Topic: FrSky 2.4GHz FHSS kineski sistem sa telemetrijom (Read 13374 times) previous topic - next topic
Odg: FrSky 2.4GHz FHSS kineski sistem sa telemetrijom
Reply #15 –
Procedura:
1. provjeris da li je tx u PPM
2. ugasis tx
3. upalis tx pritom drzeci bind gumbek na modulu - lampica crvena blinka
4. spojis bateriju (pazi da je dovoljno napunjena) na prijemnik pritom drzeci bind gumbek. Crvena lampica treperi.
5. gotovo
6. zgasis tx i rx
7. upalis tx i rx i zarulja na rx svijetli zeleno !
AKo to nije tak onda jebiga.
Reply #16 –
na starom prijemniku je sve tak jedino pod brojem 7 svjetli crveno ali radi, a novi na 4 stvara problem crvena lampica neče treperit nego samo svijetli i kad ih ugasim pa upalim neradi :(
Reply #17 –
eh, onda je jedino da probas prijemnike upariti sa nekim drugim tele. modulom. Obicni modul ne igra sa tele. prijemnicima.
Jos mi pada na pamet V1 i V2 verzije softwarea, samo o tome ne znam nista. Moras malo to poguglati.
M.
Reply #19 –
da,da,da
ima nova revizija i u tom grmu leži zeko, evo tu imas sve za update
http://frsky-rc.com/ShowNews.asp?id=41
Two PPM modes: HS Mode and FS Mode:
We would suggest to apply HS Mode only for digital/high-speed servos.
HS mode has 9mS PPM period (111Hz), FS mode has 18mS PPM period (55.6Hz).  How to switch between two PPM modes on the RX:
Turn the transmitter off, connect the battery to the receiver, press the F/S button of receiver for 6 seconds and then release it.
The red LED will flash fast in HS Mode and slow in FS Mode when the TX is not turned on.
ovo piše na dnu strane i to smo jučer nenamjerno promjenili više puta, tj iz HS  brzo blink (9mS)  u FS sporo (18mS)
budemo danas probali opet sve kombinacije
samo pitanje; jel i tx mjenja HS i FS mode?
Reply #20 –
Caution:Please note that in two-way mode, both modules and receivers need to be upgraded simultaneously. V1 and V2 are not compatible.
RX module must be put into BOOT LOADER PROGRAMMING MODE by linking CH7 to CH8 signal pins on the RX before power up.
šta s ovim spajanjem signala izmađu 7 i 8 ch?
i ako ima taj  V2 program kak ga stavit u modul?
piše tu ali ni ja ni kano nismo experti za komp :(
TX module uses the FrSky USB or Serial Cable for upgrade.
RX must have a RS232 converter installed between the RX module data pins and the PC comm. Port.
Reply #21 –
izgleda da su prijemnici v2 sada bi trebo nekako ubacit novi software a ja nemam pojma kako  :( jel ima neko ko je to radio da mi napravi
Reply #22 –
uspio ubacit v2 softwer u stanicu i uspio bindat 2 nova prijemnika ;D i sada radi ali stari više neradi :( jer je v1 a nekužim kako ga stavit na v2 oni pokazuju neku međupločicu "upgrade lite" to nekužim  ???
Reply #23 –
dečki hvala vam na savjetima  8)
Reply #24 –
Za ovog prvog - starog treba ti ovo http://www.himodel.com/radios/FrSky_receiver_upgrade_lite.html
i procitati ovo http://www.frsky-rc.com/uploadfile/201011/20101108144206997.pdf
Sretno!
M.
Reply #25 –
Evo jedna jako bitna informacija za ekipu koja leti FrSky, prijemnici im nemaju natrimane antene za 2,4GHz band, pogotovo oni mali 4 kanala, nastelana im antena na 1345MHz i na udaljenosti nekih 300m sa 2dBi antenom padas, sa 5dBi pocinje pucat na 550m kod promjene polarizacije, a kad ukljucim video link potpuno padne veza;
Neki dan sam dva puta roknuo zbog te gluposti dok danas nisam isao isprobavat to jer me od pocetka bunila duzina te antene znajuci da je 1/4 valne duzine za 2,4GHz iznosi 2,96cm duzina vruceg kraja, znaci dio koji nije opleten masom, nakon trimanja sa prirucnim CSI metrom na 550m radi sve bez greske sa ukljucenim video linkom i GoPro kamerom koja je poznata da sprica na sve strane;
Svi koji imaju te prijemnike ili ostale od FrSky bilo bi pozeljno natrimat antenu, na malim V8R4 izmjeriti od sredine one smjese sa kojom je fixirana 2,96cm i tu je odrezat
Evo i video od prije 2 dana, tocno se moze vidjet udaljenost kad pukne rc veza
crash in HD
Reply #26 –
Evo novina za FrSky telemetry - i ja cu vjerojatno isto prijeci sa obicnog na telemetry!!!
Hack modul telemetry
http://www.frsky-rc.com/ShowProducts.asp?id=76
Senzor za bateriju
http://store.flytron.com/sensors/97-voltage-sensor-for-frsky-telemetry.html
Te meni zanimljiv LCD display za isti
http://www.flytron.com/rc-electronics/95-frsky-telemetry-display-rssivolts.html
pozzz
LP,  Chris
... gravity always wins ....
Reply #27 –
I to je moguce.....
3.5Km with Frsky 2.4Ghz
LP,  Chris
