Post reply
Something happened, review it here:
  • Warning: this topic has not been posted in for at least 120 days.
Warning! This topic is currently/will be locked
Only admins and moderators can reply.
shortcuts: alt+s submit/post or alt+p preview
Attachments and other options
Add files by dragging & dropping or selecting them Add files
Attach:
(Clear attachment)
(more attachments)
Allowed file types: doc, gif, jpg, mpg, pdf, png, txt, zip
Restrictions: 15 per post, maximum total size 8,192 KB, maximum individual size 2,048 KB
Note that any files attached will not be displayed until approved by a moderator.
Topic Summary
Posted by Crayox - September 10, 2009, 10:55:18 pm
Hvala ljudi na pomoći! Uspio sam složiti iz starog PSUa. Imao sam jedan 20 ohma otpornik pa sam njega, isto je onaj "pješčani". Izmjerio izlaz i sve radi, stavio na punjač - opet radi :)
poz
Posted by Plavi - September 09, 2009, 08:04:04 pm
Da možeš puniti i one "home made" baterije koje nemaju onaj "mali bijeli višepinski konektor".
Posted by Crayox - September 09, 2009, 07:57:26 pm
E hvala, od sad ću onda tako :)
Zašto su uopće stavili obično? Brže?
Posted by Plavi - September 09, 2009, 07:50:06 pm
Svaki put balansirano punjenje.
Posted by Crayox - September 09, 2009, 07:18:33 pm
Da li da stavim otpornik između crne i zelene s kojim ću paliti napajanje? Nebi li to samo trebalo kratko spojiti?...preko prekidača naravno
Posted by Crayox - September 09, 2009, 07:17:22 pm
Kakva je preporuka za punjenje? Od kad sam kupio punjač i LiPo baterije, punio sam ih kojih 6 puta na charge, danas sam stavio na balance. Ima li neko pravilo svakih x puta ih balansirati? Ili, zašto ih nebi svaki puta punio u balance modu?
Posted by Diogen - September 09, 2009, 07:06:43 pm
@ Crayox:
zaboravi sve te molexe, floppy, onaj veliki kontakt za matičnu, kontakt za SATA..sve, ama baš sve to treba odcvikati i ostaviti samo žice koje sam naveo. Bedasto mi je citirati samoga sebe, ali moram to učiniti:
"Zatim na vodu za plus pet volti (najčešće je crven) odvoji jednu takvu žicu, takve ostale odsjeci, spoji jedna gadni veliki otpornik od cca 10-20 ohma snage disipacije barem 10 W jer se grije."
Dakle taj otpornik se spaja na +5V, a ne +12V, ima za to razloga (iako se može učiniti i drugačije uz malen gubitak snage).
Sada se vrati na moj post gdje sam opisao preradu i pročitaj:
-ono sa plavim slovima,
-ono sa crvenim slovima
itd.
@Zac1970
 Mogao bi poskidati tih starih postova: nešto i jesam, ali se pokazalo da su to onda preuzela 2-3 usera foruma (RCP).. Delal sam dakle za čućekove želučeke. Beskorisno!
Posted by Zac1970 - September 09, 2009, 06:21:51 pm
Zac, ja se nikada ne ljutim na tebe! ;) ;)
BTW, bilo je toga na starom friku, ja sam 'u milosti' pa bi to mogao i pronaći, ali mi se neda. Prirodno sam lijen.
Kaj ti možeš čitati modelarfki dio foruma na starom FF?
Mene su hitili van pred samo gašenje >:(
A i boli me k.... za njihov forum
Posted by Crayox - September 09, 2009, 05:11:07 pm
Hvala Diogen, tako otprilike piše i na onom siteu. Ovaj otpornik ide na baš na onaj vod od kojeg uzimam 12V, onaj isti molex koji ima i 5V....jel tako?
Što se tiče čistoće, hm, ima naravno jeftinih PSUa, moj je ok bio tada, ali svejedno, ako mogu napajati od hdda, DVD playera, matične, graf. itd. pa valjda onda mogu i jedan punjač. Nije da baš unište sve komponente nakon godinu, dvije. Naravno, špekuliram, nisam ga nikad spojio na osciloskop. ;)
E da, što mislite, vi elektroničari, ako na uređaju piše 11~18V da li bi se smjelo spojiti 20V na njega?
Posted by Diogen - September 08, 2009, 09:10:04 pm
Posted by Zac1970 - September 08, 2009, 08:35:22 pm
Kaj se ljutiš odma. Sad se sjećam da si mi to slično napisao na pm jednom na starom FF no zaboravil sam  :-X
Valjda sam zato kupil sve gotovo na UH  ::)
No dobro ovo će koristiti nekome novaku jer sve one informacije sa starog FF nisu dostupne.
