FlyFreak
RC Modeli => Helikopteri => Topic started by: zokizo on July 03, 2018, 09:17:24 am
Title: ALZRC Devil 420
Post by: zokizo on July 03, 2018, 09:17:24 am
Dosadili kvadovi pa da se vratim na pocetak
a i falilo mi ono klecanje koljena, znojenje dlanova i zvuk blejdova  ;D
Nije bilo para za 505 pa sam uzeo 420
manje vise nacitao se  i nagledao alzrc-goblina itd dok sam cekao paket
ali veseli me ovaj FC Spirit i self level, self level invert i rescue mode
za razliku od copterX ili hk kopija trexa 450,500 koje sam slagao, stvarno su jako lijepo i precizno odradili kopiju sve legne na svoje mjesto
bez dodatnog rezanja brusenja i ostalog kemijanja da bi sve leglo na svoje mjesto stvarno odlicno odradjeno
evo i par slikica bulda (bit ce jos kako budem slagao)
Title: Odg: ALZRC Devil 420
Post by: zokizo on July 03, 2018, 11:03:34 pm
Pomalo napreduje (https://uploads.tapatalk-cdn.com/20180703/9401bf935cbf2e0c292406c9b6d460d8.jpg)(https://uploads.tapatalk-cdn.com/20180703/6bc873cf6710b97f15e62467ff66712c.jpg)(https://uploads.tapatalk-cdn.com/20180703/a78aa95e46ce5f0fbdc8e25214436bd3.jpg)(https://uploads.tapatalk-cdn.com/20180703/1a8b1c7e6b4bdd1cc31142e718f9e122.jpg)
Sent from my FIG-LX1 using Tapatalk
Post by: frankycro on July 04, 2018, 12:22:47 pm
Big like  ;)
Post by: varadero on July 04, 2018, 04:06:05 pm
Pratim, bilo bi dobro da staviš linkove odakle si sve naručio.
Poslano sa mog SM-G935F koristeći Tapatalk
Post by: as on July 04, 2018, 04:43:09 pm
Neka naših kopija  :D :D :D
Post by: zokizo on July 04, 2018, 06:06:31 pm
A kako build ide vidis da i nije sve tako sjajno
Tail boom se mice lijevo desno kad ga zavidas mada mislim da idu jos dve vide (slika) kojih nema u kitu :)
Fali par washera u uputama za slaganje su nacrtani ali ih ja nisam dobio
Rep ne klizi kako bi trebao, kao na ostalim helicima
Nista sta se nemoze rijesit ali.... (https://uploads.tapatalk-cdn.com/20180704/56a37bd113fc35cc0edf9494406914fc.jpg)
Post by: as on July 04, 2018, 10:06:38 pm
Boom se fiksira s nosacem repnog serva i meni je to bilo dok ga nisam stavio.
Post by: as on July 04, 2018, 10:10:56 pm
Sta nije u redu s repom?
Post by: zokizo on July 04, 2018, 10:49:41 pm
Da ali probaj drzat frame i tail bom i mrdaj naprijed natrag
Moj ima lufta ne puno ali ima
Post by: zokizo on July 05, 2018, 09:12:12 am
kit s motorom i esc sa rc711
servoi s banggooda
i fc http://www.spirit-system.com/ (http://www.spirit-system.com/)
od svugdje pomalo ;D
Post by: as on July 05, 2018, 02:48:37 pm
Meni nema lufta kad sam stavio nosač repnog serva.
Spomenuo si da klizač na repu ne kliže kako bi trebao. Možeš li mi opisat u čemu je problem, možda i ja imam taj problem a da ne znam da ga imam.
Post by: zokizo on July 05, 2018, 03:55:34 pm
Ne klizi bas lijepo a i ball linkovi su preuski treba ih malo rasiriti kod mene
Post by: as on July 05, 2018, 09:46:31 pm
Kod mene rep normalno klizi a linkovi si isto pre uski.
Post by: as on July 05, 2018, 09:46:54 pm
Treba ih razraditi.
Post by: zokizo on July 05, 2018, 11:27:43 pm
S ovim
https://www.google.hr/search?q=ball+reamer&oq=ball+reamer&aqs=chrome.0.69i59j0l2j69i60l3.5961j0j9&client=ms-android-huawei&sourceid=chrome-mobile&ie=UTF-8
Sami od sebe se i nece bas
Post by: davor on July 06, 2018, 08:55:38 am
Na goblinu bum nema lufta, kad zasarafis ostane razmak izmedju gornje povrsine buma i alu ploce, tako da su dodirne povrsine kosine sa strane, to ga centrira. Mislim da nosac serva nije zamisljen da drzi bum, ja sam ga pobrusio tako da ne dodiruje bum uopce.
