Topic: Racing quad - Team Hrvatska (Read 1773769 times) previous topic - next topic
Odg: Racing quad - Team Hrvatska
Reply #5760 –
Malac je vrhunski :)
Daj koji info:
Ich seh den Wald vor lauter Bäumen nicht.
Reply #5761 –
Evo ja cu pripomoc:
Frame: Quanum Wisp sa HK bez gornje ploce
Motori: 8,5mm brushed sa HK
FC i ESC: Scisky (Quanum) sa HK
vtx i cam imate na BG raznih micro (posaljem linkove kad dodjem na komp)
Propovi: Hubsan (za FPV potrebni Parrot propsi)
Batke: od 300-750mAh NanoTech
Treba vam DSM2 modul ili stanica (Spektrum, Orange)
Reply #5762 –
Hvala :)
Reply #5763 –
Kolko para te je ukupno izašo?
Reply #5764 –
@zed sad ces vidjet pelanja s ova dva nova malca sam da se zgotove...jos par sitnica ;) )))
evo ih cekaju napeti ko puske !!!
Reply #5765 –
Posto je to izvorno klicocopter, prvi ga je slozio Klic, evo sheram linkove koje je on meni poslao da ne izmisljam toplu vodu
Evo sve:
http://www.banggood.com/Micro-Scisky-32bits-Brushed-Flight-Control-Board-Based-On-Naze-32-For-Quadcopters-p-1002341.html
http://www.banggood.com/700TVL-CMOS-14-CMOS-FPV-Camera-150-Degree-Wide-Angle-NTSC-PAL-3_3-5V-p-1019754.html
http://www.banggood.com/FPV-5_8G-200mW-32CH-Wireless-Audio-Video-AV-Transmitter-Module-FX758-2-p-980317.html
http://www.banggood.com/FPV-5_8GHz-Micro-CL-TX-Anternna-0_8g-Lightweight-p-973291.html
http://www.banggood.com/Wholesale-3-Set-Walkera-QR-Ladybird-Spare-Parts-Main-Blades-Propellers-QR-Ladybird-Z-01-p-47127.html
Skuplji propsi s nešto više sape
http://www.ebay.com/itm/371287059595
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=89218
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=46634
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=86504
Ako želiš najjaće motore onda su to ovi, ali su 5 puta skuplji:
http://micro-motor-warehouse.com/collections/all-motors/products/cl-0820-17
110 baksa bez batki
BATKE:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=32783
Ove su stalno na backorderu:
http://www.hobbyking.com/hobbyking/store/__38364__Turnigy_nano_tech_300mah_1S_45_90C_Lipo_Pack_Fits_Nine_Eagles_Solo_Pro_100_EU_Warehouse_.html
Problem je kaj nećemo moć peljat svi skupa ako uzmemo svi ovaj vtx, jer treba nekaj prelemit na njemu da se otključaju svi kanali, ovak je lokano na IRC 7/8 kanal.
Evo i par korisnih linkova sa rcgroupsa:
http://www.rcgroups.com/forums/showthread.php?t=2382869
http://www.rcgroups.com/forums/showthread.php?t=2466286
Kak prelemit VTX na sve bandove:
http://www.rcgroups.com/forums/showthread.php?t=2456116
Spajanje FPV opreme (ima lik dobrih videa o micrachima):
http://www.drone-maniac.com/diy-cheap31usd-and-lightweight7-4g-200mw-5-8g-fpv-kit-with-widelens-and-cl-antenna/
Reply #5766 –
No dobro, moja 200-tka nije puno veca  :D
Reply #5767 –
posto je ovo 110 , a tak skoro duplo  ;D
Reply #5768 –
Je, je , soli, soli, kaj sad da uzmem flexu i sflexam ga :D
Reply #5769 –
Ovo je fakat mikronac, nedaj boze da ti padne negdje na livadi, nebus ga nasao. A kad hodas i cujes krc onda znas da si ga nasao  :D
Reply #5770 –
Ali za dvoranu u Rudešu ko stvoren
Reply #5771 –
Pozdrav društvo pošto su mi motori izubijani i pri kraju pa me zanima koje bi sad preporučili kaj uzet ja sam si razmišljao između emax mt2205 2300kv i rs2205 2300kv ali spreman sam i za sugestije
to bi išlo na qav 210 na 5045bn 3s bateriju...... :)
Reply #5772 –
QAV 2206 2200kv
Sent from LG-G4
Reply #5773 –
sunnysky su na akciji 9 dolara na survelizone
