Poštovani modelari!,novi sam u ovome i trebao bih pomoc Vas iskusnih ako moze?
Naišao sam na idealne upute za izradu zagija na stranici---rcflybook.com---e sad materijal za zagi sam sakupio stiropor i letvice,a trenutno si pravim žicu za rezanje stiropora ;D no u elektroniku se bas i nerazumijem,a i nemam bas novaca na bacanje da bih si sve kupio i onda shvatio da se nista neslaže :) evo linkovi s elektronikom po mom izboru a i malo pokupljeno od ostalih modelara na forumu :D
STANICA-http://www.hobbyking.com/hobbyking/store/__20976__Turnigy_9X_9Ch_Transmitter_without_Module_Mode_2_v2_Firmware_.html
MOTOR-http://www.hobbyking.com/hobbyking/store/__12919__D2826_6_2200kv_Outrunner_Motor.html
ESC-http://www.hobbyking.com/hobbyking/store/__24562__HobbyKing_40A_ESC_4A_UBEC.html
PROP-http://www.hobbyking.com/hobbyking/store/__9840__SF_E_Prop_7x4_178x102mm_w_Adapters_Black_5pcs_bag_.html
SERVO-http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=662
BATERIJA-http://www.hobbyking.com/hobbyking/store/__9394__Turnigy_2200mAh_3S_30C_Lipo_Pack.html
XT60-http://www.hobbyking.com/hobbyking/store/__9572__Nylon_XT60_Connectors_Male_Female_5_pairs_GENUINE.html
Evo jos bi zamolio da neko doda nesto sto mi jos fali,ako nije problem.
Ispričavam se na dužini posta...
Moduli su precijenjeni :)
Znači fali ti ili stanica s modulom (Turnigy tj. FlySky) ili još bolje, uzmeš ovak stanicu bez modula + FrSky modul za nju
Ma bolje mi je onda uzet stanicu s modulom :) hvala samo nastavite s odgovorima ;D
Trebat će ti još ovo:
http://www.hobbyking.com/hobbyking/store/__8519__Linkage_Stopper_M3x2xL11_2mm_10pcs_set_.html (http://www.hobbyking.com/hobbyking/store/__8519__Linkage_Stopper_M3x2xL11_2mm_10pcs_set_.html)
http://www.hobbyking.com/hobbyking/store/__8421__Nylon_Clevis_2x29mm_10pcs_.html (http://www.hobbyking.com/hobbyking/store/__8421__Nylon_Clevis_2x29mm_10pcs_.html)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9887 (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9887)
http://www.hobbyking.com/hobbyking/store/__6589__Battery_Monitor_2_6S.html (http://www.hobbyking.com/hobbyking/store/__6589__Battery_Monitor_2_6S.html)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=68 (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=68)
ili
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=20228 (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=20228)
uz ovaj prvi ti treba i
http://www.hobbyking.com/hobbyking/store/__5277__Turnigy_4mm_Heat_Shrink_Tube_b_RED_b_1mtr_.html (http://www.hobbyking.com/hobbyking/store/__5277__Turnigy_4mm_Heat_Shrink_Tube_b_RED_b_1mtr_.html)
punjač za baterije ako nemaš(to ti je minium za punjač)
http://www.hobbyking.com/hobbyking/store/__7028__Turnigy_Accucel_6_50W_6A_Balancer_Charger_w_accessories.html (http://www.hobbyking.com/hobbyking/store/__7028__Turnigy_Accucel_6_50W_6A_Balancer_Charger_w_accessories.html)
Nadam se da sam ti pomogao
Hvala vam puno svima skratili ste mi muke traženja po netu,eto kad se skupe novci bacam se na posao i postavljam slike :)
vidio sam da su prije trebale dozvole za stanicu,ali od ove godine vise ne dali je to tocno,mislim da nemam problema kad narucim tu stanicu?
Ne trebaju vise dozvole
FlyMeToTheMoon jel bi mi mogao ako nije problem sastavit takav sličan popis stvari samo da se izbaci stanica,punjač i da se doda gws v-tail mixer II (200 step)?
