Post reply
Something happened, review it here:
  • Warning: this topic has not been posted in for at least 120 days.
Warning! This topic is currently/will be locked
Only admins and moderators can reply.
shortcuts: alt+s submit/post or alt+p preview
Attachments and other options
Add files by dragging & dropping or selecting them Add files
Attach:
(Clear attachment)
(more attachments)
Allowed file types: doc, gif, jpg, mpg, pdf, png, txt, zip
Restrictions: 15 per post, maximum total size 8,192 KB, maximum individual size 2,048 KB
Note that any files attached will not be displayed until approved by a moderator.
Topic Summary
Posted by bozoou - January 01, 2018, 11:21:03 am
Uspio sam da mi se pokaze devices u Zadigu, i drzao sam boot pins i tada da mi FC prikaze kao bootloader ....ali svejedno mi nakon toga u cleanflightu nije prikazivao DFU opciju gore desno.
I onda sam sto varijanti isprobavao do kada cu drzati pinove i jednom nehotice instaliram driver preko mouse devices xd ...i sad mi miš ne radi. To je bilo zadnje jucer, nadam se sa ce se mis lako vratiti u život....al nemam pojma o čemu se tu radi. Jesu to driveri za miš u igri...ili za usb port :/
Posted by Ikarus - December 31, 2017, 10:21:33 pm
Samo dok ukljucujes usb i cim ti prikaze dfu, mozes pustit
Posted by bozoou - December 31, 2017, 08:08:09 pm
Pozdrav,
ne kužim kako se flasha  F3 Femto FC. Do sada sam flashao samo jednom jedan drugi FC i to je prošlo uspješno, ali s ovim sam zapeo.
Znači slijedim upute official of FCa: http://img.banggood.com/file/products/20161102215004F3%20femto%20manual%20V1.1.pdf
..no kada instaliram taj "Zadig" (čemu god to služilo) ...mislim da se ne desi što bi se trebalo desiti. ...jer prilikom instalacije istoga imam poruku "0 devices found".
Također ova uputa iz gornjeg manuala:
Place the board into DFU mode by shorting out (soldering or screwdriver) the boot pins on top of the board .Your device will be detected as a STM Device in DFU mode (or STM BOOTLOADER).
...me buni.
Od kojeg momenta do kojeg bi ja trebao držati boot pinove u spoju?
