pozz ekipa naime poceo sam raditi RC katamaran o 80cm duzin zanima me sto mi je sve potrbno da mi provukao osovinu od motora do propele koji dijelovi
imaš po 30usd kompletne armature pa prostudiraj
http://www.r2hobbies.com/rc-accessories/for-boats.html (http://www.r2hobbies.com/rc-accessories/for-boats.html)
pozz i ugodna gradnja
HVALA hehe sada se bacam po ubrzanom postupku na plastificiranje mog brodica :) kad to zgotovin tk onda dolazi na red ovo
dali je ovo kompaktibilno i dovoljno za katamaran duzine 80cm sirine 24cm i tezine cc 1,3kg
http://www.r2hobbies.com/25-5-rc-ep-deep-vee-arowana-mono-1-racing-boat-hardware-kit-rudder-shaft-propeller-wooden-mount.html (http://www.r2hobbies.com/25-5-rc-ep-deep-vee-arowana-mono-1-racing-boat-hardware-kit-rudder-shaft-propeller-wooden-mount.html)
http://www.r2hobbies.com/eurgle-rc-boat-2445-3500kv-370l-bl-brushless-inner-runner-motor-with-water-cooling-system.html (http://www.r2hobbies.com/eurgle-rc-boat-2445-3500kv-370l-bl-brushless-inner-runner-motor-with-water-cooling-system.html)
ova ti osovina bolje paše
http://www.r2hobbies.com/32-3-rc-ep-epoxy-fiberglass-godspeed-u-catamaran-racing-boat-hardware-kit-rudder-shaft-propeller.html (http://www.r2hobbies.com/32-3-rc-ep-epoxy-fiberglass-godspeed-u-catamaran-racing-boat-hardware-kit-rudder-shaft-propeller.html)
sa tim motorcicem si i nebus bas pomogao.
;D mi kazes onda koji motoric da bude zivahan i cc 40-50km/h ako to nije previs brzo po ovom sto si dao savijet meni bi trebao motor sa osovinom 5mm
http://www.ebay.com/itm/LEOPARD-Boat-3674-KV2200-4-Poles-Brushless-Motor-IM116-/300557027769?pt=Radio_Control_Parts_Accessories&hash=item45fa9849b9 (http://www.ebay.com/itm/LEOPARD-Boat-3674-KV2200-4-Poles-Brushless-Motor-IM116-/300557027769?pt=Radio_Control_Parts_Accessories&hash=item45fa9849b9)
na 4s sa propelerom od 42mm...
a sto kazesna ovaj motor
http://www.r2hobbies.com/eurgle-rc-boat-3660-1800kv-540l-bl-brushless-inner-runner-motor-with-water-cooling-system.html (http://www.r2hobbies.com/eurgle-rc-boat-3660-1800kv-540l-bl-brushless-inner-runner-motor-with-water-cooling-system.html)
ova osovina
http://www.r2hobbies.com/25-5-rc-ep-deep-vee-ocean-force-mono-racing-boat-hardware-kit-rudder-shaft-propeller-wooden-mount.html (http://www.r2hobbies.com/25-5-rc-ep-deep-vee-ocean-force-mono-racing-boat-hardware-kit-rudder-shaft-propeller-wooden-mount.html)
i ovo mislim da bi mi trebalo
http://www.ebay.com/itm/RC-Model-Boat-Submarine-Universal-joints-ID-4mm-X-5mm-Coupling-4mm-To-5mm-/280938171651?pt=Radio_Control_Vehicles&hash=item4169384d03#ht_1620wt_952 (http://www.ebay.com/itm/RC-Model-Boat-Submarine-Universal-joints-ID-4mm-X-5mm-Coupling-4mm-To-5mm-/280938171651?pt=Radio_Control_Vehicles&hash=item4169384d03#ht_1620wt_952)
molio bi komentar
Za motor neznam...nisi reko na koji napon ces ga spojit.