Posted by Diogen - September 08, 2009, 08:21:00 pm
Sad bi ti mogel prenjeti svima nama a može i Diogen da se ne mučiš  ;D
Ajde Zac ....ne.... gnjavi ! ;)
Znaš dobro da sam ja protiv tih prerada. Napravio sam ih dovoljno da im je logaritam dvoznamenkasti broj ... i sva su sr....
Napajanja od PC-a su 'izviđačko rješenje', koliba od blata i pruća, a imaš na raspolaganju 'predsjednički apartman' za par baksi na UH (isto je swičer, ali malo prilagođen potrebama).
Zašto ne valjaju prerade PC napajanja? Dakle to je napajanje napravljeno po sistemu radi-ne-radi-ne-radi, nešto kao žmigavac koji koristi plavuša. Između puno radi i ne radi postoji sredina koja se zove izmjereni istosmjerni i slabo filtrirani napon. Kada bi sa time išao napajati neki osjetljivi uređaj... bilo bi svega. Pogotovo je osjetljiv na tzv induktivna a možda i kapacitivna opterećenja.  U slućaju da ti PC napajanje nema OLP tj, zaštitu od prenapona i kaj sve ne riskiraš i punjač i bateriju....
Moja preporuka: uzmi napajanje od starih notebook ili laptop  kompjuterčića koji su koristili Nixx batke. Takva napajanja imaju obično oko 3A pri 14 Volti i namjenjena su za punjenje pa pašu. Posebno dobri modeli su bili Armada od HP-a i onaj, kako se zvao od Tošibe?
Ako si uporan u vlastitoj gluposti ( a i ja sam) prerada se ne dela nažalost po bojama žica, jer sam primijetio da neki OEM farbaju vodove po nekom njihovom daltonizmu.
Potraži kontakte za minus (najčešće crni drot) i spoji preko otpornika od 100 ohma na PWR-ON (najčešće zelena, ali ima ih svakakvih).Otpornik je potreban da ti nekaj ne zašmelca.
Zatim na vodu za plus pet volti (najčešće je crven) odvoji jednu takvu žicu, takve ostale odsjeci, spoji jedna gadni veliki otpornik od cca 10-20 ohma snage disipacije barem 10 W jer se grije. Na drugi kraj otpornika spoji jedan minus vod. Otpornik izolirano iznutra prisloni na kučište (pazi da nekaj ne šlusaš) da se hladi, a dobro bi bilo da između namažeš malo onog bijelog silikonskog dreka kojim se namažu processori prije ugradnje hladnjaka. Otpornik se najlakše montira pomoću onih zubastih plastićnih vezica
Zatim pronađi vodove za +12 volti (neću reći koje boje jer meću svašta) skrati ih na potrebnu dužinu, na kraj zalemi jednu banana utičnicu, izoliraj i zašarafi je na kučište.
Na drugu banana utičnicu napravi isto sa žicama za minus (valjda su crne) i isto tako zašarafi na kučište i izoliraj.
Sve ostale žice odsjeci u korjenu, možda preko mjesta koje si sjekao kapni malo toplog ljepila da nekaj ne šlusa.
Zatvori kušište....
Prekidač ti ne treba,imaš onaj iza.... ako ga nema , izabrao si quratz od swičera.
Pazi sada ovo: sve ovo je napisano as-is i sam si odgovoran radiš li tako, a to znači sam si budeš kriv ako te drmne struja, opeće vatra ili sjebeš punjač.
Pa ti vidi ...
Posted by Zac1970 - September 08, 2009, 08:04:30 pm
Ma na hrelicu uzme staro AT napajanje za 20Kn.
Ono se pali na prekidac :)
http://www.flyfreak.net/forum/index.php/topic,284.0.html
Još povoljnije nego na hreliću  ;D
P1 ispravne potpuno ak vam treba napajanje na prekidač je.
Meni trebaju elise, dva kompa za dvije elise 10x4. Imam jedno napajanje vani sa prekidačem i mjenjao bi ga za elisu 7x4 za OS10
Posted by Zac1970 - September 08, 2009, 07:52:39 pm
zelenu i crnu spojiš i startaš napajanje.
Mario kaj misliš da ti se punjač gasi zbog prljave struje ili je napajanje starije i slabo.
Taj problem sam i ja imao sa starim napajanjima. Napravio sam jedno napajanje frendu i ne sjećam se kolika je struja bila ali nije se sa moglo puniti sa nekaj puno ampera. Punjač je bio turingy onaj od 40 baksi.
Ja imam kupljeno napajanje a napravio bi još jedno i sad trenutno imam novo napajanje od kompa i kad proračunam da to napajanje košta okolo 180kn za to već skoro mogu kupiti napajanje, kod kineza.
baš mi je kolega diogen objasnio gdje je bio problem i zakaj nisam mogel izvuci svu struju iz trafoa....
Posted by Wespen - September 08, 2009, 03:00:52 pm
