Post reply
Something happened, review it here:
  • Warning: this topic has not been posted in for at least 120 days.
Warning! This topic is currently/will be locked
Only admins and moderators can reply.
shortcuts: alt+s submit/post or alt+p preview
Attachments and other options
Add files by dragging & dropping or selecting them Add files
Attach:
(Clear attachment)
(more attachments)
Allowed file types: doc, gif, jpg, mpg, pdf, png, txt, zip
Restrictions: 15 per post, maximum total size 8,192 KB, maximum individual size 2,048 KB
Note that any files attached will not be displayed until approved by a moderator.
Topic Summary
Posted by mlilasic - July 28, 2016, 05:51:38 pm
i
[emoji3][emoji6][emoji41]
Posted by DJDarky - February 03, 2016, 04:15:13 pm
Od sutra folija na aciji. Nekad imaju i one tanke, neznam kakva će sutra biti pa ako nekom treba... ;)
http://www.lidl.hr/hr/2635.htm?action=showDetail&id=27835
Posted by Elav - January 13, 2016, 11:31:59 pm
Sutra nova akcija alata.
http://www.lidl.hr/hr/2635.htm?id=606
-kutna brusilica s regulacijom o/min po smiješnoj cijeni od 230 kn
-vertikalna glodalica
.....itd
Posted by DJDarky - January 07, 2016, 09:23:36 pm
Danas sam u Lidlu naletio na vakum-vrečice, 90x120 košta 20kn. Vidim da dosta ljudi vakumira krila i sl. pa ako nekom treba...
Posted by Toki - December 02, 2015, 09:13:38 pm
Uh ja vidim već 5 stvari koje budem uzeo :D
Posted by DJDarky - December 02, 2015, 05:15:26 pm
Možda si sutra netko nešta neđe u Lidlu, ja sigurno hoću. Osto sam bez ljepljive trake, pa povečalo a možda si i metlu kupim da si mogu pomesti radionicu :D :D
http://www.lidl.hr/hr/2635.htm?id=579
Posted by rubazg - June 11, 2015, 03:39:12 pm
dakle sljedeći tjedan imate u lidlu treking cipele, prošle godine sam si kupio i testirao na najjače, u praoni, po snjegu, vodi... odlične su a koštaju 179kn, netko ko ih nebude testirao kao ja bit će još zadovoljniji od mene, preporučujujem svakom
Posted by novizagi - April 14, 2015, 11:44:13 am
ja sam uzeo pred ca godinu dana takvu vrstu od einhella, isto ca 350 kn, za usisavati blatnu vodu (pranje podruma), i kasnije usisavanje prašine u šupi na viksi
uglavnom, stvar je šljakala ko grom
o dugotrajnosti ne mogu govoriti
onaj "filter" od spužve sam naravno odmah potrgao kod montaže, ali ništa što malo duct tape-a nije sredilo :)
za neku "hobi industrijsku namjenu" mislim da će biti odličan, samo uzmi u obzir ovo s vodom, da ju imaš blizu (a imaš ju)
Posted by gogy - April 14, 2015, 10:15:04 am
Ako je od parksidea ja ga imam več 3 godine i otišao mi je filter pa imam najlonsku duplu čarapu na njemu i oko 2 litre vode i ne štedim ga nikako. peri-deri. jedina mana kaj moraš stalno mijenjat vodu jel se usmrdi- pa smrdi kad ga upališ ali inače sve pohvale. od prašine knaufa, autokita, farbe i inih gluposti. šlajferica rupes i parkside.
Kaj se tiće utičnice imaš na njemu utičnicu u koju ide utikač od šlajferice pa se pali usisivač čim upališ šlajfericu a kad ugasiš šlajfericu usisivač radi još nekih par sekundi i automatski se gasi..
Posted by boha - April 14, 2015, 09:51:51 am
Ja san zadnje od alata u njih uzea onaj "industrijski" usisavac za 50e usisava od kamenja do vode,garancija 3 godine. Radi vec godinu dana,neko vrime je radia ko bilge pumpa na brodu mi haha i jos uvik sve u redu  ;D
E to me interesira, baš taj mokro-suhi usisavač: vrijedi li tih 380 kn? Kada brusim balzu, zaserem cijelu radionu, pa bi trebao jedan pouzdani grubi radionički usisavač ? Mislio sam ga montirati u drugu prostoriju, a na zidu napraviti spojnu cijev i prekidač za rad, tako bi mogao usisavati ili spajati alate bez dodatne buke i struje zraka koja samo razbacije piljevinu po radionici?
Ja sam unazad godinu dana uzeo nešto slično u Bauhausu, cijenovno tu negdje, jeftin za usisavanje po graži...
Posted by Diogen - April 14, 2015, 09:24:55 am
Posted by rubazg - April 05, 2015, 08:19:43 am
kupljeno, traka je super i ima je puno, stvarno dugo traje
Posted by wirevt - April 02, 2015, 06:59:06 pm
Od danas u lidlu, srebrne i crne, 50metara, 20kn/kom
Posted by rubazg - March 27, 2015, 08:04:30 pm
tone i tone čokolade sam dopeljao u hrvatsku i prodao
Posted by rubazg - March 27, 2015, 08:02:58 pm
dobre su stvari iz lidla, i dosta jeftine znaju biti, šteta što ne prošire asortiman, ja u lidlu kupujem već 20 godina