Sent from my HTC Wildfire S A510e using Tapatalk 2
novi sam u ovom tako da se ne putim toliko u to nesto bi ugradio da nebude sad profi ali ni smece
evo par slika od moga uradka:
(http://img441.imageshack.us/img441/5141/brodic.jpg)
dali bi ovaj prop bio dobar
http://www.r2hobbies.com/4-43-26-09mm-rc-ep-boat-plastic-propeller.html (http://www.r2hobbies.com/4-43-26-09mm-rc-ep-boat-plastic-propeller.html)
na motor
http://www.hobbyking.com/hobbyking/store/__25091__3660SL_3180kv_Brushless_Inrunner_WaterCooled_.html (http://www.hobbyking.com/hobbyking/store/__25091__3660SL_3180kv_Brushless_Inrunner_WaterCooled_.html)
bravo bravo... jako dobro odrađeno.... daj stavi i sliku odispod.....
vlakna??
vlakna??
konstrukcija broda je napravljena d šperploće 5mm i presvuceno balzom od 2mm nakon cega je cili brod namazan jednim slojem staklene vune u kombinaciji sa smolom a drugi sloj je isao samo smola kad malo uvatim vrimena otvorit cu novu temu i opisati sve sa slikama kako je brodic nastao jedno znam je tezi od tvornickih ali bocu od 1.5L drzi ka bebu doslovno mozes bubnut jos...
može komentar na ovo sve
i na to bi isa baterija 4s od 5000mAh
http://www.r2hobbies.com/rc-boat-fiberglass-25mm-52mm-540-motor-mount-with-water-cooling-system.html (http://www.r2hobbies.com/rc-boat-fiberglass-25mm-52mm-540-motor-mount-with-water-cooling-system.html)
http://www.ebay.com/itm/universal-joint-coupling-5mm-to-4mm-rc-model-boat-scale-/160796573408?pt=UK_ToysGames_RadioControlled_JN&hash=item257038fee0 (http://www.ebay.com/itm/universal-joint-coupling-5mm-to-4mm-rc-model-boat-scale-/160796573408?pt=UK_ToysGames_RadioControlled_JN&hash=item257038fee0)
http://www.r2hobbies.com/turborix-cnc-aluminum-sailing-boat-servo-wheel-for-futaba-servo-25t-1pc.html (http://www.r2hobbies.com/turborix-cnc-aluminum-sailing-boat-servo-wheel-for-futaba-servo-25t-1pc.html)
sad dali je potrebno uzivati onaj set za montazu motora ili je dovoljno sam napraviti???
bili ovaj motor izdrza na bateriji od 5000mAh voziti 20min cc da nije kontsntno ful gas trazim neko okvirno negledamo u minutu hehehe
stigli dijelovi i sada krece montaza bude i slika :) prvi katamaran na krutu osovinu pa nek mu bog pomogne :)))
samo jako pazi sa podmazivanjem.... : "OD VIŠKA GLAVA NE BOLI!"
Istina da treba podmazati,samo pazi s čim podmazuješ i sa kojom masti kaj se ne shebeš
kak sam se ja pa mi se mast zapalila i zapekla ,a onda je bilo puno sranja.
Od pregaranja motora do taljenja osovine i ležajeva... ;)
a koju si to mast toto koristil???
Prije ili sad??Sve kaj ne peče za rit. ;)
Sad mješam grafitnu i litijsku
i pokazalo se super jer ne mijenja na svojstvu.
Dok je bila samo grafitma jednostavno nije izdžala jer se stvrdnula.
evo koja slika 8)
(http://imageshack.us/a/img832/7297/imag0137km.th.jpg) (http://imageshack.us/photo/my-images/832/imag0137km.jpg/)
slika sa ugradnjom osovine i kormila
(http://imageshack.us/a/img837/8084/imag0152yk.th.jpg) (http://imageshack.us/photo/my-images/837/imag0152yk.jpg/)
(http://imageshack.us/a/img710/958/imag0153v.th.jpg) (http://imageshack.us/photo/my-images/710/imag0153v.jpg/)
(http://imageshack.us/a/img841/7906/imag0155eq.th.jpg) (http://imageshack.us/photo/my-images/841/imag0155eq.jpg/)
(http://imageshack.us/a/img842/5409/imag0156zt.th.jpg) (http://imageshack.us/photo/my-images/842/imag0156zt.jpg/)
eto danas ide plastificiranje ispod broda pa test u vodi :) a onda cu stavit slike od ugradnje motora koji ide za koji dan
Pripazi na kut osovine i koliko ti je propeler u vodi,tj koliko je daleko od krmenog dijela.
