Topic: HK buddy code popusti (Read 397573 times) previous topic - next topic
Odg: HK buddy code popusti
Reply #136 –
Reply #137 –
Reply #139 –
Trex 500 fb
Aurora 9
Reply #143 –
ind my codes here: http://hk.rc-international.info/swarm/mifi (valid until November 23, 2011)
Code: [Select]
[URL=http://www.hobbyking.com/buddy.asp?code=1DE42278-4A9A-4498-9AFA-EB02BCA29296]Rhino 610mAh 2S 7.4v 20C Lipoly Pack[/URL]                             Save US$: 0.24
[URL=http://www.hobbyking.com/buddy.asp?code=014899C7-EB6F-4D04-A01E-12EC679D0940]Turnigy nano-tech 1300mah 3S 25~50C Lipo Pack[/URL]                    Save US$: 0.37
[URL=http://www.hobbyking.com/buddy.asp?code=8DB40FB9-19E6-40E2-AD15-BD1BC3F30803]Pushrod Snap Connectors 1.5mm (5pack)[/URL]                            Save US$: 0.79
[URL=http://www.hobbyking.com/buddy.asp?code=9AAE48E9-B449-43A8-BD12-FA7C8764C4F6]HobbyKing 4-6min Epoxy Glue[/URL]                                      Save US$: 0.07
[URL=http://www.hobbyking.com/buddy.asp?code=8F60C4BD-D2D9-42CC-862B-05C4DA217E1E]XT60 - JST Male In-line Power Adapter[/URL]                            Save US$: 0.43
Reply #144 –
Find my codes here: http://hk.rc-international.info/swarm/ssacer (valid until November 24, 2011)
Nylon Screws 6x75mm (10pcs)                                      Save US$: 0.32
Scale alloy hub rubber wheel 1.5inch                             Save US$: 1.12
Aluminium Prop Spinner 51mm / 2.0inch diameter                   Save US$: 0.47
HXT 6.9kg / 39.2g / .16sec Twin bearing servo                    Save US$: 0.11
20CM Servo Lead (Futaba) 32AWG Ultra Light (10pcs/set)           Save US$: 0.46
Master Airscrew propeller 9x8                                    Save US$: 1.96
Master Airscrew propeller 10x6                                   Save US$: 0.57
Gaui X3
Trex 600N
Seagull Decathlon 20cc
Reply #145 –
Find my codes here: http://hk.rc-international.info/swarm/icybox (valid until November 24, 2011)
Water Inlet for 42inch R/C Boat (2Pcs/Bag)                       Save US$: 0.91
Servo Mount                                                      Save US$: 0.34
Turnigy 4mm AquaProp 42x29x15mm.                                 Save US$: 0.45
Turnigy 4mm AquaProp 34x25x13mm.                                 Save US$: 0.45
Turnigy 4mm AquaProp 31x22x14mm.                                 Save US$: 0.45
Turnigy 4mm AquaProp 38x23x16mm.                                 Save US$: 0.45
Turnigy 4mm AquaProp 38x31x15mm.                                 Save US$: 0.45
Turnigy 4mm AquaProp R40x25x15mm.                                Save US$: 0.45
Turnigy Servo Tester                                             Save US$: 0.14
JST Male 2 pin connector set (10pcs/set)                         Save US$: 0.38
Reply #148 –
Find my codes here: http://hk.rc-international.info/swarm/marijom (valid until November 28, 2011)
HXT 6.9kg / 39.2g / .16sec Twin bearing servo                    Save US$: 0.08
HobbyKing 4-6min Epoxy Glue                                      Save US$: 0.07
Maxi-Cure Extra Thick Pocket CA 3/4 oz                           Save US$: 0.76
10CM Servo Lead (Futaba) 32AWG Ultra Light (10pcs/set)           Save US$: 0.75
30CM Servo Lead (Futaba) 32AWG Ultra Light (10pcs/set)           Save US$: 0.42
X3 UBEC 6v-23v input - 5v 3A Output                              Save US$: 2.53
