Post reply
Something happened, review it here:
  • Warning: this topic has not been posted in for at least 120 days.
Warning! This topic is currently/will be locked
Only admins and moderators can reply.
shortcuts: alt+s submit/post or alt+p preview
Attachments and other options
Add files by dragging & dropping or selecting them Add files
Attach:
(Clear attachment)
(more attachments)
Allowed file types: doc, gif, jpg, mpg, pdf, png, txt, zip
Restrictions: 15 per post, maximum total size 8,192 KB, maximum individual size 2,048 KB
Note that any files attached will not be displayed until approved by a moderator.
Topic Summary
Posted by Poskok - August 17, 2012, 05:21:21 pm
dobro si prebacio točkove naprid, ja svoju prodao, kupio funtanu benzinca od dražića iz zadra
Posted by Migovik - August 17, 2012, 11:05:27 am
...kupio jacu batku 3000 mAh...i vece tockove... ;).velika razlika...uzivancija u igri... :D
Posted by Poskok - June 11, 2012, 05:27:45 pm
moram i ja nabavit batku oko 3000 mAh 3S za svoju ova izgleda popustila
Posted by Hrenovka - June 11, 2012, 05:22:27 pm
momci,samo jača batka i piči miki
Posted by Poskok - June 03, 2012, 10:22:59 am
samo mi je pilot čini mi se sitan, kad stane iz  cesne izgleda veća nego i mene,  ;)
Posted by zrodi - June 03, 2012, 08:39:28 am
Uh, aviončina za 5, vozač prva liga!
Posted by Poskok - June 03, 2012, 12:15:42 am
jesan ti reka da je model odličan ;)
Posted by Migovik - June 02, 2012, 11:18:01 pm
samo ko jaca batka.... ;)
Cessna
Posted by Poskok - June 02, 2012, 12:12:54 am
odlično, da batka je malo bezze, taman se čovik naloži moraš k zemlji, kolika je uopće originalna batka kapaciteta? na mojoj ne piše, izgleda mi oko 2000mAh, mislim da bi moglo ići do 3-4000 mAh, ne bi težina puno ugrožavala letna svojstva mislim
Posted by varadero - June 01, 2012, 09:30:11 pm
Eto Migovik poletio, super model lijepo leti jedino je baterija za cca 5 minuta leta...ima li tko kakvu sugestiju za bolju bateriju ???
Posted by Poskok - June 01, 2012, 08:17:23 am
ja svoju još nisam oblijepio ima godinu dana, bijela je ko snijeg :D
Posted by varadero - May 31, 2012, 10:09:20 am
Meni je to prelijep model.....čak i dok ga Migovik šarafa :D   8)
Posted by Poskok - May 30, 2012, 12:33:35 pm
želim puno dobrih letova, s njom ti je sam ispravi, puni gas i malo navuci kormilo dubine sebi, i onda samo je lagano podigni na visinu i napravi reglažu, gore na visini malo smanji gas i onda uključi flapfeve, da možeš vidjeti kako se ponaša, samo neka je na visini, s flapsevima ona gore fino jedri i uspori, i onda ih probaš nazad vratiti i ona počne obaranje i onda samo gas, uživaj ko što sam i ja , hahah
Posted by Migovik - May 30, 2012, 11:39:07 am
...eto uz pomoc prijatelja satavljena...leti ce s mojom stanicom 9x turning. ;D...kad ce letit. 8)..kod nas je dosta lose vrijeme... :(
Posted by Poskok - May 29, 2012, 11:33:20 am
nemoj za početak polijetat sa spuštenim flapsovima, ode u zrak i u stall, meni je prvi put umalo odletjela u zemlju al sam se nekako jedva izvukao