Ja bi u tvom slučaju stavil što manji kut tak da ti na kraju izađe polupodvodni pogon i s time ćeš imat manju porošnju i manje će se mučiti motor.
ovo je kruta osovina :) tako a jedino ovako moz ici ovo je kut od 7 stupnjeva
Pa i kod mene je kruta osovina,imam 6 stupnjeva nagib.
Spoji motor i kad imaš cjelinu spusti ga skroz do dole pa izmjeri onda i kad fiksiraš podloži ga barem 1mm tak da ima malo lufta ali samo zato da ga lakše kasnije skineš.
Ako ti kaj smeta da ga spustiš pobrusi,jer ako ti bu preveliki kut samo buš imal problema.
a sto reci toto hehehe budemo vidili za koji mj kad se sve kupi pa kak ce to ici samo sada na njmu je prop od 4cm i mislim da ce to biti preveliko za trnutni motoric koji kaze da ima 1200W i 1800 okretaja a planirane su baterije 4s
Vjerojatno bu ti taj prop prevelik za taj motor.
Kreni sa nekim 34,35mm pa izmjeri potrošnju.
Na početku sam i ja krenul sa večim propom pa sam za 10 min skuril motor. ;)
dali mi neko moze reci sto znaci na baterini npr 30C to nemogu ubrat
reci mi jeli mozes izmiriti struju obicnim ampermetrom i na kojoj poziciji :)
Ovisi kakav instrument imaš.
Naruči si radije watt metar,a mislim da ti ga netko sa foruma prodaje.
Cijena na HK ti je oko 20$ i onda vidiš wate,ampere .
Trebal bi isto tak znati podatke od motora pa da vidiš dal si ga preopteretil ili ne.
Maksimalna struja koju bateriju može dati, ako je npr. baterija 2200mAh, može dati 66A.
2.2A×30
Pisalo se o tome po forumu bar desetak puta, koristi tražilicu
To ti je broj koji označava koliko možeš opteretit bateriju.
30 pomnožiš za kapacitetom baterije.
npr: 2200mah piše na bateriji i to pomnožiš sa 30 i dobiješ 66000mah.
To bi značilo da bateriju možeš max opteretiti sa 66 amp.
Kaj ti puno znači jer ako ti motor na ful gasu vuče 100AMP,ode baterija u PM. :D
neznam al ovaj kut osovine mi zgleda puno veći nek si izmjeril.....
slušaj kaj ti toto veli....
sprobaj skupit tu kilažu koju bude imal gotov (olovo,komad željeza ili bilo kaj bi imalo od prilike tu težinu) stavi ga u vodu i ako ti je propeler dosta/previše pod vodom digni gore osovinu....
ja sam tak složil osovinu na high windu i.... kaj i?.... "mešalica"
jednostavno se čamac gutil....kak da sam ga stavil u tijesto za kolač a ne vodu..... :D :D :D :D
P.S. : hvala toto na informaciji.... ja sam isto namjeraval staviti grafitnu....
A BOGAMI JE NEKIH 7-8 STUPNJEVA.... heh izgleda puno veće...... ???
to znaci da ova baterija pase na moj motor na koji ide 60A ova baterija po tom izdrzaca 100A motor
http://www.hobbyking.com/hobbyking/store/__8580__ZIPPY_Flightmax_5000mAh_4S1P_20C_.html (http://www.hobbyking.com/hobbyking/store/__8580__ZIPPY_Flightmax_5000mAh_4S1P_20C_.html)
U pravilu je tak.
