evo jedan video s testiranja kakav je za snimanje
http://www.youtube.com/watch?v=KqHHXJ_5zHg (http://www.youtube.com/watch?v=KqHHXJ_5zHg)
Meni se sviđa uradak...slika čista i mirna ,krajolik fenomenalan,jedino ''D'' nema posla ...nadam se da stiže veliki 3D,pa će ona opet u prvi plan...nisam nikakav znalac ali moram nabaviti nešto slično ,o tome će mo razgovarati.Velik i Lijep pozdrav iz Splita :)
Bit ce i veliki 3D, ali idem redom, jedno od pravila je da lako stane na zadnje sjediste, neke modele sam rijetko letio bas zbog previse posla da se spakuju,
moram jos malo testirati kako modeli s tockovima podnose moja slijetanja u polje, koristim tehniku stall pri maloj visini da se ne kotrlja previse a opet da se ne nagne na stranu.
Tri se pokazao jako zgodan za ponijeti, moze se sklopiti i nositi u ruci,
osim osjetljivog repnog mehanizma ne vidim neke druge mane a prilicno zabavan.
Da Marko , propozicije stoje , ni sam nisam letio velike IC modele radi osobnog komoditeta, i pripreme prije, a čiščenja poslije letenja,tako da sam više montirao i čistio nego letio.Na kraju sam prešao na E-drive , a samo ostavio IC Cessnu 182 ,1700 mm(iz sentimentalnih razloga), a svi drugi su elektro.Još moram nabaviti quadro ili tricopter FPW , pa sam miran.
LP
Prava je steta sto je interes za tri copterima slab, ima nesto u nacinu kako lete,
evo jos jedan pokusaj da nagovorim da i drugi naprave koji.
http://www.youtube.com/watch?v=5u9K-XTdkKU (http://www.youtube.com/watch?v=5u9K-XTdkKU)
ovo sam otisao kod kolege u blizini, u jednu ruku tri ruksak s baterijama i stanicom i prosetao, vrlo prakticno za ponjeti i malo letuckati,
cak i za neka pocetnicka snimanja cisto ok, pogotovo ako ne piri vjetar.
sklopljen izrazito kompaktan
1.6 gore
Rjesenja s lopticama se siri i postaje prihvaceno,
jedino je njihova ljepsa nije raznjic nego carbon.
1.6 u akciji
http://www.youtube.com/watch?v=appQgsWp7b8 (http://www.youtube.com/watch?v=appQgsWp7b8)
vidio sam ti video kod hk, super izgleda!!
i ja razmisljam jel da si napravim koji tricopter jel jos jednog quada. imam hexu i quick n dirty quada ovdje a zelim nesto jace i brze :P
jel ti se ne trese zadnji motor?
Servo stalno nesto radi pa izgleda kao da motor trese, orginal motor mount je los pa mi je 4tm napravio posteni.
Ovako izgleda motor mount kada ga pravi majstor napravi ( Hvala 4tm )
prednje jos nisam zamjenio.
evo jedan od boljih
http://quaternium.es/product.php?id_product=1 (http://quaternium.es/product.php?id_product=1)
evo jedan od boljih
Odlicno izgleda, nisam znao za taj,
ja sto sam prije nasao bilo je ili fali sipke ili puno skuplje,
ovaj stavljen kao iduci ako skrsim x900.
Ako imas jos koji takav stavi link u mojim pretrazivanjima ocito sam preskocio Spanjolsku.
Ja sam ga uzeo dosao na vrata za 10 dana vrijedi svake kune. Servo odlicno zasticen, mjesta za sve jedino je malo stisnuto doci do kk2.
Moze slikica, video u letu ili ako imas volje napravi thread build log review, ja sam se nagledao na rcgroups od tricopter yaw mehanics na dalje a eto promakao mi krasan okvir,
pricekat cu jos taj mjesec dana da carina ne zeza i nabavljam jednoga.
To majstore,
odlicno si rijesio ledice,
rep rjesenje mi se svidja,
uskoro ide kk2 s odvojenim lcd za podesavanje tako da stima da je zasticen, mozda bude dostupan i revolution od openpilot ( taj bi rado probao).
Stanu li 2 baterije tj koja je max velicina?
Nabavljam, planiram probati mozda i druge motore,
koje je max velicina propa, vidim da je 10" preporuceno.
Ja imam gore 11x4,7 evo slika sa rhino 2250 za usporedbu inace bez problema gore stane 3s 4500
@sasapu hvala na odlicnim slikama,
jos ako imas flight video i mozda video kako izgleda snimak s tvog tri ( ipak je predvidjen za gopro),
cijena prihvatljiva i jos dolazi polu sastavljen odlican.
Bit ce jos trikija, meni se svidja kako leti.