Glede linkova u manualu pise da ce se nakon nekoliko letova razraditi sto ja isto mislim da nece, pa sam ih prosirio sa gore spomenutim alatom. Dva linka, na cijevi sto povezuje repni servo i repni slider su veci za par desetinki i alat ne pase. Inace uvijek smo te linkove prosirivali da budu malo knap ali da se lagano pomicu, dok nije dosao goblin sa svojom "preciznom" izradom i tvrdnjom da to kod njihovih linkova nije potrebno.
Post by: as on July 06, 2018, 11:36:44 am
Kod Devila boom ima malo lufta dok se ne stavi nosač serva. Ne znam kako je na Goblinu ali na našem je vida od najlona tako da se ne ne smije jako zategnuti. Nosač serva je napravljen da drži boom s donje strane i baš ga treba jako nategut da vide sjednu na svoje mjesto. Ja sam svoj zakucao poprilično jako i boom je pukao ali nosači i vida nisu popustili tako da mislim da je taj dio sasvim dobro napravljen.
Ball linkovi jesu malo uski ali servo poslje leta nije vruć tako da mislim da se puno ne "lomi " u radu. Prije ću ga ja razbit nego što će se linkovi razradit :D :D :D :D .
Post by: zokizo on July 06, 2018, 01:56:23 pm
ja sam svoje linkove prosirio jer su servooi konstantno zujali kad bi stajali mirno, sta bi znacilo da su under load sta i nije bas kako bi trebalo biti
nakon sto sam ih malo prosirio kad se swash izravna usute
Post by: zokizo on July 23, 2018, 10:23:32 pm
Kad imas 5 razlicitih modela s 5 razlicitih fc ti se desi ovo, krivi switch, i dok sam skuzio sta je, heli je vec poljubio zemlju
Pad s 50ak m,
I steta samo 57 dolara,
Stvarno cvrst heli su napravili
Belt puko, blejdovi, tail boom, zupcanik i link jedan(https://uploads.tapatalk-cdn.com/20180723/af868bf6c7e7e4f4ce8241edf4538297.jpg)
Post by: frankycro on July 24, 2018, 11:41:11 am
Nisi valjda throttle hold potegao? Ako jesi tu funkciju za sve modele na isti switch obavezno. Koje FBL kontrolere koristiš?
Dali su servo svi preživili?
Post by: as on July 24, 2018, 01:26:16 pm
Koja tuga.
Sad dok dijelovi dođu ......
Post by: zokizo on July 24, 2018, 07:12:27 pm
Frenky, ne throttle hold nego sam aktivirao rescue umjesto self levela i vertikala ful pitch i ful gas, dok sam ja skuzio sta je vec je bilo kasno, plus kad sam dosao doma skuzim da switch na stanici kad ga malo taknes mijenja pozicije sam, bank 1 bank 2, al dobro je je proslo svi skupi dijelovi su prezivjeli :) kontroler je spirit, i sa 100 rescue funkcija se zatuces
Post by: frankycro on July 24, 2018, 10:38:18 pm
Uh, pa zar je to još jedan slučaj gdje od rescue-a više štete nego koristi? Čekaj, ako ga je rescue izravnao i dodao kolektiva znači išao je otprilike ravno u zrak i nisi znao u tom momentu što se desilo pa si u panici lupio hold ili je sam rescue odabrao neku putanju prema zemlji?
