Post reply
Something happened, review it here:
  • Warning: this topic has not been posted in for at least 120 days.
Warning! This topic is currently/will be locked
Only admins and moderators can reply.
shortcuts: alt+s submit/post or alt+p preview
Attachments and other options
Add files by dragging & dropping or selecting them Add files
Attach:
(Clear attachment)
(more attachments)
Allowed file types: doc, gif, jpg, mpg, pdf, png, txt, zip
Restrictions: 15 per post, maximum total size 8,192 KB, maximum individual size 2,048 KB
Note that any files attached will not be displayed until approved by a moderator.
Topic Summary
Posted by Ivan Bistricic - May 24, 2016, 09:34:32 am
Imas pravo, jucer sam procitao sve ponovo iz posta.
Onaj Turnigy 9x je sada 54€ što je cca 11€ skuplje od Turnigy-i6 no problem je što
ga u hobbykingu nema ni u UK Warehose-u niti EU Warehose-u...
Doduše trenutno nema niti jednog od ova 2.
Posted by varadero - May 24, 2016, 06:33:33 am
Pdf nije updatean, ali tema je, na njoj je link za ovu stanicu.
Poslano sa mog LG-D855 koristeći Tapatalk
Posted by Ivan Bistricic - May 23, 2016, 09:01:37 pm
Ivane, pročitaj sticky temu za početnike pod nazivom Modelarstvo- kako početi. Tamo ti sve piše skupa sa linkovima.
Poslano sa mog MediaPad T1 8.0 koristeći Tapatalk
Hvala na savjetu, taj pdf sam pronašao čim sam došao na forum i pročitao sam no nema ništa
konkretno za ovu stanicu, a na hobbyking-u je trenutno nema. pa rekoh da upitam.
Posted by Damir_Klc - May 23, 2016, 08:26:44 pm
Bok,
htio bih samo jednu informaciju, dali je netko upoznat sa stanicom Turnigy TGY-i10 i dali ima kakove informacije? dali se isplati kupiti ili ima nesto bolje u tom cijenovnom rangu?
evo i link http://www.hobbyking.com/hobbyking/store/__75277__Turnigy_TGY_i10_10ch_2_4Ghz_Digital_Proportional_RC_System_with_Telemetry_Mode_1_EU_Warehouse_.html
Posted by DomagojST - May 23, 2016, 06:40:17 pm
Hvala na savjetima.
A di si kupio Flysky FS-i6?
Kupio sam je preko AliExpressa,ali bi je trebao cekat 20-30 dana jer dolazi iz Kine.
LP
Posted by varadero - May 23, 2016, 06:36:44 pm
Posted by Ivan Bistricic - May 23, 2016, 05:54:01 pm
Hvala na savjetima.
Posted by DomagojST - May 23, 2016, 05:03:10 pm
Pozdrav.Ja mislim da bi vam za pocetak najbolja bila Flysky FS-i6 ili Turnigy TGY-i6.Ja kao pocetnik imam navedenu Flysky FS-i6 stanicu i veoma sam zadovoljan sa njom.Takoder ima mogucnost mixanja kanala.Po meni sa njon nebi trebali imat nikakvih problema i nadam se da vam nisam nista krivo reka,ako jesam neka stariji isprave.
LP Domagoj
Posted by Ivan Bistricic - May 23, 2016, 03:34:00 pm
Pozdrav, bi li mi netko preporučio koju stanicu da kupim, gledao sam na hobyking-uali iskreno kao početnik teško mi je raspoznati što bi meni točno trebalo.Konkretno me brine to što se spremam naručiti djelove za izgradnju http://www.parkjets.com/free-plans/f-16-falcon No frend mi kaže da za njega treba stanica koja ima mogućnost mixanja kanala.Pa rekoh možda bih treba paziti na još štogod...Hvala.
Posted by šišmiš - October 21, 2012, 10:22:53 pm
@robi1kenobi
majstore, kape dole s moje strane - poštujem prave entuzijaste i prave modelare, no takve možeš izbrojat na prste jedne ruke na ovom forumu.. Nažalost previše je pomodne i asocijalne ekipe koja sebe naziva modelarom zato što su si pokupovali opremu i gotove modele koje su sklopila djeca-robovi u nekoj tehnološki zaostaloj Kineskoj tvornici. To nisu modelari, nego čisti konzumenti gotovih proizvoda, koji ne znaju ni u modelarski luk pilicu pravilno utaknuti, a kamo li složit nešto što leti..  >:(
Bit svega takvoj ekipi je na čoporativnom letenju pokazati da je njegova Extra najveća, najbrža, da ima najjači 2-taktni motor (iako ni ne znaju objasniti razliku između 4-taktnog i dvotaktnog), da ima jebeno skupe servače (digitajne of course), zadnji krik telemetrije i po mogućnosti GPS lokator, kako bi mogli sakupit model kad ga zašilje u tlo kilometar dalje od početne pozicije..
Samo čekam dan kada ćemo na HK-u kupiti modul koji će kompletan let odraditi za njih, i usput na SD-karticu pospremiti snimak (naravno u rez od 1080p koji lovi kut od minimalno 170°) - tada ćemo i stanice (bilo one skupe ili jeftine) moći okačiti na klin..
