Topic: Turnigy 9XR Pro – info, pitanja i odgovori [FAQ] (Read 28480 times) previous topic - next topic
Izišao i 9XR Pro.
To je sam za profesionalce, nije za početnike koji se bave RC tramvajima.   :D :D :-X
http://www.hobbyking.com/hobbyking/store/__51442__Turnigy_9XR_PRO_Radio_Transmitter_Mode_2_without_module_.html
Full specke:
9XR Pro Added Features:
• ARM version of er9x radio firmware with EESKYPE simulater GUI support• 24 channel support
• 48 free mixes
• Expo, Triple rates, Curves settings
• Voice alerts
• Telemetry display• Atmel SAM3S ARM Cortex M3 , 32 bit Micro-controller , 512K flash , 64Kb of SRAM
• 4Mb EEprom for 30+ model storage
• Micro SD card (Included)
• Mini USB port, for access to SD card files and radio programing
• 1/2 Watt Audio Amplifier with digital control.
• RS232 Serial Port for External telemetry connection through Futaba trainer jack. (for DHT ,DXT)
• Logic level Serial Port for external Blue Tooth modules (HC-06,RN42)
• Dimable LED Back light
• Haptic Buzzer (pager vibrator) for trim center alert and alarm notifications
• Real "Tact" switches on menu keys, give positive feedback indication
• Built in bootloader. (Firmware can be updated in less than 15 seconds!)
• Full built-in Telemetry support for the latest RF modules. New DSM modules coming soon.
• Speaker and headphone outputs
• Ball Bearing gimbals
• Digital Trims
• Assignable Switches
• Freely Assignable Channel Mixes
• Graphical Dual Rate, Sub trims, travel adjust and Exponential
• Supports Heli/Aero/Glider and custom Model Types
• Programming templates based on model type
• Supports M1, M2, M3, M4 stick modes
• 128 x 64 backlit Liquid Crystal Display
• Built in JR & Futaba Trainer Ports
• JR Form Factor RF Modules (ORX Dsm2, ORX Open LRS 433Mhz etc)
• Programmable warnings
• 1.5Amp, 5V main switching regulator, with wide input voltage (6.5 - 30V)  (uses 3S lipo connection same as 9XR)
• Rotary encoder with push switch port (rotary encoder not included - user upgrade)
• Support for 6-way switch and more 3 way switches. (User upgrade)
• And so much more!!
A full set of user manuals and user videos are available to help learn how to use this powerful radio. Online support and user forums available at: www.turnigy9xr.com
Spec:
Channnel: Up to 24 supported
Display: 128*64LCD (dimmable Backlit)
Support Type: Heli/Acro/Glid/Custom
Model Memory: 30+
Stick modes: 1, 2, 3, 4
Encoder type: ppm/pcm
Module Interface: JR Compatible (See Related Items Below)
Simulator Interface: Yes (JR & Futaba)
Buzzer/Speaker: Yes
Battery Compartment: 112 x 44 x 27mm
Weight (less battery & Rf Module): 723g
Re: Turnigy 9XR Pro – info, pitanja i odgovori [FAQ]
Opa, izasao je!
Wow nakon skoro godinu dana i to je u prodaji.
http://www.rcgroups.com/forums/showthread.php?t=2019298
O dizajnu nebi - meni osobno nalikuje na kravlji drek preko kojeg je prešao traktor sa Pirot gumama - sorry.
ALI stanica je mrak po funkcijama - izvrstan board, OpenTX po želji, puno stvari se može preraditi/dograditi (postoje na bordu ali nisu spojene/iskorištene).
Pravi raj za hakiranje - od druge kutije do haptike, drugih switcheva, rotary kontrolera itd itd.
Wow design je skroz drugaciji, svida mi se, moram je naruciti.
Nigdje se nije nikada, nit spominjalo da bi se dizajn mogao mjenjati!
A vidim da je mene isao taj sarkasticni odgovor!
Ti si coljo puko kao kokica, i ti samo tražiš da se sa nekim prepireš ilitiga svađaš, ja tu namjeru nemam, niti je moj odgovor bio nemjenjen tebi, imam takvu stanicu pa sam se šalio da je drugačija od stare i da je stara 9xr sasvim dovoljna i to je sve!  Moj Bože ti se pitaš dali nam forum propada!
Miso, kakis! Ja sigurno se ne mislim svadati, ali si se ti ocito nabrijao jos u temi dali forum propada!
Prvo si pisao da se odjavim s foruma, a onda mjenjao post, tak da ja nebi procitao!
Iskreno mene puca donja pipa za misljenja vas tu s foruma!
Odg: Turnigy 9XR Pro – info, pitanja i odgovori [FAQ]
Evo splitao sam temu da imamo 9XR Pro posebno.
Ipak je to nova stanica, i bez obzira na sve nije losa.
Jedino se opasno priblizila cijeni Taranisa.
Jel nudi vise za tu cijenu ili ne?
Bilo bi super kada bi vardero updejtao prvi post po potrebi, da se sve odmah vidi.
Ono sto meni fali je popis modula koji provjereno rade tj. koji provjereno dbro rade :) sa linkovima na HC site.
Na gore linkanom RCG threadu piše sve i o mdulima i o razvoju itd. Thread je očajno dugačak ali svi razvijači sudjeluju i sve informacije su iz prve ruke.
Onda Taranis ili Pro?
Dizajn mi se podjednako ne svidja, tako da bi vjerojatno sam nesto rezbario za kutiju.
Taranis moze vrtiti isti firmware?
Koji su gimbali bolji? Meni je to kod 9XR smetalo.
MC3030, TX15
Tundra, Extra, Fusion, OMP
Mislim da se 9xr ne moze usporediti s taranisom!
Gimbali su bolji jedno 50 puta na taranisu i dolazi s modulom i baterijom!
Tako da pro nije nista jeftiniji, posto on kosta 100 dolara, pa jos 73 dolara modul kakav vec dolazi u taranisu i baterija jos 13 dolara!
