Post reply
Something happened, review it here:
  • Warning: this topic has not been posted in for at least 120 days.
Warning! This topic is currently/will be locked
Only admins and moderators can reply.
shortcuts: alt+s submit/post or alt+p preview
Attachments and other options
Add files by dragging & dropping or selecting them Add files
Attach:
(Clear attachment)
(more attachments)
Allowed file types: doc, gif, jpg, mpg, pdf, png, txt, zip
Restrictions: 15 per post, maximum total size 8,192 KB, maximum individual size 2,048 KB
Note that any files attached will not be displayed until approved by a moderator.
Topic Summary
Posted by ddark - February 24, 2012, 11:07:15 pm
Uh, nemoj onda, snadji se nekako za drugo vozilo
Posted by Zdenko - February 24, 2012, 11:05:51 pm
Osim ako je  u pitanju F1, prolaziš
audi sa eibach pro kit 50mm naprijed spusten  :'(
Posted by ddark - February 24, 2012, 11:01:14 pm
Posted by Zdenko - February 24, 2012, 10:54:02 pm
Evo ti karta
jel mi treba jeep do gori il mogu sa malo nižim autom doć tamo?
Posted by Zdenko - February 24, 2012, 10:52:43 pm
Mislim da sa ovom stanicom to nebus uspio sloziti.
Nemas dodatnih prekidaca i mixeva za idle-up.
Jel ima u stanici throtle i ccpm miksanje? Pitch curve i to?
šališ se, jelda? :o , nemam pojma o stanici.....
edit: evo uputa.
http://data.robbe-online.net/robbe_pdf/P1122_1-F4091.pdf
mogu dodati prekidače za miksanje.
imam doma 2 viska
Posted by ddark - February 24, 2012, 09:44:55 pm
Evo ti karta
Posted by ddark - February 24, 2012, 09:32:42 pm
Nisam htio komentirati dok ne vidim ali cini mi se da si preplatio stanicu  :(
Posted by Wespen - February 24, 2012, 09:28:52 pm
Posted by ddark - February 24, 2012, 09:09:40 pm
Ako dodjes oko 12 sigurno ce netko biti tamo a kako doci to ti je vec malo teze ali probat cu: kreni prema Pagu i skreni prema Ninu na Mazijama, kad prodjes Zeravu vozi jos mozda kilometar i tocno na mjestu gdje dalekovod prelazi cestu skreni desno na bijeli put. Nakon nekih 50-100 metara skreni lijevo bijelim putem i vozi do kraja ( nemoj odustati, cinit ce ti se da si se izgubio ali bez brige, nisi) Na kraju tog puta je livada (kreni na desnu stranu, vidjet ces auta ubrzo)
Posted by Zdenko - February 24, 2012, 09:02:41 pm
Sutra ti se leti u Ninskim Stanovima, pokupi svu opremu i donesi a naši majstori za heliće će ti sigurno rado pomoći. Ako bude sve u redu sutra se među ostalim očekuju tri "maiden flight-a" na livadi, dva stiroporca i jedan benzinac.
hvala na info.
Kada se leti, gdje tocno i kako da vas nadjem
Posted by ddark - February 24, 2012, 08:40:36 pm
Posted by Wespen - February 24, 2012, 08:08:40 pm
I obavezno pogledaj finless Bob-a na HeliFreaku.
Imas tamo stelanje stanice 101
Posted by Pilot2132 - February 24, 2012, 06:54:23 pm
http://www.rc-pilot.info/forum/forum_topics.asp?FID=20
Tu se registriraj,ekipa je aktivna,imas tu ljudi koji se razumiju u helice i stanice,a ekipa redovno ide letit kolko vidim  ;)
Posted by Zdenko - February 24, 2012, 03:19:14 pm
Dobro, nije sad da neznam letiti ni malo, kužim ipak nekog vraga  :'(
Do sada sam imao više stanica, ali nikad ove vrste, koje treba posebno programirati, pa me to malo muči.
E, i vezano za žurbu, nije žurba radi mene, nego ženetina već frkće da dva tjedna heli stoji na ormaru, a bilo mi ka hitno za kupiti.
Nadodao sam u naslov, ja sam iz Zadra.
Posted by Vedran-Ri - February 24, 2012, 03:03:30 pm
mene je nestrpljenje dosta puta kostalo
ja sam isto mislio ma sta sad drugi znaju ali ipak su znali  ;)
