Topic: Letenje multijem za vrijeme ljeta - pita turist? (Read 3598 times) previous topic - next topic
Dobio sam danas poruku na RCG od Poljaka koji bi letio na našoj obali:
My name is xxx and I am from Poland.
I would like to ask you about one subject.
Are there any restrictions on your law at the flying RC models?
Often I come to your country to sail and I would do some aerial photos of ports, islands, landscape.
Are the police in Croatia tolerate such activities?
Thank you in advance for your help.
Best Regards,
xxx
Nisam prije komunicirao s čovjekom, pretpostavljam da je vidio moje fpv filmiće s avionima, pa se javio. Vidim da ima homemade hexu i očito ima nešto iskustva, ali malo mi se ipak čini opasno da misli kako može bez brige letjeti hexom po lukama i u blizini ljudi. Htio sam mu odgovoriti nešto ovog tipa i malo ga obeshrabriti:
"During the summer coastline and islands are filled with tourists and I would strongly advise you to avoid flying over populated areas and/or above people at any time! Furthermore, if you are planning to fly without official permission for aerial recording, than somebody could probably report you and get you into trouble.
Some aerial photos in isolated places with safety in mind probably wouldn't  get you into problems, but always have in mind that your multi could potentially crash into forest and maybe cause a fire
Možda je još netko dobio slično pitanje. Što vi mislite da mu treba odgovoriti?
Odg: Letenje multijem za vrijeme ljeta - pita turist?
Znas kaj, gotovo u nulu isto pitanje sam ja dobio prosle godine samo je lik bio švabo... Tolko slicno da mi se sad cini ko neki spam... Ja sam mu napisao kak stvarno i je. Ovo tvoje mi se cini fer jedino bi mu ja dopisao da ako se makne od ljudi i snima da nece imat problema, osim ako ce gazit po tudoj zemlji...
Napisi mu da moze letiti na letalistima uz prisutnost clana kluba, bar je kod nas tako, a za letenje na divlje da moze dobiti po nosu
Sent from my SM-T211 using Tapatalk
Daj mu svoj IBAN i objasni mu da je dozvola 200€.. ;)
Haha. Mozda mu mozemo u paketu iznajmiti smjestaj i brod skupa s dozvolom :)
A sta bi oni trazili od nas recimo da se neko od nas sjeti snimati po berlinu ili parizu
A ciglu nek si naruci preko interneta... :)
Svašta.
"if you are planning to fly without official permission for aerial recording"
pretpostavljam da ovo znači da svi imate dozvole za fpv letenje i snimanje
________________________________________
Kaj jednostavno ne napišete čovjeku pravo stanje stvari:
trenutno važeći propisi ne zahtjevaju dozvolu za amatersko (nekomercijalno) letenje i snimanje
ne smije letiti bliže od 5km od aerodroma
ne smije letiti bliže od 2km od naseljenih mjesta
nije obavezno imati osiguranje
Kultura modelarskog letenja po zemljama tipa Slovačka, Češka, Poljska itd je nekoliko svjetlosnih godina ispred kulture letenja kod nas.
Ako je čovjek već lijepo i suvislo pitao o dozvolama i pravilima - onda sigurno zna što i zašto pita tj. ima iskustva.
Dolazi ovdje na godišnji, jedri uživa i sad bi to malo snimio - jer baš problem da recimo ode brodom u Kornate i napravi dobru fpv snimku? - pa recimo i objavi na jubitu itd - to može biti samo korisno.
Kad vidim koji moroni ovdje lete fpv/snimaju s kojom šugavom opremom i rizicima koje niti ne shvaćaju/razumiju - ovakvo raspitivanje i priprema mi je čisto osvježenje.
Meni se cini da su decki malo ljubomorni na "svoj" teren :)
sala mala.... ;D
