Topic: Nova DJI NAZA V2 (Read 15986 times) previous topic - next topic
Nova DJI NAZA V2
NEW NAZA V2 Comming Soon. What’s new with the NAZA V2:
New Hardware - PMU V2
New case design with CANBUS port. Enhanced BEC functionality, better heat dissipation. Extra CANBUS ports, enhances the scalability of the system and will support Gopro Zenmuse, iOSD and Bluetooth module for assistant software use on smart phones in the future, etc..
Later NAZA V1 can also be upgraded using PMU V2 and support Gopro Zenmuse, iOSD and Bluetooth module..
Main Controller
The ha
rdware structure has been optimized and the scalability and performance of the flight control system has been enhanced
Independent LED Module
What’s new with the NAZA V2 : Firmware and functions
- New attitude stabilization algorithm, provides better flight performance / maneuverability;
- New flight control performance, provides better flight experience; (flight control is smoother, take-off is easier, and solved the swinging problem when descending at high speed.)
- Support for Octo-rotor;
- One-motor stopped still can land safely (Hexa-rotor, Octo-rotor)
- Automatic course deviation compensation, reduced the effects of magnetic disturbance; interference around the compass detection & warning;
- Added IMU advanced calibration, error identification and warning, reduced the impact of sensor error to the flight performance
Odg: Nova DJI NAZA V2
Ovo me baš zanima da li je potpuno solved ili je "solved"
Sad čekamo prve neovisne yubito uratke :)
Re: Nova DJI NAZA V2
Mene sad zanima ovaj bluetooth
to bi i ja... dobro dodje taj BT modul
bas danas idemo ja i sekile u kopterworks pa cu je vidjeti u zivo i raspitati se malo iz prve ruke...   :P
he he hebenica.......
kupi se samo pmu v2 za nazu i s tim dobis ubiti nazu V2...  tako da svi koji imaju v1 s tim ce imat v2....   to u kopterworksu kosta 65eura.... dolazi im za 14 dana...  ja prvi picim po to...  he he
Independent PMU with amazing function extension
Top
The Naza PMU V2 has enhanced BEC functionality and provides extendable CAN BUS ports, which can support iOSD, Zenmuse H3-2D gimbal (pitch control). Support is also included for optional Bluetooth LED module to allow parameter adjustment via a mobile APP (future firmware upgrade required for this functionality)
 8)
Ovo je super, kupiš samo taj modul, nadogradiš software i to je to
Ima li u Hrvatskoj shop koji prodaje DJI?
Nova DJI NAZA V2
Ja sam danas nadogradio staru nazu nista nisam kupovao samo skino sve od naze v2 i digo firmware. Vidi se razlika nista drasticno. Najvece poboljsanje i promjene sam primjetio kod poletanja
Dali je to na hexi isprobano?
Ako je, hexe su i prije jako dobro i stabilno radile, mislim da će ovdje biti veča razlika za nas koji letimo s quadovima.
Ako sam dobro skuzio sada su u igri i okte
Odg: Re: Nova DJI NAZA V2
Pa jesu iako mi nije baš najjasnije gdje se spajaju zadnja 2 motora, možda na F1 i F2 koji inaće služe za gimbal???
"Support octorotor; Add protection for Hexacopter, octocopter when lost one motor power"
A bude ju netko vec uzeo pa cemo i to vidjeti
okta se steka di je iso gimbal,  al zato ovaj novi adapter pmu sluzi..  u njega se steka gimbal,  novi osd koji ce uskoro doc i bluetooth modul za spajanje na mobitel....
ja se najvise veselim OSDu koji koristi.  nazine senzore....
2banga: ja sam isprobao na hexsi i vidi se razlika...  sad sa gps_om stoji ko ukopana,  i prije je odlicno radio ali sad se ne mice ni centimetar,  vide se razlike u upravljanju i poljetanju i sletanju.....   ja happy  :P
kako mi je danijel u kopterworksu reko: v2 je ista ko v1 samo narancaste boje,  sa novim led i usb adapterom i PMU adapterom...  Tako da svi koji imaju v1 kad kupe pmu i eventualno led adapter i stave 3.10 update...  imaju v2