Možeš staviti 2 baterije od 25c majneg kapaciteta pa ih spajaš paralelno i dobiš istu stvar.
Pravilo je da baterije budu iste starosti,kapaciteta uglavnom sve isto.
ma di manjeg kapaciteta mogu uci samo dvije hehehe od 5000mah nema da stane u 15 min
Nemoj samo grafitnu jer nije za velike okretaje,bu ti izdržala ali bu se pregrijala i stvrdnula.
Koristi neku mast za ležajeve tipa litijska (tovatna) i pomješaj je sa grafitnom u omjeru 50:50.
Isprobano i radi s tim da sam se prije konzultiral sa mehaničarima na poslu i tak je to krenulo.....
osovina i kormilo smontirani i isprobano po opterecenjem i brodic kaze da drzi vodu :) wiii
(http://imageshack.us/a/img827/6348/imag0157zp.th.jpg) (http://imageshack.us/photo/my-images/827/imag0157zp.jpg/)
i par slika kako to pliva sa punom tezinom
(http://imageshack.us/a/img855/3370/imag0159ms.th.jpg) (http://imageshack.us/photo/my-images/855/imag0159ms.jpg/)
(http://imageshack.us/a/img827/3220/imag0160ex.th.jpg) (http://imageshack.us/photo/my-images/827/imag0160ex.jpg/)
što se tiće motora za njega pise da ide esc od 60A tako da bu uzel kako pise
evo i boja je pala nije puno ali je slatko :)
prije bojanje:
(http://imageshack.us/a/img40/3370/img3275c.th.jpg) (http://imageshack.us/photo/my-images/40/img3275c.jpg/)
posli bojanja:
(http://imageshack.us/a/img838/8559/img3282m.th.jpg) (http://imageshack.us/photo/my-images/838/img3282m.jpg/)
Super izgleda,samo sad ti sljedi pravi sex.
Težište,veličina propa,pa ak ti se desi kak meni da je slabi motor.
No rešil buš ti to... ;)
a motor je 1200W 60A 1800kv nadam se da bu to bilo dovoljno :) hehehe
Trebalo bi biti,ali nemoj odmah ići na veliki prop.
Ako nemaš s čim mjerit potrošnju kreni sa malim propom,pa probaj kolko se kaj zgrijalo,ako nije previše probaj sa večim itd.
dolazi mi istrument koji sam kupio u hobi kinga bas za to
pa bu ok
kaj si kupil?
kaj si kupil?
eto da se pohvalim stigla stanica servo i kontroler motora sve spojio i probao u kadi je da je radio na 12V i 1A koliko moze dati strujni adapte i a jos kada stigne baterija 4s :) ima da iskoci iz kade :) sutra malo poslikam pa stavin koju sliku a mozda i video :)
kaj si kupil?
a za mjerenje sam kupio ovo http://www.hobbyking.com/hobbyking/store/__10786__HobbyKing_HK_010_Wattmeter_Voltage_Analyzer_.html (http://www.hobbyking.com/hobbyking/store/__10786__HobbyKing_HK_010_Wattmeter_Voltage_Analyzer_.html)
Imam iso takvog,radi ok ,samo šteta kaj ne mjeri veču amperažu. :D
za sada ce me zadovoljiti :)) hehehe a kasnije cemo viti oce li biti jos jedan brodic :)) po imenu mystic c5000 ;)
evo decki stigle sve komponente za brodic jucer sam ga nabrzinu bacio u kadu cisto da bacim test da vidim koliko struje povlaci no u tom pokusaju sam skoto brod potopio jer toliko virova radi da jednostano to nece ici u kadi :))) moram cekad dok ozdravim pa cu ga u more sprobati baljda nece raditi balove ;)
ajde samo ti ozdravi :) da ga sto prije vidimo kako ide ;D
a evo ubacio koji lekadol u sebe i sada idem bateriju smistiti unutra i provuc cijevi za vodu
hehe,koja je tezina spremnog za voznju?
a bit je oko cc 2,5 - 3 kg
to je taman neka granica.