Takva ekipa robuje tom svojem nazovi hobiju, za njih modelarstvo nije relaksacija, već njihova osobna realizacija, afirmacija koju nisu postigli u drugim aspektima života... a u konačnici i financijski teret za koji nisu bili spremni i koji je ruku na srce nepotreban u večini slučajeva..
Za kraj pozdravljam sve prave modelare i podsjećam Vas na onu staru narodnu:
"Boj ne bije svijetlo oružje,već boj bije srce u junaka"  ;)
p.s.: Kolegi početniku, poručujem da se ne obazire na kreket u močvari i nek si pikne tu stanicu za 200 kunića, četiri
        alkalne AA baterije, neki pogon (motor, ESC i prop i batt za ukupno 15$), 2 analogna servaća (svaki 2.45$), šteku IzoFlor-a od 6mm, 2-3 role širokog selotejpa i neka se upusti u samogradnju i nauči nekog jarca za početak, a drajvanje gotovih modela i heklanje pred simulatorom neka prepusti papcima koji ne zaslužuju da ih se naziva modelarima..
Posted by robi1kenobi - October 20, 2012, 11:12:52 am
Ma ima ona skoro sve potrebne mixeve. Najveći problem leži u katastrofalno lošim potenciometrima na palicama. Ne znam kak vi uopće možete letit flybarless helije i multije s tom stanicom, tj. znam - s hrpom deadbanda i puuuuuno expoa. Dvije koje su meni došle su imale opako loše mikroprekidače, na jednoj uopće nisu radile 2 tipke itd.
Prošlo mi je kroz ruke sigurno 10ak tih stanica a posjedovao sam i bolje i lošije. Po meni je Futaba 6EX, Hitec Optic 6, Spektrum DX6i ili nešto u tom rangu puno bolja kupnja od tog Turnigyja, iako imaju manje mixeva, bar znaš da su potovi, switchevi i prekidači dobri. 7C, DX7, i tome slično su već jako solidne stanice koje mogu odraditi sve za vikend letača koji ne treba nekakve perverzije. A one su u 1000 i kusur kn rangu bez prijemnika (s dostavom, ganz nove), pa radije dodaš parsto kn i uzmeš poštenu stvar.
Posted by Shimpa - October 20, 2012, 09:51:33 am
Moja prva je bila ona koju imam i danas (JR XP9303)
I iskreno ne bi je mijenjao al mi svi frendovi imaju futabu pa da postoji mogućnost spajanja preko trainer linka. To i s-bus, ostalo manje više sve mogu i s ovom.
ta turnigy stanica nema ni približno funkcija koliko imaju kvalitetnije stanice, da ne počnem o kvaliteti izrade, kvaliteti switcheva, kvaliteti firmwarea... a i dalje košta 800 kuna sa svim davanjima. To da je džabe još bi shvatio ali ovako...
Posted by robi1kenobi - October 19, 2012, 11:12:49 pm
A di si naš'o prastaru 12Z... :)
Inače, u Hrvatskoj nema profi modelara jer nitko nije sponzoriran a i nitko ne leti na nivou da bi bio sponzoriran (bar ja to još nisam vidio) :)
Kaj se tiče ostatka teksta, u pravu si. Ali ako netko namjerava ostati u hobiju, čemu bacati lovu na lošu opremu? Ak si može odmah priuštiti kvalitetnu stvar, zašto ne :) Ionak je stanica stvar koju imaš neko vrijeme...
Moje mišljenje
Posted by šišmiš - October 19, 2012, 11:06:59 pm
Moja početnička je bila Spektrum DX6i, kupio ju polovnu tu na forumu, ni ne sjećam se od koga....i nisam zažalio, ubrzo dođe do izražaja kod ovih ESky, Efly i sličnih jeftinjara, koliko su digitalni trimovi i kontrole bolji od analognih, pogotovo ako se radi o nekom 3D modelu.
slažem se s tobom... no ako idemo tom logikom, nebi li Ti i ostala škvadra koja spada u 'profi' aviomodelare trebala
gledati nešto ovakvo :http://www.futaba-rc.com/systems/futk9300.html, a ne busati se u prsa sa DX8-icom ?  ;D
Samo bez veze motate kolegu...
Morate imati na pameti da mi početnici prvo trebamo zdribiti kilu deprona i proći stanice poput HK-ovih i Turnigy-a 9x, E-sky i ostale
iz domovine Brucea Lee-a da bismo jednog dana skužili razliku u rezoluciji kad nam u ruke dođe nešto skupo i profinjeno..
Želim reći da čovjek može sasvim fino letjeti za početak sa stanicom za 200 HRK-a, deproncem koji u materijalu vrijedi 30kn i motorizacijom za < 200 HRK-a..
Isto tako, što se tiče modela, puno veća satisfakcija, barem meni, je kad sa stanicom za 200kn dignem u zrak depronca kojeg sam svojim rukama i vještinom izradio i kad se ispostavi da leti bolje od modela za koje ljudi pljunu po par tisuća kuna u kitu..
I što je najvažnije - zabijem li ga u zemlju, za dva dana izradit ću još bolji za narednih 30 HRK-a i nastavit uživat u pražnjenju baterija.. ;)
Posted by robi1kenobi - October 18, 2012, 02:04:13 pm
Ima u oglasu dobrih stanica, Shimpin JR 9303, neov DX7 i sigurno se još nešto nađe, bolje skupit malo više love na početku i uzet poštenu stanicu nego taj 9X