FlyMeToTheMoon koliko sam shvatio sve sto se narucuje s HK do 1500gr poštarina iznosi 23,59$,jel znas mozda cijenu za vecu kilažu?
hvala ti,oprosti ak te zezam jer se polako ucim o svijetu modelarstva pa neznam bas sve,i ove sve djelove sto si mi nabrojao sam pogledao,ali vidim da su neke cijene narasle...pa jel ti to od prije taj post ili?
pa je to je super za ubuduce :) ma sad me muci sad to sve stavljam na popis al su uracunali i kutiju u koju to sve ide a ona je teska 439gr pa sad moram raspodjelit ne na 3 paketa nego 4 ili vise!
ok,a valjda cu uspit nekako jeftinije proc :D jel taj paket stize na kucnu adresu ili u postu? znam sam da dode za nekih 2 tjedna tak nesta sam procito na forumu ak se nevaram.
oke,hvala ti puno si mi pomogo :)
valjda ce neko znat :D
evo upravo pogledao,to je vise manje slicno tvom postu na stranici 1 :) ali nema veze opet ima nesto drugacije sto se moze iskoristit ;D
Puno hvala za popis.
FlyMeToTheMoon evo sastavio sam popis sve to u 2 paketa ;D nego jos mi treba tvoja pomoc stavio si mi ove gold conectore,njih nema a jel ima nesto slicno tome da posluzi istoj svrsi???
medu onima sto si mi preporucio ovaj sam odabrao
http://www.hobbyking.com/hobbyking/store/__12191__TURNIGY_TRUST_45A_SBEC_Brushless_Speed_Controller.html (http://www.hobbyking.com/hobbyking/store/__12191__TURNIGY_TRUST_45A_SBEC_Brushless_Speed_Controller.html)
fali mi samo baterija za daljinski i ti gold conectori a to pise da nemaju da ce stic za tjedan ili 2,znaci ja to mogu narucit i stici ce zajedno sa ostalim?
upakiro sam i to ;D pa cu bolje malo sacekat :) a te sve baterije ja mogu punit na ovaj punjac jelda
za pocetak sam si narucio samo jednu bateriju za zagija,a kasnije budem jos koju :)
120 cm,gledao sam na ovoj stranici
http://www.rcflybook.com/rc-portal/Odjel-za-po%C4%8Detnike/Kako-napraviti-avion/ZAGI-izrada-1.dio/1/4/19 (http://www.rcflybook.com/rc-portal/Odjel-za-po%C4%8Detnike/Kako-napraviti-avion/ZAGI-izrada-1.dio/1/4/19)
sve je lijepo opisano korak po korak pa mi se cini da bi mogao i uspiti napravit kako spada :D
ma do stelanja brzine i svega ostalog ima jos vremena :) ja sam vam iz bistrinaca-slavonija i baranja :D a vi?
stari mi je davnih dana radio u kutini i uvijek mi je pricao "sine ono sve sto se u kutini nevidi to sam napravio ja" hahaha kaze da je kutina jos jedan grad pod zemljom sto se tice tih cjevovoda i neznam ceg sve ne ;D
FlyMeToTheMoon jel se ovo uopce moze ustekat u obicnu uticnicu?
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=20971 (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=20971)
Evo da se i ja uključim u razgovor ;)
Pratim i sviđa mi se tolika pomoć koja se pruža u nevolji za početnike.
Zamolio bih da mi se napravi dobar setup za zagija 140cm, za letenje FPV
Neka bude kvalitetno i kompletan setup da ne lutam jer se ja stvarno ne kužim.
Gdje se sve stavlja elektronika i na kojim pozicijama radi držanja balansa zagija?
Hvala
Pozdrav sa poplavljenog Raba ::)
Subic meni su stvarno pomogli svi pogotovo FlyMeToTheMoon jos jedno hvala,nadam se da ce i tebi :)
FlyMeToTheMoon jel si moram i ovo kupit??
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=4170 (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=4170)
za ceg to sluzi?
to je ako nema v tail mix na stanici
jel ova ima?
http://www.hobbyking.com/hobbyking/store/__8992__Turnigy_9X_9Ch_Transmitter_w_Module_8ch_Receiver_Mode_2_v2_Firmware_.html (http://www.hobbyking.com/hobbyking/store/__8992__Turnigy_9X_9Ch_Transmitter_w_Module_8ch_Receiver_Mode_2_v2_Firmware_.html)
Hvala
Tu bi mogli uskočiti dečki koji su već letjeli FPV sa zagijima Tomislav_ZG, Stipe, mislim i DavorVŽ.