a drvenjak je presvucen plastikom tako da nemoze lakse :) sam brod ima oko 1 - 1,5kg
ma po meni je to ok,e sad iskusniji clanovi znaju bolje :D pohvala za samogradnju i izgleda mi jako ljepo :)
evo decki pao je prva voznja osjecaj je bio jeben jer znas da si to izgradio od same nule nisam jos testirao puni gas vec samo do pola i na pola gasa mi se dogada da mi prova ide dosta gori doli jel to treba dodati gasa da to prestane ili ???
da,sistem ti je isti kao kod pravih glisera-dok nejdu puni gas pramac(prova) im je dosta visoko no kad das ful gas on se mora ispraviti na vodi tj.glisirati po povrsini vode.
kad budes mogao nabaci koji video da vidimo kako ide :)
Može i nemora biti,nebuš tak dugo znal dok ga ne spizdiš ful gas,a isto tak ti može biti i CG u igri.
U mom slučaju je skakal i van iz vode,samo sam premjestil baterije bolje napred i sve ok.
evo i snimke :))
RC CATAMARAN ZADAR (http://www.youtube.com/watch?v=ArkZEDi8JzM#ws)
Pomakni cg prema napred,to bi trebalo riješiti problem. ;)
da toto je u pravu ;D
mozda ce zvucati glupo ali sto je to CG
CG-centar gravitacije.
Znači čamac je napred prelagan i diže se na zadnje kotače.
Otežaš ga bolje napred i nema više tu snagu,ali pomiči postepeno,ono probaj baterije,regler ili nekaj stavit malo napred pa buš videl.
probat cu ugurat nsto metalno pa cu vit jer bateriju nemogu da maknm ni mm iovak je stala u iglu :))
a sa kolikom tezinom da probam u vrh broda
Teško je to reči.
Probaj za nekih 200g,pa budeš videl kaj se dešava,ako prestane smanji malo i nađi mu neku granicu,a ako skače i dalje idi gore.
To je sad već igra,ali to je neizbježno....
budem veceras izrezo odredenu kolicinu tereta pa sutra probam na licu mjesta dodavat
eto ubacio ja njemu u provu nekih cc 400g i dobio sa da sa punim gasom brod iskace i do pola metra i leti do 2m imam filing da sam napravio avion a ne brod na 35sec pocinje sa opterecenjem 400g ovo prije je sa 200g
VIDEO0021 (http://www.youtube.com/watch?v=5iqgvzKDHHM#ws)
zanimljivo...
hidroavion? :)
i to drveni brod koji ima tezinu,, stavio sam jos tezine pa cemo vit sto ce biti
pokusamao sam svakako pomjerati tezinu ali on nikako da prestane skakati pa je tako i skok bio koban i pogodio kamen dakle brod stradao malo se drvo na provi doslovno rascvitalo mislim da odustajem od ovoga broda jer unutarnjem dijeli nema bas puno prostora za kemijati sa raspodijelom tezine
stvar je da tu ima xy mogućih "zašto" on skače
dodavanje mase naprijed očigledno ne pomaže previvše
ako imaš volje, popravi ga, pa probaj još kombinirati sa položajem i kutom osovine, kao i udaljavanjem/približavanjem propelera zadnjem dijelu trupa
ili se javi kolegi Race-u ovdje, on je imao sličan problem, njegov se nije letio gore, nego se sa dodavanjem gasa "zapikavao" u vodu
na kraju je to složio i išao je ko grom
ja dodam punu gas pa mi na osovini iskoce krajevi koji je drze u centru sad sam probao staviti manji prop sutra cu samo zakrpati rupu da ne pusta posto je to na vrhu nije non stop u vodi pa samo da provam kako ce se ponasati
ako nista drugo bar lipo zabice radi :)) hehehe okrenio kormilo on malo cupnio i naravno malo neznanja ja pustio gas i sposto bez gasa ne okrese nikako ravno u obalu sam mi je srce zaigralo
