Topic: Moj Heli moj SETUP (samo setup) (Read 21165 times) previous topic - next topic
Ovdje stavite svoj heli. slike .setup
Name:
Flight Style:
FBL System:
Motor:
Pinion:
Target Headspeed(s):
ESC:
Governor:
BEC:
RX Pack:
Cyclic Servos:
Tail Servo:
Main Blades:
Tail Blades:
Lipos:
Weight no batt:
Odg: Moj Heli moj SETUP
Flight Style: 3d
FBL System: mini vbar
Motor:Scorpion sk2520 1880kv
Pinion: stock
Target Headspeed(s): 3100
ESC:HBW 50a v3
Governor:da
BEC:ne
RX :vcontrol
Cyclic Servos:savox sh 0255mg
Tail Servo:savox sh 1257mg
Main Blades:align 360mm seconds
Tail Blades:alzrc 68mm
Lipos:nanotec 1550 6s
Weight : 850g
Name:SAB Goblin 500
Flight Style: skoro 3d
FBL System: Vbar Neo
Motor: Quantum 4120-1100kv
Pinion: 19
Target Headspeed(s): 2400
ESC:HBW Platinum 100a V3
Governor:da
BEC:ne
RX : vControl
Cyclic Servos: TGY 616HV
Tail Servo: RJX FS-0391THV
Main Blades:Edge 520
Tail Blades: stcok
Lipos:wellpower 4200mAh 35C 6s
name: MSH protos 500
flight style: mild 3d
fbl system: k bar
motor: scorpion
pinion: stock 15t
target headspeed: 2700
governor: ne
bec: castle ice
esc: castle ice 100
rx: spectrum
cyclic servos: ino lab hg 0260 mg
tail servo: mks 760
main blades: hk bezveze
tail blades: stock
lipos: zippy 6s  2450mah 30c
Name:hisky 100s[/font
]Flight Style: hard 3d
FBL System: HiSky FBL100 TX:OrangeRx R111XN
Motor:hisky 11500kv
Pinion: 9t
Target Headspeed(s): 10000000 (nemam pojma)
ESC:BLHELI
Governor:da
BEC:ne
RX :ORX Spektrum module taranis
Cyclic Servos:Spektrum 2,1gm
Tail Servo:brushles motor 14000kv
Main Blades:Assault 100mm seconds
Tail Blades:pl 23mm
Lipos:nanotec 300mah 2s
Weihgt:52,5g
Name: Walkera V450 D03
Flight style: mild 3d
Fbl system: 3dh v2
Motor: smt 2825  4400
Pinion: 11t
Target headspeed: 2800
Esc: yep 60A
Governor: ne
Bec: ne
rx: spectrum
Cyclic servos :wk 09-9
Tail servo: Align ds 525 m
Main blades: Rotorstar fbl
Tail blades: stock
Lipos: Nanotech 3s 2200 mah 50c
Flight Style: 3d
FBL System: Neuron[/
Motor:Leopard LC-500 1450kv
Pinion: 14t
Target Headspeed(s): 2600
ESC:yep 80a
Governor:da
BEC:7amp
RX :Taranis
Cyclic Servos:RTC D9257MG
Tail Servo:MKS 760 alu
Main Blades:EDGE 430mm seconds
Tail Blades:Revolution 73.5mm
Lipos:zippy 2650 6s
Weight :
Name:Tarot 450 pro v2
Flight Style: Za sada vise sarafam nego sto letim
FBL System: mini K-BAR V2 5.3.4
Motor: Helidrive T450 - 3600KV
Pinion: 13T
Target Headspeed: 2800
ESC: Red brick 50A
Governor:ne
BEC:ne
Cyclic Servos: Savox SH-0257MG
Tail Servo: ALIGN DS520
Main Blades:DEKO 325mm
Tail Blades: stock
Lipos: Nanotech 3s 2200 mah 45-90 C
Slika za sad nema jer nedavno sam gadno oro s helicem ???
Flight Style: 3d
FBL System: MSH Brain
Motor:Scorpion 51063 880kw
Pinion: 15t
Target Headspeed(s): 3000
ESC: YGE 60a
Governor:da
BEC:ne
RX :frsky X4R
Cyclic Servos:rctimer D9257
Tail Servo:Savox SH1290
Main Blades:HALO 450
Tail Blades:Stock carbon blend
Lipos:zippy 2650 6s
Weight :
Name:Blade 180 CFX
Flight Style: 3d
FBL System: AS3X® flybarless
Motor:Blade 5800Kv
Pinion: 10t
ESC: Castle Creations Talon 15
Governor:da
BEC:da
RX :Spektrum
Cyclic Servos:Spektrum H2060
Tail Servo: Spektrum
Main Blades:MH-18FX040BK
Tail Blades: MH-18FX030YL
Lipos:zippy 450mAh 3s
Weight :
Jeti Duplex DS-24
SAB Goblin 380 NEO, SAB Goblin 500 NEO
SAB Goblin 700 kyle stacy  NEO
Flight Style: Hard 2.5d
FBL System: kbar
Motor: scorp 4020 910kv
Pinion: 15t
ESC: stock hw 100a
Governor: kbar
BEC: cc bec pro
RX : gr12
Cyclic Servos: Align ds620
Tail Servo: Align ds655
Main Blades: spin blades 515mm
Tail Blades: edge 85mm
Lipos:zippy 4000mah 6s
Target headspeed: 2300
Weight : ko to zna :)
X3, G380, 600n, 700n diesel,
nesto benzinjare drvene.
Pauwerd baj Đeti
Flight Style: 3d
FBL System: Neo
Motor:Leopard lc450 1900kv
Pinion: 11t alu align
Headspeed(s): 2900, 3100
ESC:HBW 50a v3
Governor:da
BEC:ne
RX :vcontrol
Cyclic Servos:KST 215
Tail Servo:KST 565x
Main Blades:Zeal 360mm seconds
Weight : 950g
Name: MSH PROTOS 500
Flight Style: unbelivbl
FBL System: Beastx v3
Motor: hyperion 1000kv
Pinion: 15T
Target Headspeed(s): 3200
ESC:lipotech 80A
Governor: off
BEC: on
RX Pack: GR-16
Cyclic Servos: MKS
Tail Servo:MKS
Main Blades: rotostar
Tail Blades:msh orange
Lipos:6s 2600mah 40c
Weight: 1710 grama AUW
Flight Style: 3D
FBL System: NEO
Motor: O.S MAX 37SZ-H
Pinion: 19t
Headspeed(s): 2500, 2750
ESC: NE
Governor: DA
BEC: DA
RX :Spektrum DX9
Cyclic Servos:GS-511
Tail Servo:GS-518
Tail Blades:HALO CF 72
Lipos:NITRO 25%
Weight :
Jeti Duplex DS-24
Flight Style: 3d
FBL System:Neo
Motor: Leopard lc500 500kv
Pinion: 10
Target Headspeed(s):2150
ESC:Hobbywing 160a
Governor:da
BEC:ne
RX:Vcontrol
Cyclic Servos:Kts 815
Tail Servo:Kst 805
Main Blades:insane 700
Tail Blades:revolution 105
Lipos:zippy 5000 40c 6s 2x
Weight no batt:kg cca
![/url][/u] No longer available[/b][/font]