Po mom mišljenju motor veličine 3536 od 1200 - 1500kv ovisno o naponu batke, prop bi bio od 8x6 - 10x5.
Nism testirao tako nešto pa ne mogu reći da je 100% ali u svakom slučaju bih krenuo od toga.
Ima ima, bez brige :) Nema sta nema na toj stanici :)
Inace taj mikser sluzi da kombiniranje ailerona sa elevatorom pa nastaju elevoni. Znaci zagi ima elevone koji koriste i kao eleroni i kao elevator :)
oke,vec sam mislio da i to trebam :D
decki dali neko ima kakav link kako da napravim šablon veliki i mali za krila zagija onaj preko kojeg idem sa vručom žicom?
e superiška,a jel ovaj program moram skinit ili ima online Airfoil Browser?
hehe :D moze :)
ovaj zagi kalkulator je super,tu mogu i neke mini modele smisljat :) ali onaj program-prvi link nemogu instalirati pise da je neka greska.
ma evo skonto sam :D
FlyMeToTheMoon mozda je ovo glupo pitanje jel sam tek pocetnik,ali zanima me dali bi se mogao napraviti mini zagi gledo sam po forumu ima samo 3 takva,narucio sam opremu za veliki zagi ali ovaj mali mi se cini da ga je jeftinije skrsit :D :D jer je sve sto ide u njega jeftinije,dali bi mi mogao preporuciti neke mjere u zagi kalkulatoru ili da ga napravim kako ispadne i sto se tice profila to bi samo trebo smanjit u onom programu jelda? :D
ok,a gdje da skinem simulator?jel ima simulator bas za zagi?
ok,jel taj kabel ima kod nas za kupit ili da sa hk narucim
Ima na jednoj slici pa samo uvecas za svoje potrebe, precrtas na sperplocu recimo 5mm i izrezes.
A ima i tu jedna slika s profilom: http://rcwings.webs.com/projekti.htm (http://rcwings.webs.com/projekti.htm)
A najjednostavnije je samo u tom programu Airfoil Browser otvorit željeni profil i kliknut na print i stavit željene veličine i to je to.
Evo jedan post sa foruma koji može poslužiti:
Evo
TSAGI 12 korjen (http://rcwings.webs.com/pdf/TSAGI%2012%20korjen.pdf)
TSAGI 12 završetak (http://rcwings.webs.com/pdf/TSAGI%2012%20zavr%C3%85%C2%A1etak.pdf)
USA 45M korjen (http://rcwings.webs.com/pdf/USA%2045%20M%20korjen.pdf)
USA 45M završetak (http://rcwings.webs.com/pdf/USA%2045%20M%20zavr%C3%85%C2%A1etak.pdf)
Pozz
Onda evo jedan koristan video (iz ove teme: http://www.flyfreak.net/zagi/kako-napraviti-zagi-rc-ig/ (http://www.flyfreak.net/zagi/kako-napraviti-zagi-rc-ig/)): Kako napraviti leteće krilo ZAGI - RcFlyBook (http://www.youtube.com/watch?v=MMlwkevEBI4#)
Jedino šta ja ne bi winglete šarafio na zagija nego zalijepio uhuporom i onda samo dodirne rubove dodatno pojačao selotejpom. Meni nisu nikad otpali sa zagija. Jedino su mi se okrhnuli radi tvrde trave pa sam taj dio (trokut) izrezao, umetnuo novi komadić i zalijepio.
A ako budeš jako motor urezivao u zagija onda po preporuci kolege iz Križa (Igor), trebalo bi staviti L komade ili jedan veliki koji odmah posluži i kao motor mount da se zagi ne raskoli ako padne direkt na nos :)
Ja svojeg nisam urezivao puno i motor sam podigao na nosač tako da mi 1/4 propelera viri sa donje strane zagija. Kod slijetanja se taj dio samo izmakne kad takne travu i to je to.
A serva nisam lijepio uopće, samo sam napravio rupe na knap, ugurao serva i prekrio selotejpom. Drži pošteno i ne miču se.
Evo i MH43 profil root i tip ( pokazao se boljim od Tsagi profila )
http://rcwings.webs.com/apps/forums/topics/show/2361500-zagi-profil- (http://rcwings.webs.com/apps/forums/topics/show/2361500-zagi-profil-)
