Topic: NAZE32 rasprave koliko je dobar  (Read 11023 times) previous topic - next topic
Odg: NAZE32 rasprave koliko je dobar
Reply #30
...ja sad ima 6 quadova za napravit...stavit ću naze32, kk2, oklopljenu kk2, naza v2, naza v2+gps, multiwie i onda test kontrolera, motora, fpv-a i ostalog...mora biti sve gotovo do našeg mitinga u 9-tom mjesecu...  8)
MAK Zapad   -    ZK Rode Prelog  -
https://www.facebook.com/progressof/?ref=bookmarks
Quad micro+mini, Hamer X-8, Dex min, T-Rex 500, Tarot650Ironman X8 Futaba 14SG
Reply #31
U imas dobranog posla  :-X
Reply #33
Nemam, sve je namontirano. Ja sad trazim po netu gdje naci motor koji sam skrsio danas pa nema nigdje
Reply #34
kosta 31$ al ti naplate 38$ malo cudna stranica i dobijes dva acro NAZE32 za jednu sa barometrom hmmm
Ako pogledas malo bolje to ti je samo konverzija vrijednosti s$  ili ti ga singapure dollar, nadam se da je od pomoci:-)
InnovationMatters
Reply #36
Za sve koji misle staviti naze32 evo nasao zgodan tutorial za podesavanje pidova. Jucer isprobali na livadi i funkcionira
Quad between 400-500 MTM such as RD450, qav500, ADS 400q (flat arms), Iconic-x
Looptime: 2800-3000
P: 4.6-5.2 (roll), above 5.0 (pitch)
I: default
D: up to 35 max (roll/pitch)
P gain for yaw are normally between 9.5 - 11. for ads 400 (gaui style), it's right up to 13. I suspect the arm gets full blast during FFF and requires higher P to lock.
Mini quad between 220-250 MTM such as RD230, mini quad blackout, DRQ250, QAV250
Looptime: 2300-2500 (can go down to 2000. any lower than that, it's hard to tune)
P: 2.8-3.2 (roll/pitch)
I: cranked it up a tad bit
D: up to 40 max (roll/pitch)
P gain for yaw are normally between 9.5-10.5
Mini hex 290mm (totally different animal esp on pitch)
Looptime: 2500
P: 4.0-4.5 (roll), 6.8-7.0 (pitch)
D: Up t0 42 max (roll/pitch)
P gain for yaw are between 10-11.5
Reply #37
Hm,nekako mi na ovom snimku,konfiguracija sa CC3D još bolje izgleda. Nekako je baš kao po šinama. Svaka čast.
Nisko,niže,...šetnja...
