Post reply
Something happened, review it here:
  • Warning: this topic has not been posted in for at least 120 days.
Warning! This topic is currently/will be locked
Only admins and moderators can reply.
shortcuts: alt+s submit/post or alt+p preview
Attachments and other options
Add files by dragging & dropping or selecting them Add files
Attach:
(Clear attachment)
(more attachments)
Allowed file types: doc, gif, jpg, mpg, pdf, png, txt, zip
Restrictions: 15 per post, maximum total size 8,192 KB, maximum individual size 2,048 KB
Note that any files attached will not be displayed until approved by a moderator.
Topic Summary
Posted by robi1kenobi - October 09, 2012, 02:07:01 pm
Mi smo sad za vikend išli u Sloveniju sa stanicom, punjačem i 2 modela, nisu nam dali ATA karnet ni niš
Posted by modernwarfare - October 06, 2012, 05:04:24 pm
pa u budampestu,pise ti sve na hk stranici di imaju shopove
Posted by ivanhoe - October 06, 2012, 03:44:14 pm
pozz,uskoro cu ic u mađarsku u shop od hobby kinga jer ne zelim cekat da mi to sve stigne postom uglv uzet cu si turnygi 9x,2200kv motor,1600kv motor,30a esc,par komada serva i jos par sitnica uglv zanima me dali ja moram imat nekakvu dozvolu za uvoz ili mogu sam rec da je za privatnu uporabu? ps. iz BiH sam
Aj plz reci di u Mađi ima njihov šop? Tnx!
Posted by modernwarfare - October 06, 2012, 02:57:14 pm
Posted by Poskok - September 18, 2012, 08:38:55 am
evo nekih propisa s carine, znači, ovo spada u sportske rekvizite tako da možete pogledati pod
Osobni predmeti putnika i predmeti za sportske svrhe
na sljedećem linku
http://www.carina.hr/Carina/PrivremeniUvoz.aspx#P1
nije potreban ata karnet, drugo su klavijature i druga oprema, s modelom se može vratiti u 349 komadića u vreći ako se model razbije,
na dnu teksta ima u pdf-u formular koji se samo popuni i ovjeri na carini da se u određenom roku popisana oprema vrati i to je to
ja imam FAI sportsku dozvolu pa tako dokažem da je to sportska oprema pri uvozu u RH, i naravno kad se vraćam samo to ovjere da je izišlo u napisanom roku
eto, nadam se da će bit korisno
Posted by zokizo - February 07, 2012, 12:02:15 pm
mozda ces najtocniji odgovor dobiti ako nazoves carinu
ja sam zvao carinu rijeka posto sam vec imao njihov broj
Posted by banga - February 07, 2012, 11:51:56 am
dali je bitno koja zemlja je u pitanju ili je to svejedno? putujem u kolumbiju pa bi ponjeo stanicu par baterija punjac i quadcopter
Posted by bgnjip - January 03, 2012, 12:37:04 pm
i ja sam imao slično iskustvo prije 2 god., išao sam u Mađarsku na jednu konferenciju i frendu vozio profi sintić. S obzirom da se muzički instrumenti moraju prijavit, prvo nazvo Carinu i rekli mi da prijavim na granici. Došo tamo pa me carinik prvo poslo na špediciju (vjerovatno, čisto da protegnem noge), u špediciji nemaju poima, kažu mi to ne radimo. Ja onda nazvo frenda koji zna carinika i kaže mi čovjek, odi cariniku i traži ga formular/izjavu za privremeni izvoz. Ja dođem pogledam ga u oči i kažem oću to! A on prevrne očima i ode u kontejner i da mi papir preko volje. Ja ga ispunio, on udario žig i otišo. Nisam mogo vjerovat da im je tako težak posao.
Na povratku sam reko da imam sintić pokazo papir (mislim da ga je uzeo ili ovjerio) i prošao.
 ;D
Posted by zokizo - January 03, 2012, 11:13:31 am
presao granicu i pitam policajca da bi prijavio neke stvari i govori da netrebam i piam dali ce biti problema prilikom povratka
govori da ne rekao je da ako su vidljivi tragovi koristenja nema problema
nemaju ni oni pojma sta treba prijavit sta ne
Posted by sasapu - January 02, 2012, 02:06:34 pm
nego reci ti nama di ti to putujes ;)
Posted by Poskok - January 02, 2012, 09:01:31 am
ja sam vozioiz bih u cro, samo sam na običnom A4 papiru napisao izjavu da to privremeno izvozim u HR ,ljudi mi ovjerili,nitko nije pitao,carinik je pogledao stanice i avione i ništa više, kad sam se vraćao samo razdužio i to je to
Posted by Plavi - January 02, 2012, 12:11:44 am
Ma neće, prvo će te pitat kolko košta kofer  :D
Posted by zokizo - January 01, 2012, 11:21:43 pm
javim kad rijesim
kofer di drzim stanicu i baterije kad otvoris izgleda ko neka teroristicka naprava
valjda me nece pocet tuci prije nego im objasnim sta je to  :D :D
Posted by robi1kenobi - January 01, 2012, 11:03:23 pm
Sigurno ti nije rekla nešto, već ti je rekla točno koji formular moraš ispuniti, jel tak zoki?  :D
Posted by Plavi - January 01, 2012, 10:46:52 pm
danas sam zvao carinu i objasnio osobi koja mi se javila rekao sam da je to "igracka" nadaljinsko upravljanje 2,4ghz
i rekao mi je samo da kad budem izlazio kazem da imam to i da cu morat popunit nesto i da nema nikakvih problema
valjda zna sta prica posto radi na carini  :)
a vidjet cemo ubrzo nadam se samo da me nece vratit s granice/carine
Super ako je tako ( tako bi trebalo i biti )  ;)
Mada još uvijek postoji ono ALI, naiđeš na jelena pa mu objasni  :D
U svakom slučaju sretno i javi kako je prošlo.
Pozz