Evo i jedan moj video gdje sam natovario 3 x 2200 3s samo da vidim hoce li podici.
http://www.youtube.com/watch?v=FX4XUMSoqpQ (http://www.youtube.com/watch?v=FX4XUMSoqpQ)
super! porucujem!! koje motore imas, i kako leti? jel dosta jak tako? kolko dugo sa kojom baterijom iiii kolko je tezak?
hvala
hvala
Motori NTM 1200 imas u video description linkove
Meni leti odlicno
Oko 3 kg potiska na maks gasu
1 baterija previse motori vuku no ako bi stavio 9x4.7 s kojima je quad letio 8 tko zna,
iz nekoga razloga ni quad ni tri mi s carbon 9x4.x ne lete dobro a vole plasticne 9x4.7
s 2 x 2200 10-12 min
s 3 x samo malo duze 14-15 u biti ne isplati se 3
ali s 2 x 2200 i gopro moze 10- min
Tezina
825 prazan
i na to 200q po bateriji
100g gopro
1200-1400 g
ah znaci te motore. malo su slabi za 10 cola jelda? ima kolega na quadu i griju se dosta sa 10'', sa 9 ide dobro.
i jos nesto, sorry ako te maltretiram. kolko je tezak od prilike? sa svim bez gopro
** edit: aha, bio si brzi od mene. hvala puno!
Da 10" je preko preporucene vrijednosti,
no ti motori su se vrtili na quadu danima s 10", sada su na tri,
na hexi 6 komada isto 10",
ne kazem da je to dobro ali 9" carbonci mi ne valjaju, 9" plasticni mogu lako puci,
10" imaju snage i leti mirno.
Quad sam letio s 4 x 2200, hexu s 5 x 2200 i s 10" imaju snage.
Vecina ih vrti s 8" ali na lakim quadovima.
1000 kv bi mozda bio bolji za 10" ali ja volim ove.
KK2 1.6 fw snimka s letjelice
http://www.youtube.com/watch?v=WAjpq0yOK1A (http://www.youtube.com/watch?v=WAjpq0yOK1A)
Konačno video iz zraka :-*
:) Novi u pripremi,
danas oblacno, kisa samo sto ne pljusne a meni vrag ne da mira pa tricopterom visoko.
Evo i jedan kratki s problemom u letu, kontakt, senzor, motor?
http://www.youtube.com/watch?v=IUWMZwAxZNk (http://www.youtube.com/watch?v=IUWMZwAxZNk)
Antena na stanici, držiš ju u najgorem mogućem položaju. Drži ju preklopljenu sa strane ili preklopljenu prema gore.
Preklopljena prema dolje je JR preporuka.
Na internetu najbolji savjet je da vrh antene nije prema modelu pa ovisno kako se leti i kako se drzi.
Dolje na stranu je jedna od preporuka,
novi modeli imaju u stanici tako da vise ne mozes birati,
kod modularnih dio smjerova je blokiran,
neki moduli idu samo gore.
Srecom JR mi ima u svakom prijemniku ( i zamjenskom) minimum telemetriju voltaza na prijemniku i
alarm mi pisti kada se izgubi,
telemetrija se puno ranije gubi tako da je to rano upozorenje ali ne i RSSI.
frsky to ima odlicno rjeseno pisti i jos mislim da varira brzina pistanja kod slabog signala.
Ako misliš na onaj brzi trzaj pred kraj, takvo što se znalo i meni na quadu povremeno dogoditi i sa 1.5, a dogodilo se jednom i sa 1.6 verzijom firmwarea. Mislim da to nema veze sa položajem antene jer ti je trikopter bio svega nekoliko metara udaljen, gdje je polje stanice (odašiljača) dosta jako pa položaj antene ne bi trebao imati preveliki utjecaj, a i kod mene se to događalo i na malim udaljenostima s tim da ja uvijek držim antenu presavijenu u stranu. Prije da se radi o firmwareu jer taj Atmelov mikrokontroler na KK2 dosta toga vrti i procesira, moguće je da kod izračunavanja negdje zapne pa ga jednostavno vremenski interrupt izbaci iz rutine i zato dolazi do takvog trzaja dok ponovo ne obradi informacije sa senzora. Inače dosta programiram mikrokontrolere pa mi je to logičnije objašnjenje od položaja antene. Trebalo bi možda pogledati na stranim forumima da li se netko žalio na takav slučaj i kakvo je objašnjenje. Srećom nakon tih trzaja nije bilo posljedica u obliku padova i sl.
Varadero me zeza za polozaj antene, nije mislio da je to uzrok,
atmel stekanje je moguce.
Ide uskoro novi KK2 s kucistem pa cu isprobati i taj.
E Marko, onda je ipak ono na šta sam prvo pomislio.
Nisi popio rakijicu ujutro pa ti prsti drhte :D
Zato i cesce letim kod punca u dvoristu, ovo je bila trijezna lokacija.
Gledao sam malo jos rasprava i uputa za polozaj antene,
na stranu je slabo ako dolazis s krive strane antene,
prema gore ne valja ako letis iznad visoko,
prema dolje nije za FPV ako letis iza sebe,
ravno gore najlosije ako si okrenut vrhom prema modelu,
e sada znaj kako okrenuti,
u kofer ide samo ravno gore,
na modelu nemam satelite ( navodno je spectrum medju zadnjima koji jos to koriste ili jedan od rijetkih).
