Post reply
Something happened, review it here:
  • Warning: this topic has not been posted in for at least 120 days.
Warning! This topic is currently/will be locked
Only admins and moderators can reply.
shortcuts: alt+s submit/post or alt+p preview
Attachments and other options
Add files by dragging & dropping or selecting them Add files
Attach:
(Clear attachment)
(more attachments)
Allowed file types: doc, gif, jpg, mpg, pdf, png, txt, zip
Restrictions: 15 per post, maximum total size 8,192 KB, maximum individual size 2,048 KB
Note that any files attached will not be displayed until approved by a moderator.
Topic Summary
Posted by Zgrocks - December 09, 2016, 04:23:54 pm
Letim i presretan sam . Al bas brutale. I dosad ga posudivao tak da ono svi sretni i zadovoljni.
Posted by branimir2000 - December 09, 2016, 12:56:39 pm
Čisto me zanima - kako je završila priča?
Posted by Zgrocks - May 19, 2016, 11:41:51 am
1701 kn sam platio plus jos sam trebao dati 11 kuna za nesto ali mi nisu rekli za sta uglavnom da ne bude zabune ,racun je slikan i vidi se ,jedino onda naslov treba urediti
Posted by Zgrocks - March 14, 2016, 10:11:53 pm
Nisam mogao cekati
Posted by Zgrocks - March 14, 2016, 10:09:10 pm
Posto sam nacuo situacije koje kolaju o meni,sutra cu staviti sliku svog racuna iz poste od dji . Koji se moze usporedito o datumu kada je ovaj post objavljen.A sto se tice kamera imaju racun i garanciju preko gopro supporta(inace maznute ili ukradene stvari nemaju) a jeftino sam ih prodavao jer se gopro hero 3 black prodaje po dosta vecoj cijeni i popularnija je nego gopro hero lcd plus.Inace predrasudi su losi ,najbolje prvo nesto pitati,usmeno,pozivom,porukom ,pa cak i javno .Nemam sto skrivati.Dron sam kupio jer sam mislio da je dobra ivesticija.
Posted by Zgrocks - March 10, 2016, 08:46:38 am
Ima i iosd mini onscreen display
Posted by Zgrocks - March 09, 2016, 10:42:58 pm
Zasto je jedna zicica potrgana iz ovog konektora koji ide iz p2 signal hub 1 ? Izgleda mi ko namjerno a na to se spajao video link
Posted by Zgrocks - March 09, 2016, 10:26:55 pm
Jedan motorcic ima mrvicu lufta,to znaci novi lezaj nabaviti?
Posted by Zgrocks - March 09, 2016, 09:35:57 pm
Hvala svaki savjet je dobrodosao!!ima li tko na forumu da ima phantoma 2 da je voljan napu iti bateriju i isprobati ovog igraca
Posted by frankycro - March 09, 2016, 09:03:37 pm
Kupiš stanicu na njuškalu a kad ono radi i bez bindanja  :D
Kod Phantoma 2 (čistog) znači koji je namjenjen da na njega staviš recimo Zenmuse H3/4-3D (što je u ovom slučaju tvoj) isporučivao se sa stanicom na 2,4GHz, dok kod ovih Vision + ide stanica na 5,8GHz.
Posted by Zgrocks - March 09, 2016, 08:44:51 pm
eto slika
Posted by Zgrocks - March 09, 2016, 08:26:12 pm
Dosao je phantom,na seb ima gimbal i vec se vidi da je nesto fusareno na njemu.Tj na samome dronuuz njega je dosao i avl58 5.8g vdeo link transmitter.Ima li itko iz zg da ima phantoma nekoga pa da b htio isprobati ovaj moj da li radi ? (trebam punjac pretpostavljam,stanicu i drugi prop posto ovajjedan zapinje a sad cu i slike staviti
Posted by backspin - March 07, 2016, 03:16:33 pm
nema frke... javi kako je proslo
Posted by Zgrocks - March 07, 2016, 03:15:58 pm
vidio sam na njuski a iz vukovara pise da je a ja sam iz zg =) .Nevertheless jako puno hvala sad cu prouciti malo videe.!! ;) ;)
Posted by backspin - March 07, 2016, 03:06:12 pm
