Post reply
Something happened, review it here:
  • Warning: this topic has not been posted in for at least 120 days.
Warning! This topic is currently/will be locked
Only admins and moderators can reply.
shortcuts: alt+s submit/post or alt+p preview
Attachments and other options
Add files by dragging & dropping or selecting them Add files
Attach:
(Clear attachment)
(more attachments)
Allowed file types: doc, gif, jpg, mpg, pdf, png, txt, zip
Restrictions: 15 per post, maximum total size 8,192 KB, maximum individual size 2,048 KB
Note that any files attached will not be displayed until approved by a moderator.
Topic Summary
Posted by Niram - June 19, 2011, 11:30:42 am
jeftin a dobar sim kabel ti je ovaj
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=14304
Nesto skuplji ali i dalje jeftin... i naravno daleko daleko bolji sim kabel je ovaj:
http://www.dealextreme.com/p/usb-2-0-almighty-flight-simulator-dongle-51480
Posted by P0rk - June 19, 2011, 10:26:53 am
EDIT: Saznao sam da idu 8 AA baterija,tako da punjac i baterije prekrizite,samo mi sim kabl treba
Poklopac od baterije se neće dat zatvorit sa AA baterijama - barem je kod mene to bio slučaj.  Poklopac i spremnik su rađeni za neke kineske AA  :D
Stavio sam ovu http://www.rctimer.com/index.php?gOo=goods_details.dwt&goodsid=483&productname=  8)
Posted by zeRO - June 18, 2011, 11:21:15 pm
AA baterije su ok za prvu silu, al ne i dugoročno, posebice ak uzmeš u obzir cijenu Li-Po baterija. Ako se misliš bavit hobijem, a očito misliš kad si već tu, trebat će ti Li-po punjač (kojeg, između ostalog i tražiš), pa zašto onda ne spojiti ugodno s korisnim i nabavit si Li-Po pack za stanicu?
Najbolje što se nudi za malo para je (plane gotovo u trenu, zato se strpi i ugrabi kad stigne na stock):
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=7346
Ako ti se neda čekati:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=17762
http://www.leaderhobby.com/product.asp?ID=9394001223767
Što se kabla tiče, zaboravi na jeftine s ebaya.Uzmi si ovo i miran si:
http://www.flyfreak.net/simulatori/zakon-simulator-kabel/
Punjača ima svakakvih, ja ti osobno mogu preporučiti ACCUCEL 6, mislim da ti nešto više od toga neće ni trebati:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=7028
naravno, trebat ćeš si nabaviti i neki ac/dc adapter od min 12V i nekih 5-6A. Imaš ih na ebayu i HK-u.
Posted by Juroxzg3 - June 18, 2011, 09:41:36 pm
Evo,Uskoro cu kupiti Turnigy 9x,neznam koju bateriju da kupim,koji sim kabl da kupim a kamoli koji,ako je moguc direktan link do te baterije,kabla i punjača
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8992