nemam puno iskustva u modelarstvu sto se ovakvih problema tice, al imam u stvarnim dimenzijama, nisam 100% siguran o kakvom se modelu radi, al ako je propela iza krme, onda smanjenjem trima treba umiriti pramac camca, (ako je pramac camca gledano s ljeve strane, elisu rotiramo u smjeru kazaljke na satu, znaci gornji dio desno, doljnji ljevo)
ako je to prekomplicirano, onda mozes na krmeno zrcalo ugraditi ovako nesto, naravno to moze najobicniji lim savijen da dize krmu iz vode
(http://www.wholesalemarine.com/blog/wp-content/ben31.jpg)
u mom slucaju meni se propela vrti u kontra smijeru od kazaljke na satu i kut osovine je nekih cc7 stupnjeva da brod dok lagano ubrzava prova pocme ici gore dolje ali kada brodu odvrnem full on doslovno iskoci iz vode a to sa trimovima ideja je odlicna i budem probao nesto izkombinirati pa cisto da probam kako ce se ponasati :)
imas li mozda ideju koliki bi kut trimova trebao biti na osnovu broda
nisam mislio na vrtnju vijka dal je ljevi ili desni :)
evo jedna skica, pretpostavljam da tvoja osovina stoji kao ova crvena, ako je tako (a prilicno sam siguran da je) onda je prvo pomakni u horizontalan polozaj, a kasnije ka nize al ne ispod nekih 10°
ako ni tad ne bude dovoljno onda propelu izravnaj na horizontalno, a trimove stavi 10° u odnosu na horizontalu kao plava linija
(http://i1293.photobucket.com/albums/b587/mbalun/Photobucket%20Desktop%20-%20EVAS-PC/Untitled_zps26399d7c.png)
meni osovina stoji nesto kao ovo plavo na slici sutra napravim trimove pa u utorak probam malo isprobavati :) hvala na ideji pa cemo da vidimo :)
evo slike kako to kod mene stoji
(http://imageshack.us/a/img266/1316/imag0232fl.th.jpg) (http://imageshack.us/photo/my-images/266/imag0232fl.jpg/)
pokusavam na videu skuzit dal ti prvo kad das gas digne pramac, il prvo skoci
moze biti jos jedno rjesenje a to je propeler s vecim lift efektom da ti malo podigne krmu, cini mi se kao da ti krma previse vuce pa da onda stvori moment koji je dovoljno velik da digne pramac. jel ti je osovina propelera nize od linije dna broda, ili je iznad, ?
nisam skuzio sliku, sad jos samo jedno pitanje, jesu li ti baterije iznad osovine illi ispred motora ?
Produži osovinu tak da ti oko 65-75% propelera bude ispod razine dna skije ili ti ga najniže točke čamca,pa onda probaj ;)
ma sovinu ne diram ni pod razno jer to znaci odpilit pola broda danas sam ugradio trimove pa cemo viti a sto se tice iskakanja to se dogodi kad opalim puni gas :)
meni motor stoji ispred baterije skoro u u vrhu broda a baterija stoji iznad osovine
ako ikako mozes smesti baterije ispred motora ili tocnije ispod osovine, trenutno je centar mase iznad osi propelera i dosta nazad i visoko, i onda ta sila stvara ogroman moment koji ti zavrti camac, na tome ti nece pomoc trimovi, mislim hoce malo al bi bilo bolje kad bi rjesio uzrok.
ja sam svjesan toga ali postoji problem sto je motor u prednjem dijelu otvona na brodu a baterija po sredini nazalost nemam opcija da to dvoje okrenem ja sam u provu doslovce ubacio 0.5kg mase izjednacim bateriju nazalost on se ponasao dosta slicno trimove sam stavio pa cu sutra isprobati i viti kako ce to funkcionirati javim se sutra posli testa
bas me zanima dal ce oni biti dovoljni da rjese problem. jel imas jos neku elisu ? da uzmes neku koja je za hidroplane ili nes slicno a da je istog koraka kao tvoja pa da vidis s njom. da ti izdigne krmu pri naglom dodavanju gasa
