Topic: iCharger 3010B - 1000W (Read 3803 times) previous topic - next topic
Uskoro izlazi iCharger 3010B, za sve one nove lipice gladne strue.
Ukratko - 1000W, 30A, 10S  ??? ???
Specke
Input voltage range: 4.50 – 38.0VDC
Charge current range: 0.05 – 30.0A  :P
Discharge current range: 0.05 – 30.0A
Maximum charge power capacity: 1000W @ input voltage 23V (500W @ input voltage 12V)
Maximum discharge power capacity:  80W
Maximum regenerative discharge power capacity: 1000W
Maximum extern discharge power capacity: 1200W @ 40V/30A
Current drain for balancing: <350mA
Balance accuracy: <10mV
Lithium (LiPo/LiIo/LiFe) battery cell count: 1-10 series (In non-balance mode, expand LiFe to 12s)
NiCd/NiMH battery cell count: 1–25 series
Pb battery cell count: 1–18 series (2–36V)
Battery setup memories: 10
Intelligent temperature control: Yes
PC Connect: USB port
Weight: 750g
Dimensions (L X W X D): 143X123X46mm
Odg: iCharger 3010B - 1000W
Malo pažljivije čitaj
na 12V ulaznog napona 500W
Ako oćeš kilovat onda na 27V traži 40A, koji to trafo može? (osim mog)
P
MC3030, TX15
Tundra, Extra, Fusion, OMP
Ma meni je dovoljno od Robija akomulator spojen paralelno sa Majkovim :)
A imamo i agregat :)
Da jako slabo toliko da poslje svakog letenja guramo bar jedan auto  jer još vjek nismo nabavili kleme a sreča je i u tome što je od wespa auto automatik taj se da fino na guranje upalit.
Mozete posudit APU od deckiju iz ZB Lucko. Ima 27V.
P
MC3030, TX15
