Post reply
Something happened, review it here:
  • Warning: this topic has not been posted in for at least 120 days.
Warning! This topic is currently/will be locked
Only admins and moderators can reply.
shortcuts: alt+s submit/post or alt+p preview
Attachments and other options
Add files by dragging & dropping or selecting them Add files
Attach:
(Clear attachment)
(more attachments)
Allowed file types: doc, gif, jpg, mpg, pdf, png, txt, zip
Restrictions: 15 per post, maximum total size 8,192 KB, maximum individual size 2,048 KB
Note that any files attached will not be displayed until approved by a moderator.
Topic Summary
Posted by Coljo - February 14, 2014, 09:08:34 pm
Sve pet, ali 2 ampera moze biti premalo za bec! Spojis 4 serva i moguce je da se regler spregrije i iskljuci skroz, to znaci model u pod!
Posted by miso227 - February 14, 2014, 12:37:33 pm
Tako je, kupujes motor koji sa određenom elisom za njega,ima dovoljno velik potisak, da bi mogao vuči tvoj model, recimo sa 8x4 elisom ima potisak 1000g a tvoj model recimo 800g sa svom elektronikom, znaci da imaš viska potiska, tj snage.
Posted by toni24 - February 14, 2014, 12:16:32 pm
Pregledo sam sinoc to po youtubu.. Sad je jasnije  :D
Ovo sam mislio uzet, i pise dole da regler ima  BEC Output : 5V/2A
A i skoro svi sad vec to odma imaju.
http://www.ebay.com/itm/EMAX-CF2812-1540KV-Brushless-Motor-Firedragon-30A-ESC-for-RC-Multicopter-Plane-/300956678983?pt=Radio_Control_Parts_Accessories&hash=item46126a7b47
I vidim da pise, Recommended model weight 200-800 g..
Pa mi palo na pamet jel ima mozda kakva tablica ili nesta slicno sa gramazom modela, tezina, npr. tezina aviona 600 g. i onda taj i taj motor te jacine se preporucuje?
Posted by miso227 - February 14, 2014, 08:39:54 am
Nađi na youtube koji video imaš sve objašnjeno kako se spaja i kako to sve radi
Posted by miso227 - February 14, 2014, 08:37:33 am
Prijemnik ti dobija napajanje od reglera, ni slucajno spajati direktno neku bateriju koja nije predviđena za prijemnik.
Posted by Coljo - February 14, 2014, 01:47:56 am
Ovako nesto si kupi, to ti daje napajanje za reciver i ujedno je to regler za motor!
To ce ti biti super sada i posilje!
http://www.hobbyking.com/hobbyking/store/__45019__Hobbyking_YEP_40A_2_6S_SBEC_Brushless_Speed_Controller_EU_warehouse_.html
Posted by gregor - February 13, 2014, 09:32:52 pm
kupi esc s becom ako letis na elektro ako ne kupi samo bec to ti smanji napon na 5v
Posted by toni24 - February 13, 2014, 09:15:47 pm
Evo da se pohvalim, stigo je jucer FlySky th9x, jos sad da dodu kablovi za simulator. I onda u nabavku elektronike i u izradu..  :)
E sad sljedece sta me zanima da ne radim bezveze novi post za to malo, na recieveru mi pise od 4.5 do 6.5 volti.. Kad bi ja stavio bateriju 7.4 ili 11.1 v, on bi pregorio jel? 7 bi jos izduro ali 11.
To mi sad nije malo jasno.. Ili ima nesta jos sto se mece da smanji?
Posted by toni24 - February 09, 2014, 03:02:59 pm
Ma mislio sam ako netko ima tu stanicu da kaze kakva je i to, ali dobro..
Narucio sam Flysky x9 ..   Hvala  :)
Posted by toni24 - February 02, 2014, 07:50:10 pm
Pozdrav svima..
Evo ja sam novi ovdje na forumu, poceo bi se malo ozbiljnije bavit ovim hobijem, imam neko iskustvo u izradi modela. Radio sam makete broda od takozvanog furnira, to je bilo ovako samo za ukras.. :)
E sad me zanima vase misljenje o toj stanici, iskustva.. Flysky FS-T6-RB6 6 ch, cito sam po stranim forumima, puno toga pretrazio, ali zanima me ovdje kod nas dali ju netko ima, kako se pokazala?  Neki kazu
da ima problema sa dometom..
 http://www.ebay.com/itm/Mode-2-2-4ghz-RC-Helicopter-Plane-Flysky-Transmitter-TX-RX-combo-6ch-FS-T6-RB6-/121204130256?pt=Radio_Control_Parts_Accessories&hash=item1c385441d0
FlySky FS-T6 2.4ghz 6ch Computer Transmitter