Ostali proizvodjaci rijetko navode polozaj antene.
Na zemljanom range testu najdalje dobijem s ravno gore, no u zraku je druga prica.
Na kraju imam samo jedan orginal JR na hexi, a na ostalima malesni 4ch parkflayer ili 6ch ADMS isto parkflayer koji je na tricopteru.
Dopisivao sam se s proizvodjacem klonova u vezi novog DM9F koji je full range, kazu da nagovarju HK za prodaju i da su prvi primjerci napravljeni,
ali se jos nigdje ne moze kupiti.
HK jos ne nudi ni DM6F 6 ch nego samo 4 ch DM4F malesnog ali po prihvatljivoj cijeni ( ti su mi na Zagi XL i Zagi EDF i ...)
Jucer sam malo testirao flight time s 9x4.7 ( plasticni) s kojima moze letjeti i sa samo jednom baterijom,
pa onda s dvije.
Jedna - 7 min pre kratko
Dvije - 12 malo duze nego 10x4.5
vratio 10x4.5 bolje mi je
iz nekoga razloga 9x4.7 rc timer carbonce ne voli a 10" mu skroz stimaju
Malo sam trazio po webu pa nasao jos jednu tablicu za NTM 1200
http://www.youtube.com/watch?v=xheroJ6Yrq4 (http://www.youtube.com/watch?v=xheroJ6Yrq4)
Danas cijeli dan kisa,
navecer popustilo ali vani mrak,
sta cu stavio ledice i letim.
[attachimg=2]
Meni je i najveci gušt letiti po noći, kad stavis ledice, puno ga bolje vidis nego po danu, a i nema dosadnih prolaznika sa zašto i kako pitanjima
:) :D
Trebao bi jednom prijeci na gimball,
ali za moju zabavu i ovako ide.
[attachimg=3]
ujedno sam i probao youtube stabilize i razvlaci sliku kao zvaku ( za iz blize)
http://www.youtube.com/watch?v=xG4LOPfqtrg (http://www.youtube.com/watch?v=xG4LOPfqtrg)
Ajmo gimbal na hexu i u zrak, da malo uživamo u snimkama ravne nam slavonije ;D
jos malo letuckanja
http://www.youtube.com/watch?v=Z0dZIeV9viI (http://www.youtube.com/watch?v=Z0dZIeV9viI)
Marko evo nešto za Tebe...ako nisi vidio... 8)
Flite Test - Tricopter vs Quadcopter - Viewer Response (http://www.youtube.com/watch?v=sMuu3EUqitM#ws)
Hvala za video,
ja volim tri iako su ipak malo problematicni, H quad je u planu,
od danas ponovo vozim quad x666, x900 vratio posudjene dijelove sa x666,
ima jos neobjavljenih/neobradjenih videa od x900, no bit ce novih od x666.
Htjeo bi jos probati octu i naravno vece i jace motore te jako jako velike elise a i trokrake me svrbe,
danas narucio drvene cisto za probu da vidim da li bolje upijaju vibracije.
Jednog dana mozda tri copter s 15"-17" elisama rasklopivi.
Sto se tice mirnoce i pouzdanosti HEX je do sada najbolja, no zabava u letenju je vise na strani tri,
quad je opet uvjerljivo najlaksi za napraviti.
Da shvatio sam odavno ,kada si Ti u pitanju,IZAZOV je Tvoja najvažnija pokretačka snaga...i to imponira... 8)
Procitao si me, cim nesto proradi vec smisljam sta bi novo probao,
kako si jedan od rijetkih koji komentiraju za tebe jos dva neobjavljena,
ima jos ali nije obradjeno.
proba letenja s 9XR
http://www.youtube.com/watch?v=xavm3S4xWME (http://www.youtube.com/watch?v=xavm3S4xWME)
cisto da usporedim
te let s lampicama
http://www.youtube.com/watch?v=mpqGmuzXO-Q (http://www.youtube.com/watch?v=mpqGmuzXO-Q)
pozdrav i hvala na javljanju.
drugi propovi za probu
http://www.youtube.com/watch?v=1hrCToslh9o (http://www.youtube.com/watch?v=1hrCToslh9o)
jedan video s istim motorima ( Flitetest anycopter)
http://www.youtube.com/watch?v=MrvNvpMQctE (http://www.youtube.com/watch?v=MrvNvpMQctE)
Triki izgleda moćno na nebu... :)
Ovih dana slažem si quad a nakon toga na redu je jedan triki.
Slavonska ekipa rastura :-*
Trebalo bi izmislit dual triki, rasklopivi, tako da kad ideš s frendom letit svako leti svoj triki, a kad treba nešto recimo snimiti 2 trikija se sklope u hexu i prebaci se u hexa mod i onda se ide s tim u zrak. 8)
Ima smisla... :)
