Post reply
Something happened, review it here:
  • Warning: this topic has not been posted in for at least 120 days.
Warning! This topic is currently/will be locked
Only admins and moderators can reply.
shortcuts: alt+s submit/post or alt+p preview
Attachments and other options
Add files by dragging & dropping or selecting them Add files
Attach:
(Clear attachment)
(more attachments)
Allowed file types: doc, gif, jpg, mpg, pdf, png, txt, zip
Restrictions: 15 per post, maximum total size 8,192 KB, maximum individual size 2,048 KB
Note that any files attached will not be displayed until approved by a moderator.
Topic Summary
Posted by kish89 - June 05, 2010, 12:51:13 pm
Dakle kontrola preko posebne palice nije moguca?
Posted by 3xp3rt - June 05, 2010, 12:32:13 pm
Mislim da mozes dva jedino na 3. kanal preko Y kabla, ali nisam siguran, nek me neko ispravi ako grijesim...
Posted by kish89 - June 04, 2010, 10:14:07 pm
rjeseno, samo je 2 trebalo prebacit :)
nego jos jedno pitanje
jel je moguce na prijemnik spojit dva ESCa, jedan tamo gdje i inace ide a drugi recimo umjesto elerona?
Posted by kish89 - June 04, 2010, 08:49:54 pm
ok probat cu hvala
Posted by Tomi - June 04, 2010, 08:02:12 pm
Evo našao sam video na jubitou, mislim da samo "2" treba prebaciti i gasi se CPM mix.
Posted by Tomi - June 04, 2010, 04:55:32 pm
Imaš ispod druge ili treće baterije (od lijeva) još 2 dip switcha, e sad ne znam točno koji, budem pogledal kad dođem doma sa posla pa javim.
Posted by devastator - June 04, 2010, 04:34:15 pm
prekidači služe tome  da  se  prčka  po  njima  nemaš kaj tu  zaj***t
več  si  zajebal  kad si  kupil  takvu  stanicu  jeftino  neznači  i  dobro
Posted by robert32 - June 04, 2010, 04:05:09 pm
ma sta drhtis,samo prckaj...
Posted by kish89 - June 04, 2010, 03:33:14 pm
S obzirom da je u stanici lipica 20C , i udar postene struje je moguc ako dobro navlazim prste :)
Cekam covjeka da odgovori, jer on ocito zna sto treba napraviti, necu bezveze prckat po prekidacima, makar ne vjerujem da se ista ozbiljno moze desit.
Posted by 3xp3rt - June 04, 2010, 03:21:13 pm
Pa brate sto ne probas, nece te struja udariti...
Posted by kish89 - June 04, 2010, 02:52:40 pm
35mhz
i daj mi reci dok iskljucim CCPM, onda svaki kanal mogu zasebno kontrolirat?
kako treba postavit dip switch?
Posted by Tomi - June 04, 2010, 01:15:28 pm
Colective pitch mix - tri serva rade zajedno i dižu ili spuštaju swash plate (i ostalo). Hm, jel to 2,4GHz verzija ili ona sa kvarčevima ? Za 2.4 GHz verziju ne znam, ja imam na 35 MHz i imam 4 dip switch-a, jedan je za uključivanje i isključivanje CCPM mix-a.
Posted by kish89 - June 03, 2010, 11:42:07 pm
hmm. a cemu sluzi uopce taj CCPM mix ?
vidio sam da kod baterije ima jedan DIP switch, mozes mu birat jedino 1 ili 0, to je valjda to , ali kako dalje?
Posted by Tomi - June 03, 2010, 09:15:35 pm
Za druge heliće ne znam ali ako se ugasi CCPM mix može na avion. Potraži na netu uputstva, ja sam već zaboravil kako, znam da ima prekidače ispod baterija ali ne znam točno koji treba.
Posted by robert32 - June 03, 2010, 05:46:30 pm
kolko ja znam,za helic da,a za avion ne,vjerojatno ce ti neko drugi to bolje pojasnit..
