Frame: tarot 650 sport sa električnim retraktima i pokrovom
FC: djy Naza v2 +osd+gps
Motori: djy e800 350kv
ESC: djy 620s
Prijamnik: Frsky x8r
Video vtx: Eachine TS832 600mW 5.8 gHz (https://www.banggood.com/Eachine-TS832-FPV-5_8G-32CH-600mW-Wireless-AV-Transmitter-p-975425.html?rmmds=myorder (https://www.banggood.com/Eachine-TS832-FPV-5_8G-32CH-600mW-Wireless-AV-Transmitter-p-975425.html?rmmds=myorder))
Antene: Realacc 5 dbi (https://www.banggood.com/Realacc-5_8Ghz-5dbi-50w-RHCP-4-Leaf-FPV-Antenna-SMARP-SMA-Red-p-1091104.html?rmmds=myorder (https://www.banggood.com/Realacc-5_8Ghz-5dbi-50w-RHCP-4-Leaf-FPV-Antenna-SMARP-SMA-Red-p-1091104.html?rmmds=myorder))
Telemetrija: Frsky FLVSS lipo sensor i 3DR Radio Telemetry Kit 433Mhz
OSD: Mini OSD
Stanica: Turnigy 9xr pro sa Frsky XJT modulom i 7db patch antenom za veći domet. Zajedno sa zasitnim koferom iz Bauhausa. Lijevi gimbal je zamjenjem za 3 axsis gimbal
Propeleri: dji 1345s
Ekran: Field view 777rx32 sa sun shade-om i držačem za stanicu (https://hobbyking.com/en_us/7-inch-800-x-480-5-8ghz-receiver-fpv-monitor-fieldview-777-rx32.html (https://hobbyking.com/en_us/7-inch-800-x-480-5-8ghz-receiver-fpv-monitor-fieldview-777-rx32.html))
Baterije: Multistar 12000 mAh 6s 10C
3s 2200 mAh za staicu (https://hobbyking.com/en_us/turnigy-9xr-safety-protected-11-1v-3s-2200mah-1-5c-transmitter-pack.html (https://hobbyking.com/en_us/turnigy-9xr-safety-protected-11-1v-3s-2200mah-1-5c-transmitter-pack.html))
i 3s 1000 mAh za ekran makar se može koristi i baterija iz stanice
Punjač: Imax B6 sa parallel charging boardom
Cijene:
Komplet svega navedenog: 3000 kn
Dron nije moj već od kuma mog, letio je svega dva puta, nema vremena radi na terenu, u izgradnji je, žena, djeca i tako to samo ga premiće po kući
Bump 2500kn sve komplet!