Post by: zokizo on July 25, 2018, 10:17:07 am
Stavio u rescue (mislio sam da je SL) i zavrtio blejdove i odjednom samo vertikala  ful gas, prije toga sam jos doma neke postavke mijenjao i mislio da sam nesto krivo namjestio pa mi rescue nije bio ni na kraju pameti da ga iskljucim, i jos radi sjebanog prekidaca je u zraku mijenjao bank 1 i bank2, pa je poceo radit piruette i tick toe i mislim da su se tad linkovi otkacili i blejdom si otkino rep i onda pad, izgledalo je na trenutke ko da ga tareq vozi :)
Post by: zokizo on October 27, 2018, 05:22:00 pm
Ovaj put djed mraz donio geolink
Ide test pa napisem kako radi
[emoji4](https://uploads.tapatalk-cdn.com/20181027/4c3ab9c58be968351e4d6be049788fc8.jpg)(https://uploads.tapatalk-cdn.com/20181027/74ef8ccc0de5ff0d793e546d1da569e6.jpg)(https://uploads.tapatalk-cdn.com/20181027/9951b607483cdfd0fd17ba725bcdcba1.jpg)
Post by: frankycro on October 28, 2018, 01:34:00 am
Zanimljivo! Ali pripazi na jednu stvar, kod helića bilo kakva pomagala osim standardnog FBL-a koji se u osnovi oslanja samo na žiroskope dakle pomagala kao što su attitude, auto level i position hold mogu dok je helić na zemlji napraviti pre korekciju i izvrnit ga na neku stranu, prvenstveni razlog za tu pojavu je to što je patern vibracija drugačiji dok helić vrti rotor a stoji na zemlji, čak i kada je sve dobro izbalansirano mnogobrojna iskustva govore da setovi senzora kao što su akcelerometri mogu biti zbunjeni u takvim situacijama ta tada zadriftaju, dakle preporuka je helić poletjeti u "manualnom" modu gdje rade samo žiroskopi pa tada uključiti ostalo. Ne kažem da je to nužno da će se dogoditi, ali pripazi, također se nadam da su to poriješavali na takvim kontrolerima novijeg datuma.
Ajd baš javi kad isprobaš...
Post by: zokizo on October 28, 2018, 07:56:08 am
U self levelu kad polijecem nisam primjetio nikakve probleme, gps hold, rth sam stavio na posebne switcheve pa kad budem 2m u zraku ih aktiviram, javim kako je proslo malo je sranje vrijeme pa ce pricekat
Post by: davor on October 28, 2018, 08:00:33 am
Pred deset godina je bio aktualan skookum bl 720 sa gps senzorom. Nisam imao love da ga kupim pa sam uzeo sk540.
U isto vrijeme sam imao i brain, zakljucio sam da brain je bolji, i sve skupa zamijenio s vbarovima  :D . Taj rescue na brainu nije bas radio uvijek kako treba, sve je trebalo biti dobro izbalansirano, i onda bi funkcioniralo prvih par minuta a poslije bi sto kaze franky akcelerometri oddriftali i stvar vise ne radi kak treba. Mislim da je magija u kalmanovom filteru koji razabire sto je signal a sto sum, a za to treba procesorske snage. Sad je hardver jaci, a i senzori su napredovali pa mozda ...
Mislim da onaj francuz sto je radio developing na brainu sad radi esprit?
Mozda bi uzeo tu kombinaciju ako sad radi kak treba (sad kao imam love).
Post by: zokizo on October 28, 2018, 08:57:51 am
Spirit je dosta vremena na trzistu, ovo malo sta sam s njim letio meni radi super (nisam strucnjak u letenju helicem, hover malo lijevo malo desno i to je to) gps modul je poprilicno nov na trzistu i ovako na oko za razliku od dji naza gps je poprilicno veci a i tezi, mislim da su oni unutra ubacili jos neke elektronike koja bi trebala rijesavat probleme, malo sam po you tube-u gledao ostalu ekipu i demonstracije i cini se da ok radi. Nisam dugo vremena vozio helice, pa polijecem u self levelu da ne ubijem heli odmah i stvarno nikakvih problema
Post by: frankycro on October 29, 2018, 01:05:11 am
Odlično, ipak je to 32 bitni ARM, trebao bi s lakoćom filtrirat podatke sa akcelerometara, kad poletiš ako uspiješ opali i koji video za forum, jako malo letova sa helićima ima ovdje.  8)
Post by: zokizo on October 29, 2018, 07:27:33 am
Budem budem :)
Post by: zokizo on January 01, 2019, 01:37:51 pm
Nakon dosta vremena ustimao heli i spirit fbl, ukratko vilica do poda kako radi, od prije par godina kad sam se igrao sa spartan quarkom, ovo danas je otislo tolko naprijed da sam impresioniran, od coaxial moda scale, selflevel, gps funkcije
Drzanje repa, jos je danas bio neki vjetar i heli je radio kao da ga nema, tople preporuke za spirit fbl kontroler, a i kit :)  sve naj naj u 2019  zivjeli
Post by: frankycro on January 01, 2019, 04:39:00 pm
Ajde baš mi je drago da si ga uštimao, sad samo gas... pardon... kolektivni  :)  i također sve naj u 2019.
