Topic: trex 500 flb dijelovi (Read 4051 times) previous topic - next topic
Re: trex 500 flb dijelovi
Prijatelju fali ti 100€
Mislim da ti fale pro gripovi, feathering (mozes i od stare verzije, sve iste) i main shaft za dfc glavu i thrust bering.
Odg: trex 500 flb dijelovi
set
http://www.ebay.com/itm/ALIGN-T-REX-500DFC-Main-Rotor-Head-Upgrade-Set-H50181-500-/360459434192?pt=Radio_Control_Parts_Accessories&hash=item53ed0e78d0#ht_6441wt_1163
●500DFC Main Rotor Head Assembly x 1
●500 Feathering Shaft Sleeve x 1
●500DFC Damper rubber x 2 (POM Φ6xΦ11x4mm)
●M2.5 Set screw x 1
●Socket collar screw(M2.5x19mm) x 2
●Socket collar screw(M2.5x16mm) x 1
●500DFC Main Blade Grip Arm x 2
●500DFC Main rotor grip arm integrated control link x 2
●500DFC Main rotor grip linkage bearing sleeve x 2
●682ZZ Bearing(Φ2.5xΦ6x2.6mm) x 4
●500DFC Linkage rod A(M2.5x12mm) x 2
●600PRO Elevator ball link x 2
●500DFC Main Shaft x 1
●Socket collar screw(M3x6mm) x 4
●250 Feathering shaft washer x 2
i jos samo gripovi
http://www.heliflightcenter.com/H50150_Trex_500PRO_Metal_Main_Rotor_Holder_p/H50150.htm
i to je to valjda  ???
Ajde onda iskopaj i za mene bar za servoe
treba jos i feathering shaft i thrust beringe (koje moze koristit od normale 500tke) i to je to
neo thx  ;)
